Debian Bookworm 5.14.0-1-amd64 build fail
Same problem as reported by @rba777 in their most recent post here GNU/Linux Debian 11 nvidia-drm driver errors (version 470.57.02) - #4 by rba777
For me, I’m using the distro’s package. Yes yes, I should be using the ‘official’ build foo from nvidia… more just posting this so others can know it’s an observed behaviour elsewhere and not just you.
DKMS make.log for nvidia-current-470.57.02 for kernel 5.14.0-1-amd64 (x86_64)
Wed 29 Sep 2021 06:11:00 AEST
make KBUILD_OUTPUT=/lib/modules/5.14.0-1-amd64/build V=1 -C /lib/modules/5.14.0-1-amd64/source M=/var/lib/dkms/nvidia-current/470.57.02/build ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/5.14.0-1-amd64/source NV_KERNEL_OUTPUT=/lib/modules/5.14.0-1-amd64/build NV_KERNEL_MODULES="nvidia nvidia-uvm nvidia-modeset nvidia-drm nvidia-peermem" INSTALL_MOD_DIR=kernel/drivers/video NV_SPECTRE_V2=0 modules
make[1]: Entering directory '/usr/src/linux-headers-5.14.0-1-common'
make -C /usr/src/linux-headers-5.14.0-1-amd64 -f /usr/src/linux-headers-5.14.0-1-common/Makefile modules
make[2]: Entering directory '/usr/src/linux-headers-5.14.0-1-amd64'
test -e include/generated/autoconf.h -a -e include/config/auto.conf || (		\
echo >&2;							\
echo >&2 "  ERROR: Kernel configuration is invalid.";		\
echo >&2 "         include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo >&2 "         Run 'make oldconfig && make prepare' on kernel src to fix it.";	\
echo >&2 ;							\
/bin/false)
make -f /usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build obj=/var/lib/dkms/nvidia-current/470.57.02/build \
single-build= \
need-builtin=1 need-modorder=1
NV_CONFTEST_CMD=/bin/sh /var/lib/dkms/nvidia-current/470.57.02/build/conftest.sh " gcc-10" x86_64 /lib/modules/5.14.0-1-amd64/source /lib/modules/5.14.0-1-amd64/build
NV_CONFTEST_CFLAGS=-O2 -D__KERNEL__ -DKBUILD_BASENAME="#conftest15755" -DKBUILD_MODNAME="#conftest15755" -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/lib/modules/5.14.0-1-amd64/source/arch/x86/include/asm/mach-default -I/lib/modules/5.14.0-1-amd64/source/include/asm-x86/mach-default -I/lib/modules/5.14.0-1-amd64/build/include2 -I/lib/modules/5.14.0-1-amd64/build/include -include /lib/modules/5.14.0-1-amd64/build/include/generated/autoconf.h -I/lib/modules/5.14.0-1-amd64/source/arch/x86/include -I/lib/modules/5.14.0-1-amd64/source/arch/x86/include/uapi -I/lib/modules/5.14.0-1-amd64/build/arch/x86/include/generated -I/lib/modules/5.14.0-1-amd64/build/arch/x86/include/generated/uapi -I/lib/modules/5.14.0-1-amd64/source/include -I/lib/modules/5.14.0-1-amd64/source/include/uapi -I/lib/modules/5.14.0-1-amd64/source/include/xen -I/lib/modules/5.14.0-1-amd64/build/include/generated/uapi -mfentry -DCC_USING_FENTRY -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD   -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -fno-pie -Wall -Wundef -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Wno-packed-not-aligned
