GPU
• DeepStream Version
docker: nvcr.io/nvidia/deepstream:6.1.1-triton
• TensorRT Version
Driver Version: 520.56.06 CUDA Version: 11.8
Secondary GIE does not have Parent data. I’m trying associate the car that was detected (PGIE) with the detected LPD (SGIE) using YOLOv7 model
Python APP code snippet
pgie = Gst.ElementFactory.make("nvinferserver", "primary-inference")
sgie1 = Gst.ElementFactory.make("nvinferserver", "secondary1-nvinference-engine")
pgie.set_property("config-file-path", "/apps/configs/config_infer_primary_yolov7_triton-server.txt")
sgie1.set_property("config-file-path", "/apps/configs/config_infer_primary_yolov7_lpd_triton-server.txt")
pgie.set_property("process-mode", 1)
sgie1.set_property("process-mode", 2)
streammux.link(queue1)
queue1.link(pgie)
pgie.link(queue2)
queue2.link(tracker)
tracker.link(queue3)
queue3.link(nvanalytics)
nvanalytics.link(queue4)
queue4.link(sgie1)
## function
try:
# Note that l_obj.data needs a cast to pyds.NvDsObjectMeta
# The casting is done by pyds.NvDsObjectMeta.cast()
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
except StopIteration:
break
ndom_confidence = obj_meta.confidence
ndom_unique_component_id = obj_meta.unique_component_id
ndom_parent = obj_meta.parent
ndom_object_id = obj_meta.object_id
ndom_class_id = obj_meta.class_id
print(ndom_object_id,ndom_class_id, ndom_unique_component_id,ndom_parent)
Triton Primary GIE
infer_config {
unique_id: 1
gpu_ids: [0]
max_batch_size: 6
backend {
triton {
model_name: "yolov4-640"
version: -1
grpc {
url: "0.0.0.0:8001"
input_control {
process_mode : PROCESS_MODE_FULL_FRAME
interval : 0
Triton Secondary GIE
infer_config {
unique_id: 2
max_batch_size: 30
backend {
triton {
model_name: "yolo-lpr"
version: -1
grpc {
url: "0.0.0.0:8001"
input_control {
process_mode: PROCESS_MODE_CLIP_OBJECTS
operate_on_gie_id: 1
operate_on_class_ids: [0, 1, 2, 3, 4]
interval: 0
async_mode: false
object_control {
bbox_filter {
min_width: 128
min_height: 128
Output of Parent is None for Secondary GIE
GIE_ID > OBJ_TRACKER_ID > CLASS_ID > Parent
2 18446744073709551615 0 None
1 14451367522747809832 0 None
1 14451367522747809833 1 None
Also, I don’t understand why Tracker is operating on Secondary GIE.
