I installed a arducam b2050 imx477 camera. I’ve made a costum dtb file through jetson-io
and set it in extlinux.conf
as FDT /boot/tegra210-p3448-0000-p3449-0000-b00-user-custom.dtb
Its a bit unclear what the issue is.
it is shown as:
vi-output, imx477 7-001a (platform:54080000.vi:0):
/dev/video0
v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, imx477 7-001a
Bus info : platform:54080000.vi:0
Driver version: 4.9.253
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: no power)
Format Video Capture:
Width/Height : 3840/2160
Pixel Format : 'RG10'
Field : None
Bytes per Line : 7680
Size Image : 16588800
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
group_hold 0x009a2003 (bool) : default=0 value=0 flags=execute-on-write
sensor_mode 0x009a2008 (int64) : min=0 max=0 step=0 default=0 value=0 flags=slider
gain 0x009a2009 (int64) : min=0 max=0 step=0 default=0 value=16 flags=slider
exposure 0x009a200a (int64) : min=0 max=0 step=0 default=0 value=13 flags=slider
frame_rate 0x009a200b (int64) : min=0 max=0 step=0 default=0 value=2000000 flags=slider
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
write_isp_format 0x009a2068 (bool) : default=0 value=0
sensor_signal_properties 0x009a2069 (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
preferred_stride 0x009a206e (int) : min=0 max=65535 step=1 default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=3 flags=read-only
i executed
export DISPLAY=:0.0
nvgstcapture
Here is my daemon log:
=== NVIDIA Libargus Camera Service (0.98.3)=== Listening for connections...=== nvgstcapture[1176]: Connection established (7F99E591D0)Thread 1 getting next capture
Thread 1 is waiting
Thread 2 getting next capture
Thread 2 is waiting
Thread 3 getting next capture
Thread 3 is waiting
Thread 4 getting next capture
Thread 4 is waiting
Thread 5 getting next capture
Thread 5 is waiting
Thread 6 getting next capture
Thread 6 is waiting
Thread 7 getting next capture
Thread 7 is waiting
Thread 8 getting next capture
Thread 8 is waiting
Thread 9 getting next capture
Thread 9 is waiting
Thread 10 getting next capture
Thread 10 is waiting
Thread 11 getting next capture
Thread 11 is waiting
Thread 12 getting next capture
Thread 12 is waiting
Starting services...
Worker thread IspHw statsComplete start
Worker thread IspHw frameComplete start
Worker thread CaptureScheduler checkFramePending start
Worker thread CaptureScheduler frameStart start
Worker thread V4L2CaptureScheduler checkCaptureComplete start
Worker thread V4L2CaptureScheduler issueCaptures start
Worker thread PS handleRequests start
getInstance: s_instance(0x7f9491ce40)
subscribe: SensorType(gyroscope)
subscribe: create SensorType(gyroscope) sensor(0x7f94914750)
subscribe: SensorType(accelerometer)
subscribe: create SensorType(accelerometer) sensor(0x7f94924800)
AC plugin not present: dlopen "acplugin.so", acplugin.so: cannot open shared object file: No such file or directory
Services are started
NvPclSetHotplugCallback: ++++++++++++++++++++++
---- Imager: Calibration blob file handling supported in this build ----
NvPclHwGetModuleList: OFParserListModules Succeeded
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
NvPclHwMatchPartNum: Found calibration Part#: RBPCV3:"RBPCV3"
NvPclHwPrintModuleDefinition -- Name: porg_front_RBPCV3
NvPclHwPrintModuleDefinition -- Position: 1
NvPclHwPrintModuleDefinition -- CalibrationData Found: 1
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].Name: v4l2_lens
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName:
NvPclHwPrintCameraSubModule -- HwCamSubModule[1].Name: v4l2_sensor
NvPclHwPrintCameraSubModule -- HwCamSubModule[1].DevName: imx477 7-001a
NvPclHwMatchPartNum: Found calibration Part#: RBPCV2:"RBPCV2"
NvPclHwPrintModuleDefinition -- Name: porg_rear_RBPCV2
NvPclHwPrintModuleDefinition -- Position: 0
NvPclHwPrintCameraSubModule -- HwCamSubModule[1].DevName: arducam 8-000c
NvPclModuleListInitialize: NvPclModule list[0]: porg_front_RBPCV3 position1
NvPclModuleListInitialize: NvPclModule list[1]: porg_rear_RBPCV2 position0
NvPclHwScanExternalCameras -- adding video0 to discover list
NvPclHwScanExternalCameras: Failed to stat '/dev//log'; No such file or directory
NvPclHwScanExternalCameras: Failed to stat '/dev//initctl'; No such file or directory
getHotplugMonitor: Getting hotplug monitor instance
initializeHotplug++
hotPlugfunc ++
addWatch: Watch added wd='1'
CheckProcDTExists: INFO: accessing /proc/device-tree/tegra-virtual-camera-platform/modules; No such file or directory