KBUILD_CFLAGS=-Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable  -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned
LINUXINCLUDE=-I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h
LDFLAGS=
KBUILD_LDFLAGS=-m elf_x86_64
ARCH=x86_64
  ln -sf /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-kernel-amd64.o_binary /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-kernel.o
  ln -sf /var/lib/dkms/nvidia-current/470.57.02/build/nvidia-modeset/nv-modeset-kernel-amd64.o_binary /var/lib/dkms/nvidia-current/470.57.02/build/nvidia-modeset/nv-modeset-kernel.o
 CONFTEST macros.h:
 CONFTEST patches.h:
static struct {
                const char *short_description;
                const char *description;
              } __nv_patches[] = {
{ NULL, NULL } };
 CONFTEST headers.h:
#undef NV_ASM_SYSTEM_H_PRESENT
#undef NV_DRM_DRMP_H_PRESENT
#define NV_DRM_DRM_AUTH_H_PRESENT
#define NV_DRM_DRM_GEM_H_PRESENT
#define NV_DRM_DRM_CRTC_H_PRESENT
#define NV_DRM_DRM_ATOMIC_H_PRESENT
#define NV_DRM_DRM_ATOMIC_HELPER_H_PRESENT
#define NV_DRM_DRM_ENCODER_H_PRESENT
#define NV_DRM_DRM_ATOMIC_UAPI_H_PRESENT
#define NV_DRM_DRM_DRV_H_PRESENT
#define NV_DRM_DRM_FRAMEBUFFER_H_PRESENT
#define NV_DRM_DRM_CONNECTOR_H_PRESENT
#define NV_DRM_DRM_PROBE_HELPER_H_PRESENT
#define NV_DRM_DRM_BLEND_H_PRESENT
#define NV_DRM_DRM_FOURCC_H_PRESENT
#define NV_DRM_DRM_PRIME_H_PRESENT
#define NV_DRM_DRM_PLANE_H_PRESENT
#define NV_DRM_DRM_VBLANK_H_PRESENT
#define NV_DRM_DRM_FILE_H_PRESENT
#define NV_DRM_DRM_IOCTL_H_PRESENT
#define NV_DRM_DRM_DEVICE_H_PRESENT
#undef NV_DT_BINDINGS_INTERCONNECT_TEGRA_ICC_ID_H_PRESENT
#define NV_GENERATED_AUTOCONF_H_PRESENT
#define NV_GENERATED_COMPILE_H_PRESENT
#define NV_GENERATED_UTSRELEASE_H_PRESENT
#define NV_LINUX_EFI_H_PRESENT
#define NV_LINUX_KCONFIG_H_PRESENT
#undef NV_LINUX_PLATFORM_TEGRA_MC_UTILS_H_PRESENT
#define NV_LINUX_SEMAPHORE_H_PRESENT
#define NV_LINUX_PRINTK_H_PRESENT
#define NV_LINUX_RATELIMIT_H_PRESENT
#undef NV_LINUX_PRIO_TREE_H_PRESENT
#define NV_LINUX_LOG2_H_PRESENT
#define NV_LINUX_OF_H_PRESENT
#define NV_LINUX_BUG_H_PRESENT
#define NV_LINUX_SCHED_SIGNAL_H_PRESENT
#define NV_LINUX_SCHED_TASK_H_PRESENT
#define NV_LINUX_SCHED_TASK_STACK_H_PRESENT
#undef NV_XEN_IOEMU_H_PRESENT
#undef NV_LINUX_FENCE_H_PRESENT
#define NV_LINUX_DMA_RESV_H_PRESENT
#undef NV_SOC_TEGRA_CHIP_ID_H_PRESENT
#define NV_SOC_TEGRA_FUSE_H_PRESENT
#undef NV_SOC_TEGRA_TEGRA_BPMP_H_PRESENT
#undef NV_VIDEO_NV_INTERNAL_H_PRESENT
#undef NV_LINUX_PLATFORM_TEGRA_DCE_DCE_CLIENT_IPC_H_PRESENT
