NVIDIA 340.108 - Linux 6.15: Failed to build kernel module
NVIDIA driver 340.108 (NVIDIA-Linux-x86_64-340.108-no-compat32.run) fails to be built on an up to date ArchLinux distro, the graphic card is a Fujitsu NVIDIA Quadro NVS 300 Adaptateur graphique PCI Express x16 512 Mo DDR3 DVI, DisplayPort (HDCP). It’s still building on Linux 6.14.
# CC [M]  nv-cray.o
  cc -Wp,-MMD,./.nv-cray.o.d -nostdinc -I/usr/lib/modules/6.15.4-arch2-1/build/arch/x86/include -I/usr/lib/modules/6.15.4-arch2-1/build/arch/x86/include/generated -I/usr/lib/modules/6.15.4-arch2-1/build/include -I/usr/lib/modules/6.15.4-arch2-1/build/include -I/usr/lib/modules/6.15.4-arch2-1/build/arch/x86/include/uapi -I/usr/lib/modules/6.15.4-arch2-1/build/arch/x86/include/generated/uapi -I/usr/lib/modules/6.15.4-arch2-1/build/include/uapi -I/usr/lib/modules/6.15.4-arch2-1/build/include/generated/uapi -include /usr/lib/modules/6.15.4-arch2-1/build/include/linux/compiler-version.h -include /usr/lib/modules/6.15.4-arch2-1/build/include/linux/kconfig.h -include /usr/lib/modules/6.15.4-arch2-1/build/include/linux/compiler_types.h -D__KERNEL__ -std=gnu11 -fshort-wchar -funsigned-char -fno-common -fno-PIE -fno-strict-aliasing -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=branch -fno-jump-tables -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -march=x86-64 -mtune=generic -mno-red-zone -mcmodel=kernel -mstack-protector-guard-reg=gs -mstack-protector-guard-symbol=__ref_stack_chk_guard -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -mindirect-branch-cs-prefix -mfunction-return=thunk-extern -fno-jump-tables -mharden-sls=all -fpatchable-function-entry=16,16 -fno-delete-null-pointer-checks -O2 -fno-allow-store-data-races -fstack-protector-strong -ftrivial-auto-var-init=zero -fzero-init-padding-bits=all -fno-stack-clash-protection -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -fmin-function-alignment=16 -fstrict-flex-arrays=3 -fno-strict-overflow -fno-stack-check -fconserve-stack -fno-builtin-wcslen -Wall -Wextra -Wundef -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Werror=strict-prototypes -Wno-format-security -Wno-trigraphs -Wno-frame-address -Wno-address-of-packed-member -Wmissing-declarations -Wmissing-prototypes -Wframe-larger-than=2048 -Wno-main -Wno-dangling-pointer -Wvla -Wno-pointer-sign -Wcast-function-type -Wno-unterminated-string-initialization -Wno-array-bounds -Wno-stringop-overflow -Wno-alloc-size-larger-than -Wimplicit-fallthrough=5 -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wenum-conversion -Wunused -Wno-unused-but-set-variable -Wno-unused-const-variable -Wno-packed-not-aligned -Wno-format-overflow -Wno-format-truncation -Wno-stringop-truncation -Wno-override-init -Wno-missing-field-initializers -Wno-type-limits -Wno-shift-negative-value -Wno-maybe-uninitialized -Wno-sign-compare -Wno-unused-parameter -g -gdwarf-5  -DMODULE  -DKBUILD_BASENAME='"nv_cray"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o nv-cray.o nv-cray.c
In file included from nv-linux.h:14,
                 from nv.c:13:
nv.h:15:10: fatal error: nvtypes.h: No such file or directory
   15 | #include <nvtypes.h>
                 from nv-cray.c:15:
                 from nv-chrdev.c:15:
                 from nv-acpi.c:15:
compilation terminated.
make[4]: *** [/usr/lib/modules/6.15.4-arch2-1/build/scripts/Makefile.build:203: nv-acpi.o] Error 1
make[4]: *** Waiting for unfinished jobs....
make[4]: *** [/usr/lib/modules/6.15.4-arch2-1/build/scripts/Makefile.build:203: nv-chrdev.o] Error 1
make[4]: *** [/usr/lib/modules/6.15.4-arch2-1/build/scripts/Makefile.build:203: nv-cray.o] Error 1
make[4]: *** [/usr/lib/modules/6.15.4-arch2-1/build/scripts/Makefile.build:203: nv.o] Error 1
make[3]: *** [/usr/lib/modules/6.15.4-arch2-1/build/Makefile:2003: .] Error 2
make[2]: *** [/usr/lib/modules/6.15.4-arch2-1/build/Makefile:248: __sub-make] Error 2
N.B. : I know it’s an out of support issue, but this card works as a brand new one…
nvidia-bug-report.log.gz (53.9 KB)
Hi, Did you manage to resolve this issue? I’ve a similar problem.
Thank you.
Yes, and I am currently running Linux kernel 6.19.14-arch1-1, the latest one. So it is possible. You can try my Github repo, a fork of archlinux-jerry/nvidia-340xx, where there is a patch I have made. I also submit a PR. Cf AUR (en) - nvidia-340xx.
Thank you so much for quick response! I’m on 6.17.0 hope its compatible. :)
