Nvidia 455.45.1 Make Failed on Linux Kali
Hello, I am trying to install Graphic Card Driver 455.45.1 which is for my RTX 2070 MaxQ. on Linux kali but I am unable to do so. all the time I am getting an error that is related to the Nvidia driver itself where Make always fails…Please help.
Error:
DKMS make.log for nvidia-455.45.01 for kernel 5.9.0-kali5-amd64 (x86_64)
Wed 20 Jan 2021 09:09:17 PM IST
make[1]: Entering directory ‘/usr/src/linux-headers-5.9.0-kali5-common’
make[2]: Entering directory ‘/usr/src/linux-headers-5.9.0-kali5-amd64’
scripts/Makefile.lib:8: ‘always’ is deprecated. Please use ‘always-y’ instead
SYMLINK /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-kernel.o
SYMLINK /var/lib/dkms/nvidia/455.45.01/build/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: set_pages_array_uc
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: dma_attr_macros
CONFTEST: dma_map_page_attrs
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: get_backlight_device_by_name
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: kernel_read
CONFTEST: kernel_write
CONFTEST: kthread_create_on_node
CONFTEST: of_find_matching_node
CONFTEST: dev_is_pci
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: tegra_bpmp_send_receive
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: jiffies_to_timespec
CONFTEST: ktime_get_raw_ts64
CONFTEST: ktime_get_real_ts64
CONFTEST: vga_tryget
CONFTEST: pgprot_decrypted
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: cpumask_of_node
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_framebuffer_get
CONFTEST: drm_gem_object_get
CONFTEST: drm_dev_put
CONFTEST: drm_format_num_planes
CONFTEST: drm_connector_for_each_possible_encoder
CONFTEST: drm_gem_object_put_unlocked
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_gpl_sme_active
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present___close_fd
CONFTEST: is_export_symbol_present_get_unused_fd
CONFTEST: is_export_symbol_present_get_unused_fd_flags
CONFTEST: is_export_symbol_present_screen_info
CONFTEST: is_export_symbol_present_nvhost_get_default_device
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
CONFTEST: is_export_symbol_present_kthread_create_on_node
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: file_operations
CONFTEST: file_inode
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: device_driver_of_match_table
CONFTEST: device_of_node
CONFTEST: node_states_n_memory
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: proc_ops
CONFTEST: timespec64
CONFTEST: vmalloc_has_pgprot_t_arg
CONFTEST: mm_has_mmap_lock
CONFTEST: pci_channel_state
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_fault_t
CONFTEST: mmu_notifier_ops_invalidate_range
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: drm_crtc_state_has_async_flip
CONFTEST: drm_crtc_state_has_pageflip_flags
CONFTEST: drm_format_modifiers_present
CONFTEST: drm_display_mode_has_vrefresh
CONFTEST: drm_driver_master_set_has_int_return_type
CONFTEST: drm_driver_has_gem_free_object
CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_hyperv_available
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-frontend.o
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv.o
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-pci.o
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-acpi.o
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-cray.o
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-dma.o
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-i2c.o
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-mmap.o
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-p2p.o
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-pat.o
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-procfs.o
CC [M] /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-usermap.o
In file included from /var/lib/dkms/nvidia/455.45.01/build/common/inc/conftest.h:5,
from /var/lib/dkms/nvidia/455.45.01/build/common/inc/nv-linux.h:17,
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-frontend.c:13:
/var/lib/dkms/nvidia/455.45.01/build/conftest/functions.h:11:2: error: #error acpi_walk_namespace() conftest failed!
11 | #error acpi_walk_namespace() conftest failed!
/var/lib/dkms/nvidia/455.45.01/build/conftest/functions.h:70:2: error: #error radix_tree_replace_slot() conftest failed!
70 | #error radix_tree_replace_slot() conftest failed!
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv.c:14:
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-acpi.c:15:
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-cray.c:15:
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-dma.c:15:
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-mmap.c:15:
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-procfs.c:15:
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-pat.c:15:
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-p2p.c:15:
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-usermap.c:15:
In file included from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/jiffies.h:13,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/ktime.h:25,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/timer.h:6,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/workqueue.h:9,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/srcu.h:21,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/notifier.h:16,
from /usr/src/linux-headers-5.9.0-kali5-common/arch/x86/include/asm/uprobes.h:13,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/uprobes.h:49,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/mm_types.h:14,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/mmzone.h:21,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/gfp.h:6,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/xarray.h:14,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/radix-tree.h:18,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/idr.h:15,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/kernfs.h:13,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/sysfs.h:16,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/kobject.h:20,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/pci.h:35,
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-pci-table.h:14,
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-pci.c:11:
./include/generated/timeconst.h:11:2: error: #error “include/generated/timeconst.h has the wrong HZ value!”