#undef NV_LINUX_NVHOST_H_PRESENT
#undef NV_LINUX_NVHOST_T194_H_PRESENT
#undef NV_ASM_BOOK3S_64_HASH_64K_H_PRESENT
#define NV_ASM_SET_MEMORY_H_PRESENT
#define NV_ASM_PROM_H_PRESENT
#undef NV_ASM_POWERNV_H_PRESENT
#define NV_LINUX_ATOMIC_H_PRESENT
#define NV_ASM_BARRIER_H_PRESENT
#undef NV_ASM_OPAL_API_H_PRESENT
#define NV_SOUND_HDAUDIO_H_PRESENT
#define NV_ASM_PGTABLE_TYPES_H_PRESENT
#define NV_LINUX_STRINGHASH_H_PRESENT
#define NV_LINUX_DMA_MAP_OPS_H_PRESENT
#undef NV_RDMA_PEER_MEM_H_PRESENT
#define NV_SOUND_HDA_CODEC_H_PRESENT
#define NV_LINUX_DMA_BUF_H_PRESENT
#define NV_LINUX_TIME_H_PRESENT
 CONFTEST: hash__remap_4k_pfn
 CONFTEST: set_pages_uc
 CONFTEST: list_is_first
 CONFTEST: set_memory_uc
 CONFTEST: set_memory_array_uc
 CONFTEST: set_pages_array_uc
 CONFTEST: acquire_console_sem
 CONFTEST: console_lock
 CONFTEST: ioremap_cache
 CONFTEST: ioremap_wc
 CONFTEST: acpi_walk_namespace
 CONFTEST: sg_alloc_table
 CONFTEST: pci_get_domain_bus_and_slot
 CONFTEST: get_num_physpages
 CONFTEST: pde_data
 CONFTEST: efi_enabled
 CONFTEST: proc_remove
 CONFTEST: xen_ioemu_inject_msi
 CONFTEST: pm_vt_switch_required
 CONFTEST: phys_to_dma
 CONFTEST: get_dma_ops
 CONFTEST: dma_attr_macros
 CONFTEST: dma_map_page_attrs
 CONFTEST: write_cr4
 CONFTEST: of_get_property
 CONFTEST: of_find_node_by_phandle
 CONFTEST: of_node_to_nid
 CONFTEST: pnv_pci_get_npu_dev
 CONFTEST: of_get_ibm_chip_id
 CONFTEST: node_end_pfn
 CONFTEST: pci_bus_address
 CONFTEST: pci_stop_and_remove_bus_device
 CONFTEST: pci_remove_bus_device
 CONFTEST: register_cpu_notifier
 CONFTEST: dma_map_resource
 CONFTEST: cpuhp_setup_state
 CONFTEST: backlight_device_register
 CONFTEST: get_backlight_device_by_name
 CONFTEST: timer_setup
 CONFTEST: pci_enable_msix_range
 CONFTEST: kernel_read_has_pointer_pos_arg
 CONFTEST: kernel_write
 CONFTEST: kthread_create_on_node
 CONFTEST: of_find_matching_node
 CONFTEST: dev_is_pci
 CONFTEST: dma_direct_map_resource
 CONFTEST: tegra_get_platform
 CONFTEST: tegra_bpmp_send_receive
 CONFTEST: flush_cache_all
 CONFTEST: vmf_insert_pfn
 CONFTEST: jiffies_to_timespec
 CONFTEST: ktime_get_raw_ts64
 CONFTEST: ktime_get_real_ts64
 CONFTEST: full_name_hash
 CONFTEST: hlist_for_each_entry
 CONFTEST: pci_enable_atomic_ops_to_root
 CONFTEST: vga_tryget
 CONFTEST: pgprot_decrypted
 CONFTEST: iterate_fd
 CONFTEST: seq_read_iter
 CONFTEST: sg_page_iter_page
 CONFTEST: unsafe_follow_pfn
 CONFTEST: drm_gem_object_get
 CONFTEST: drm_gem_object_put_unlocked
 CONFTEST: set_close_on_exec
 CONFTEST: address_space_init_once
 CONFTEST: kbasename
 CONFTEST: vzalloc
 CONFTEST: wait_on_bit_lock_argument_count
 CONFTEST: bitmap_clear
 CONFTEST: usleep_range
 CONFTEST: radix_tree_empty
 CONFTEST: radix_tree_replace_slot
 CONFTEST: pnv_npu2_init_context