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
setHotplugCallback: Registered new callback client
NvPclSetHotplugCallback: ----------------------
hotPlugfunc: reading from inotify FD, Thread waiting
NvPclOpen: ++++++++++++++++++++++
NvPclStateControllerOpen: Found GUID 1 match at index[0]
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f9483a830
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f948686a0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f9454f900
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94868610
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f949eba40
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f949d6d90
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16
CheckOverridesPermissions: stat(/Calib/camera_override.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/camera_overrides.isp] 2/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/camera_overrides.isp] 5/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/porg_front_RBPCV3.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/porg_front_RBPCV3.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/porg_front_RBPCV3.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/porg_front_RBPCV3.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/porg_front_RBPCV3.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/porg_front_RBPCV3.isp) call failed
---- imager: No override file found. ----
Imager: looking for override file [/mnt/factory/camera/factory.bin] 1/16
Imager: looking for override file [/Calib/factory.bin] 2/16
Imager: looking for override file [/Calib/calibration.bin] 3/16
Imager: looking for override file [(null)] 4/16
Imager: looking for override file [(null)] 5/16
Imager: looking for override file [(null)] 6/16
Imager: looking for override file [(null)] 7/16
Imager: looking for override file [(null)] 8/16
Imager: looking for override file [(null)] 9/16
Imager: looking for override file [(null)] 10/16
Imager: looking for override file [(null)] 11/16
Imager: looking for override file [(null)] 12/16
Imager: looking for override file [(null)] 13/16
Imager: looking for override file [(null)] 14/16
Imager: looking for override file [(null)] 15/16
Imager: looking for override file [(null)] 16/16
Imager: looking for override file [/data/vendor/nvcam/settings/factory.bin] 1/16
Imager: looking for override file [/data/vendor/nvcam/settings/porg_front_RBPCV3.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/porg_front_RBPCV3.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/porg_front_RBPCV3.bin] 4/16
NvPclCreateDriver: Found NvPcl Driver Hal dev_name match (v4l2_lens)
NvPclCreateDriver: Found a Driver name match (v4l2_lens)
NvPclCreateDriver: Found NvPcl Driver Hal dev_name match (v4l2_sensor)
NvPclCreateDriver: Found a Driver name match (v4l2_sensor)
NvPclConnectDrivers: hImager was NULL, creating new imager
NvPclInitializeDrivers: v4l2_lens ++++++++++++++++++
initialize WARNING: No focuser object, allocating for lens
OFDPropertyCopyToLong: could not read property [maxslewrate]
loadLensMetadata: maxslewrate not set in driver
NvPclInitializeDrivers: NvOdmLensStub ------------------
NvPclInitializeDrivers: v4l2_sensor ++++++++++++++++++
OFDPropertyGetString: could not read property [devnode-bus]
OFDPropertyGetString: could not read property [use_decibel_gain]
OFDPropertyGetString: could not read property [delayed_gain]
OFDPropertyCopyToLong: could not read property [has-eeprom]
OFDPropertyGetString: could not read property [sync_sensor]
OFDPropertyGetString: could not read property [type]
loadSubType: Sensor type missing in DT, 208
OFDPropertyCopyToLong: could not read property [set_mode_delay_ms]
OFDPropertyCopyToLong: could not read property [mode0.vc_id]
OFDPropertyCopyToLong: could not read property [mode0.dynamic_pixel_bit_depth]
OFDPropertyCopyToLongLong: could not read property [mode0.serdes_pix_clk_hz]
OFDPropertyCopyToLongLong: could not read property [mode0.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode0.gain_step_pitch]
OFDPropertyCopyToLong: could not read property [mode0.clk_settletime]
OFDPropertyCopyToLong: could not read property [mode0.embedded_metadata_width]
OFDPropertyGetString: could not read property [mode0.x_start]
OFDPropertyGetString: could not read property [mode0.y_start]
OFDPropertyGetString: could not read property [mode0.x_end]
OFDPropertyGetString: could not read property [mode0.y_end]