11 | #error “include/generated/timeconst.h has the wrong HZ value!”
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/mm.h:10,
from /var/lib/dkms/nvidia/455.45.01/build/common/inc/nv-pgprot.h:17,
from /var/lib/dkms/nvidia/455.45.01/build/common/inc/nv-linux.h:20,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/of.h:17,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/irqdomain.h:35,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/acpi.h:13,
from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/i2c.h:13,
from /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-i2c.c:13:
In file included from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/xarray.h:14,
/usr/src/linux-headers-5.9.0-kali5-common/include/linux/gfp.h: In function ‘gfp_zone’:
/usr/src/linux-headers-5.9.0-kali5-common/include/linux/gfp.h:428:20: warning: left shift count >= width of type [-Wshift-count-overflow]
428 | | (OPT_ZONE_DMA32 << (___GFP_MOVABLE | ___GFP_DMA32) * GFP_ZONES_SHIFT)
/usr/src/linux-headers-5.9.0-kali5-common/include/linux/gfp.h:453:7: note: in expansion of macro ‘GFP_ZONE_TABLE’
453 | z = (GFP_ZONE_TABLE >> (bit * GFP_ZONES_SHIFT)) &
In file included from /usr/src/linux-headers-5.9.0-kali5-common/include/linux/mm.h:10,
cc1: some warnings being treated as errors
make[3]: *** [/usr/src/linux-headers-5.9.0-kali5-common/scripts/Makefile.build:288: /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv-acpi.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.9.0-kali5-common/scripts/Makefile.build:288: /var/lib/dkms/nvidia/455.45.01/build/nvidia/nv.o] Error 1
make[2]: *** [/usr/src/linux-headers-5.9.0-kali5-common/Makefile:1799: /var/lib/dkms/nvidia/455.45.01/build] Error 2
make[2]: Leaving directory ‘/usr/src/linux-headers-5.9.0-kali5-amd64’
make[1]: *** [Makefile:185: __sub-make] Error 2
make[1]: Leaving directory ‘/usr/src/linux-headers-5.9.0-kali5-common’
make: *** [Makefile:81: modules] Error 2
**Note: I have also uploaded error log.error.log (222.9 KB) **
For kernel 5.9, you need a 460 driver.
Please also make sure you have the correct gcc set.
wait brother i am trying it…and i have GCC version : gcc (Debian 10.2.1-3) 10.2.1 20201224 and make version: GNU Make 4.3
got same error on 460 driver…It always fail at DKMS buliding. :( error.log: error2.log (221.1 KB)
Please post the output of
cat /proc/version
gcc -v
cc -v
cat/proc/version: Linux version 5.9.0-kali5-amd64 (devel@kali.org) (gcc-10 (Debian 10.2.1-1) 10.2.1 20201207, GNU ld (GNU Binutils for Debian) 2.35.1) #1 SMP Debian 5.9.15-1kali1 (2020-12-18)
gcc -v: gcc (Debian 10.2.1-3) 10.2.1 20201224
and what is cc ?
In the best case, a symbolic link to gcc.
could you be more specific. Please
in a terminal, type:
cc -v
hit the enter key, then post the output here.
ok…i thought you mistyped gcc to cc…sorry
cc -v: Using built-in specs.
COLLECT_GCC=cc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/10/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none:amdgcn-amdhsa:hsa
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: …/src/configure -v --with-pkgversion=‘Debian 10.2.1-3’ --with-bugurl=file:///usr/share/doc/gcc-10/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-10 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none=/build/gcc-10-0py4jQ/gcc-10-10.2.1/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-10-0py4jQ/gcc-10-10.2.1/debian/tmp-gcn/usr,hsa --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu --with-build-config=bootstrap-lto-lean --enable-link-mutex
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 10.2.1 20201224 (Debian 10.2.1-3)
All correctly set. You could try to reinstall the kernel headers, should be
ok wait
it worked but :) <3 thanks…but one more thing…i got in weird problem had to change switchable graphics to discrete in BIOS else I will get stuck and STARTX will not work for that i have to remove X11 configuration file.
In hybrid mode, you’ll have to configure it for PRIME:
https://forums.developer.nvidia.com/t/official-driver-384-59-with-geforce-1050m-doesnt-work-on-opensuse-tumbleweed-kde/52620/2?u=generix