 CONFTEST: cpumask_of_node
 CONFTEST: drm_dev_unref
 CONFTEST: drm_reinit_primary_mode_group
 CONFTEST: get_user_pages_remote
 CONFTEST: drm_gem_object_lookup
 CONFTEST: drm_atomic_state_ref_counting
 CONFTEST: drm_driver_has_gem_prime_res_obj
 CONFTEST: drm_atomic_helper_connector_dpms
 CONFTEST: drm_connector_funcs_have_mode_in_name
 CONFTEST: drm_framebuffer_get
 CONFTEST: drm_dev_put
 CONFTEST: drm_format_num_planes
 CONFTEST: drm_connector_for_each_possible_encoder
 CONFTEST: drm_rotation_available
 CONFTEST: drm_vma_offset_exact_lookup_locked
 CONFTEST: is_export_symbol_gpl_of_node_to_nid
 CONFTEST: is_export_symbol_gpl_sme_active
 CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
 CONFTEST: is_export_symbol_present_swiotlb_dma_ops
 CONFTEST: is_export_symbol_present___close_fd
 CONFTEST: is_export_symbol_present_close_fd
 CONFTEST: is_export_symbol_present_get_unused_fd
 CONFTEST: is_export_symbol_present_get_unused_fd_flags
 CONFTEST: is_export_symbol_present_nvhost_get_default_device
 CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
 CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
 CONFTEST: is_export_symbol_present_tegra_dce_register_ipc_client
 CONFTEST: is_export_symbol_present_tegra_dce_unregister_ipc_client
 CONFTEST: is_export_symbol_present_tegra_dce_client_ipc_send_recv
 CONFTEST: is_export_symbol_present_dram_clk_to_mc_clk
 CONFTEST: is_export_symbol_present_get_dram_num_channels
 CONFTEST: is_export_symbol_present_tegra_dram_types
 CONFTEST: is_export_symbol_present_kthread_create_on_node
 CONFTEST: acpi_op_remove
 CONFTEST: file_operations
 CONFTEST: file_inode
 CONFTEST: kuid_t
 CONFTEST: dma_ops
 CONFTEST: swiotlb_dma_ops
 CONFTEST: noncoherent_swiotlb_dma_ops
 CONFTEST: vm_fault_has_address
 CONFTEST: backlight_properties_type
 CONFTEST: vm_insert_pfn_prot
 CONFTEST: vmf_insert_pfn_prot
 CONFTEST: vm_ops_fault_removed_vma_arg
 CONFTEST: vmbus_channel_has_ringbuffer_page
 CONFTEST: device_driver_of_match_table
 CONFTEST: device_of_node
 CONFTEST: node_states_n_memory
 CONFTEST: kmem_cache_has_kobj_remove_work
 CONFTEST: sysfs_slab_unlink
 CONFTEST: proc_ops
 CONFTEST: timespec64
 CONFTEST: vmalloc_has_pgprot_t_arg
 CONFTEST: acpi_fadt_low_power_s0
 CONFTEST: mm_has_mmap_lock
 CONFTEST: pci_channel_state
 CONFTEST: backing_dev_info
 CONFTEST: mm_context_t
 CONFTEST: vm_fault_t
 CONFTEST: mmu_notifier_ops_invalidate_range
 CONFTEST: drm_bus_present
 CONFTEST: drm_bus_has_bus_type
 CONFTEST: drm_bus_has_get_irq
 CONFTEST: drm_bus_has_get_name
 CONFTEST: drm_driver_has_device_list
 CONFTEST: drm_driver_has_legacy_dev_list
 CONFTEST: drm_driver_has_set_busid
 CONFTEST: drm_crtc_state_has_connectors_changed
 CONFTEST: drm_init_function_args
