Hello NVIDIA Team,
I am facing a strange NVENC-related issue and I need some technical guidance from NVIDIA engineers.
🔍 Issue Summary
NVENC works perfectly at the system level, but a specific application (Filmora video editor) is unable to detect any NVENC encoders.
The application only shows CPU-based encoders (H.264, HEVC, AV1), while H.264 (NVENC) and HEVC (NVENC) are missing.
I have confirmed that this is not a GPU, driver, OS, or NVENC API issue, because system-level tests confirm that NVENC is fully functional.
The suspicion is that the latest NVIDIA drivers (581.xx) may not be backward-compatible with Filmora’s older NVENC SDK integration.
I need help confirming this.
🖥 My System Specifications
| Component | Details |
| GPU | NVIDIA GeForce RTX 3060 12GB |
| CPU | Intel Core i7-14700K |
| RAM | 64GB DDR5 (6000 MHz) |
| OS | Windows 11 x64 (Fully Updated) |
| Driver Version | 581.xx Studio Driver (Latest) |
| CUDA Version | Installed with driver |
| Application | Wondershare Filmora 15.0.14.16740 |
| Installation Type | Online installer |
✔ 1. System-level NVENC Works (Confirmed)
nvidia-smi Output
GPU detected correctly with no errors.
ffmpeg -encoders | findstr nvenc
Output:
✔ h264_nvenc
✔ hevc_nvenc
✔ av1_nvenc
All encoders available and working.
NVENC API DLLs present:
nvEncodeAPI64.dll -
nvEncodeAPI.dll -
nvcuda.dll -
nvcuvid.dll
Everything is correctly installed in System32 and SysWOW64.
✔ 2. Application-level NVENC Fails (Filmora)
Inside the application’s Plugins folder, NVENC-related DLLs exist:
wp_nvEnc.dll -
wp_nvEncV11.dll
But the UI does not show NVENC options:
❌ H.264 (NVIDIA NVENC)
❌ HEVC (NVIDIA NVENC)
Filmora support has confirmed:
They cannot provide older NVENC plugin files
They suspect compatibility issues with drivers
They are investigating
🧪 3. Tests Already Performed
I have already done:
✔ Clean uninstall + reinstall
Removed all:
Program Files, AppData/Local, AppData/Roaming, ProgramData.
✔ Older Filmora versions tested
Filmora 13/14/15 – same issue.
✔ GPU Acceleration enabled in settings
Filmora fails to load NVENC, even though OS sees it.
✔ NVIDIA Control Panel
Program added → Set to High Performance.
✔ Windows fully updated
Drivers also freshly installed.
✔ No hardware issues
NVENC works in:
FFmpeg
HandBrake
OBS Studio
Adobe Media Encoder
All applications detect NVENC except Filmora.
🚩 4. Hypothesis
It appears that:
🔸 Filmora uses an older NVENC SDK
and
🔸 New NVIDIA drivers (580+ series) may have breaking changes
that block Filmora from initializing NVENC.
I need confirmation from NVIDIA whether:
Q1 — Did NVIDIA deprecate/modify any NVENC APIs in recent drivers (580+ series)?
Q2 — Is backward compatibility with older NVENC SDK versions affected?
Q3 — Should I downgrade to a specific driver version for full NVENC support?
If yes, please recommend a stable driver version compatible with older NVENC SDK.
Q4 — Does RTX 3060 require any additional dependencies for NVENC initialization in apps using older SDK builds?
🙏 5. What I Need from NVIDIA
Official confirmation about NVENC changes in recent drivers
Recommended driver version for older NVENC SDK applications
Any documentation on NVENC compatibility across driver updates
Whether Filmora needs to update their NVENC integration
Thank you very much to the NVIDIA engineering team for your time.
I look forward to your guidance so I can help the application vendor resolve this issue.
Best regards,
Rakesh Kumar Goutam