OFDPropertyGetString: could not read property [mode0.h_scaling]
OFDPropertyGetString: could not read property [mode0.v_scaling]
OFDPropertyCopyToLong: could not read property [mode1.vc_id]
OFDPropertyCopyToLong: could not read property [mode1.dynamic_pixel_bit_depth]
OFDPropertyCopyToLongLong: could not read property [mode1.serdes_pix_clk_hz]
OFDPropertyCopyToLongLong: could not read property [mode1.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode1.gain_step_pitch]
OFDPropertyCopyToLong: could not read property [mode1.clk_settletime]
OFDPropertyCopyToLong: could not read property [mode1.embedded_metadata_width]
OFDPropertyGetString: could not read property [mode1.x_start]
OFDPropertyGetString: could not read property [mode1.y_start]
OFDPropertyGetString: could not read property [mode1.x_end]
OFDPropertyGetString: could not read property [mode1.y_end]
OFDPropertyGetString: could not read property [mode1.h_scaling]
OFDPropertyGetString: could not read property [mode1.v_scaling]
OFDPropertyCopyToLong: could not read property [mode2.vc_id]
OFDPropertyCopyToLong: could not read property [mode2.dynamic_pixel_bit_depth]
OFDPropertyCopyToLongLong: could not read property [mode2.serdes_pix_clk_hz]
OFDPropertyCopyToLongLong: could not read property [mode2.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode2.gain_step_pitch]
OFDPropertyCopyToLong: could not read property [mode2.clk_settletime]
OFDPropertyCopyToLong: could not read property [mode2.embedded_metadata_width]
OFDPropertyGetString: could not read property [mode2.x_start]
OFDPropertyGetString: could not read property [mode2.y_start]
OFDPropertyGetString: could not read property [mode2.x_end]
OFDPropertyGetString: could not read property [mode2.y_end]
OFDPropertyGetString: could not read property [mode2.h_scaling]
OFDPropertyGetString: could not read property [mode2.v_scaling]
initialize: Loaded Driver: 3 Modes Available--------------
NvPclInitializeDrivers: v4l2_sensor ------------------
NvPclOpen: ----------------------
NvPclStateControllerOpen: Found GUID 0 match at index[1]
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94c20270
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94bf9d00
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f949c03a0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f949e95f0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f949ec710
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f949e9f00
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/porg_rear_RBPCV2.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/porg_rear_RBPCV2.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/porg_rear_RBPCV2.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/porg_rear_RBPCV2.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/porg_rear_RBPCV2.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/porg_rear_RBPCV2.isp) call failed
Imager: looking for override file [/data/vendor/nvcam/settings/porg_rear_RBPCV2.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/porg_rear_RBPCV2.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/porg_rear_RBPCV2.bin] 4/16
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 107)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f949e95f0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f949ec710
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f949e9f00
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f94c20270
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f94bf9d00
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f949c03a0
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
NvPclStateControllerClose: Module porg_rear_RBPCV2 closed
NvPclOpen: PCL Open Failed. Error: 0xf
NvPclClose: ++++++++++++++++++++++
NvPclClose: ----------------------
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 593)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 305)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 471)
Acquiring SCF Camera device source via index 1 has failed. === nvgstcapture[1176]: CameraProvider initialized (0x7f949ea060)sourceRegistry[0] assigned
ispRegistry[1] assigned
Using Source GUID 1
Worker thread ViCsiHw frameComplete start
Worker thread ViCsiHw frameStart start
NvPclPowerOn: +++++++++++
NvPclPowerOn: -----------
Using ISP B
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=2, m_value=4294967295, m_timeout_ms=1000
SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
No library found, disabling AC plugin.