 CONFTEST: drm_helper_mode_fill_fb_struct
 CONFTEST: drm_master_drop_has_from_release_arg
 CONFTEST: drm_driver_unload_has_int_return_type
 CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
 CONFTEST: drm_atomic_helper_plane_destroy_state_has_plane_arg
 CONFTEST: drm_mode_object_find_has_file_priv_arg
 CONFTEST: dma_buf_owner
 CONFTEST: drm_connector_list_iter
 CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
 CONFTEST: drm_driver_prime_flag_present
 CONFTEST: drm_gem_object_has_resv
 CONFTEST: drm_crtc_state_has_async_flip
 CONFTEST: drm_crtc_state_has_pageflip_flags
 CONFTEST: drm_format_modifiers_present
 CONFTEST: drm_vma_node_is_allowed_has_tag_arg
 CONFTEST: drm_vma_offset_node_has_readonly
 CONFTEST: drm_display_mode_has_vrefresh
 CONFTEST: drm_driver_master_set_has_int_return_type
 CONFTEST: drm_driver_has_gem_free_object
 CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
 CONFTEST: drm_driver_has_gem_prime_callbacks
 CONFTEST: drm_crtc_atomic_check_has_atomic_state_arg
 CONFTEST: drm_gem_object_vmap_has_map_arg
 CONFTEST: drm_plane_atomic_check_has_atomic_state_arg
 CONFTEST: dom0_kernel_present
 CONFTEST: nvidia_vgpu_kvm_build
 CONFTEST: nvidia_grid_build
 CONFTEST: nvidia_grid_csp_build
 CONFTEST: pm_runtime_available
 CONFTEST: pci_class_multimedia_hd_audio
 CONFTEST: drm_available
 CONFTEST: drm_atomic_available
 CONFTEST: is_export_symbol_gpl_refcount_inc
 CONFTEST: drm_alpha_blending_available
 CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
 CONFTEST: ib_peer_memory_symbols
 CONFTEST functions.h:
#undef NV_HASH__REMAP_4K_PFN_PRESENT
#define NV_SET_PAGES_UC_PRESENT
#define NV_LIST_IS_FIRST_PRESENT
#define NV_SET_MEMORY_UC_PRESENT
#undef NV_SET_MEMORY_ARRAY_UC_PRESENT
#define NV_SET_PAGES_ARRAY_UC_PRESENT
#undef NV_ACQUIRE_CONSOLE_SEM_PRESENT
#define NV_CONSOLE_LOCK_PRESENT
#define NV_IOREMAP_CACHE_PRESENT
#define NV_IOREMAP_WC_PRESENT
#define NV_ACPI_WALK_NAMESPACE_PRESENT
#define NV_ACPI_WALK_NAMESPACE_ARGUMENT_COUNT 7
#define NV_SG_ALLOC_TABLE_FROM_PAGES_PRESENT
#define NV_PCI_GET_DOMAIN_BUS_AND_SLOT_PRESENT
#define NV_GET_NUM_PHYSPAGES_PRESENT
#define NV_EFI_ENABLED_PRESENT
#define NV_EFI_ENABLED_ARGUMENT_COUNT 1
#define NV_PDE_DATA_PRESENT
#define NV_PROC_REMOVE_PRESENT
#define NV_PM_VT_SWITCH_REQUIRED_PRESENT
#undef NV_XEN_IOEMU_INJECT_MSI
#undef NV_PHYS_TO_DMA_PRESENT
#define NV_GET_DMA_OPS_PRESENT
#define NV_DMA_ATTR_SKIP_CPU_SYNC_PRESENT
#define NV_DMA_MAP_PAGE_ATTRS_PRESENT
#undef NV_WRITE_CR4_PRESENT
#define NV_LINUX_OF_H_USABLE
#define NV_OF_GET_PROPERTY_PRESENT
#define NV_OF_FIND_NODE_BY_PHANDLE_PRESENT
#define NV_OF_NODE_TO_NID_PRESENT
#undef NV_PNV_PCI_GET_NPU_DEV_PRESENT
#undef NV_OF_GET_IBM_CHIP_ID_PRESENT
#define NV_NODE_END_PFN_PRESENT
#define NV_PCI_BUS_ADDRESS_PRESENT