Worker thread CaptureDispatcher start
(Argus) Error NotSupported: Failed to initialize EGLDisplay (in src/eglutils/EGLUtils.cpp, function getDefaultDisplay(), line 77)
(Argus) Error NotSupported: Failed to get default display (in src/api/EGLOutputStreamImpl.cpp, function initialize(), line 99)
(Argus) Error NotSupported: (propagating from src/api/CaptureSessionImpl.cpp, function createEGLOutputStream(), line 795)
(Argus) Error InvalidState: Unknown stream deleted. (in src/api/CaptureSessionImpl.cpp, function outputStreamDeleted(), line 853)
(Argus) Error NotSupported: (propagating from src/api/CaptureSessionImpl.cpp, function createOutputStreamInternal(), line 712)
Worker thread CaptureDispatcher stop
ViCsi capture path not initialized
Worker thread ViCsiHw frameComplete stop
Worker thread ViCsiHw frameStart stop
NvPclPowerOff: +++++++++++
NvPclPowerOff: -----------
Vertex shader compilation failed with log:
0:1(10): error: GLSL 4.30 is not supported. Supported versions are: 1.10, 1.20, 1.30, 1.40, 1.00 ES, and 3.00 ES
Shader source:
#version 430
layout(location = 0) in vec4 aVertex;
layout(location = 1) in vec2 aTexCoord;
out vec2 texCoord;
void main() {
gl_Position = aVertex;
texCoord = aTexCoord;
SCF: Error NotSupported: Shader compile failed (in src/services/gl/GLContext.cpp, function createShader(), line 92)
SCF: Error NotSupported: (propagating from src/services/gl/GLContext.cpp, function createProgram(), line 116)
SCF: Error NotSupported: (propagating from src/components/stages/GpuBlitStage.cpp, function initializeGL(), line 184)
SCF: Error NotSupported: (propagating from src/components/stages/GpuBlitStage.cpp, function initialize(), line 56)
SCF: Error NotSupported: (propagating from src/components/stages/GpuBlitStage.cpp, function doAsyncInitialize(), line 708)
4l2-ctl -d /dev/video0 --set-fmt-video=width=1440,height=1080,pixelformat=RG10 --set-ctrl=sensor_mode=0 --stream-mmap --set-ctrl bypass_mode=0
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.09 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.04 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.03 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.02 fps
v4l2-compliance -d /dev/video0
v4l2-compliance SHA : not available
Driver Info:
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Video Capture
Streaming
Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second video open: OK
test VIDIOC_G/S_PRIORITY: OK
test for unlimited opens: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Test input 0:
Control ioctls:
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 1 Private Controls: 17
Format ioctls:
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
fail: v4l2-test-formats.cpp(1184): ret && node->has_frmintervals
test VIDIOC_G/S_PARM: FAIL
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
test VIDIOC_S_FMT: OK
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
test Scaling: OK (Not Supported)
Codec ioctls:
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls:
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
test VIDIOC_EXPBUF: OK
Test input 0:
Total: 43, Succeeded: 42, Failed: 1, Warnings: 0