#define NV_PCI_STOP_AND_REMOVE_BUS_DEVICE_PRESENT
#undef NV_PCI_REMOVE_BUS_DEVICE_PRESENT
#undef NV_REGISTER_CPU_NOTIFIER_PRESENT
#define NV_CPUHP_SETUP_STATE_PRESENT
#define NV_DMA_MAP_RESOURCE_PRESENT
#define NV_BACKLIGHT_DEVICE_REGISTER_PRESENT
#undef NV_GET_BACKLIGHT_DEVICE_BY_NAME_PRESENT
#define NV_TIMER_SETUP_PRESENT
#define NV_PCI_ENABLE_MSIX_RANGE_PRESENT
#define NV_KERNEL_READ_HAS_POINTER_POS_ARG
#define NV_KERNEL_WRITE_PRESENT
#define NV_KERNEL_WRITE_HAS_POINTER_POS_ARG
#define NV_KTHREAD_CREATE_ON_NODE_PRESENT
#define NV_OF_FIND_MATCHING_NODE_PRESENT
#define NV_DEV_IS_PCI_PRESENT
#undef NV_DMA_IS_DIRECT_PRESENT
#define NV_TEGRA_GET_PLATFORM_PRESENT
#undef NV_TEGRA_BPMP_SEND_RECEIVE
#define NV_FLUSH_CACHE_ALL_PRESENT
#define NV_VMF_INSERT_PFN_PRESENT
#undef NV_JIFFIES_TO_TIMESPEC_PRESENT
#define NV_KTIME_GET_RAW_TS64_PRESENT
#define NV_KTIME_GET_REAL_TS64_PRESENT
#define NV_FULL_NAME_HASH_ARGUMENT_COUNT 3
#define NV_HLIST_FOR_EACH_ENTRY_ARGUMENT_COUNT 3
#define NV_PCI_ENABLE_ATOMIC_OPS_TO_ROOT_PRESENT
#undef NV_VGA_TRYGET_PRESENT
#define NV_PGPROT_DECRYPTED_PRESENT
#define NV_ITERATE_FD_PRESENT
#define NV_SEQ_READ_ITER_PRESENT
#define NV_SG_PAGE_ITER_PAGE_PRESENT
#undef NV_UNSAFE_FOLLOW_PFN_PRESENT
#define NV_DRM_GEM_OBJECT_GET_PRESENT
#undef NV_DRM_GEM_OBJECT_PUT_UNLOCK_PRESENT
#undef NV_SET_CLOSE_ON_EXEC_PRESENT
#define NV_ADDRESS_SPACE_INIT_ONCE_PRESENT
#define NV_KBASENAME_PRESENT
#define NV_VZALLOC_PRESENT
#define NV_WAIT_ON_BIT_LOCK_ARGUMENT_COUNT 3
#define NV_BITMAP_CLEAR_PRESENT
#define NV_USLEEP_RANGE_PRESENT
#define NV_RADIX_TREE_EMPTY_PRESENT
#define NV_RADIX_TREE_REPLACE_SLOT_PRESENT
#define NV_RADIX_TREE_REPLACE_SLOT_ARGUMENT_COUNT 3
#undef NV_PNV_NPU2_INIT_CONTEXT_PRESENT
#undef NV_PNV_NPU2_INIT_CONTEXT_CALLBACK_RETURNS_VOID
#define NV_CPUMASK_OF_NODE_PRESENT
#undef NV_DRM_DEV_UNREF_PRESENT
#undef NV_DRM_REINIT_PRIMARY_MODE_GROUP_PRESENT
#define NV_GET_USER_PAGES_REMOTE_PRESENT
#undef NV_GET_USER_PAGES_REMOTE_HAS_WRITE_AND_FORCE_ARGS
#undef NV_GET_USER_PAGES_REMOTE_HAS_TSK_ARG
#define NV_GET_USER_PAGES_REMOTE_HAS_LOCKED_ARG
#undef NV_GET_USER_PAGES_HAS_WRITE_AND_FORCE_ARGS
#undef NV_GET_USER_PAGES_HAS_TASK_STRUCT
#define NV_DRM_GEM_OBJECT_LOOKUP_ARGUMENT_COUNT 2
#define NV_DRM_ATOMIC_STATE_REF_COUNTING_PRESENT
#undef NV_DRM_DRIVER_HAS_GEM_PRIME_RES_OBJ
#undef NV_DRM_ATOMIC_HELPER_CONNECTOR_DPMS_PRESENT
#undef NV_DRM_CONNECTOR_FUNCS_HAVE_MODE_IN_NAME
#define NV_DRM_FRAMEBUFFER_GET_PRESENT
#define NV_DRM_DEV_PUT_PRESENT
#undef NV_DRM_FORMAT_NUM_PLANES_PRESENT
#define NV_DRM_CONNECTOR_FOR_EACH_POSSIBLE_ENCODER_ARGUMENT_COUNT 2
#define NV_DRM_ROTATION_AVAILABLE
#define NV_DRM_VMA_OFFSET_EXACT_LOOKUP_LOCKED_PRESENT
 CONFTEST symbols.h:
#define NV_IS_EXPORT_SYMBOL_GPL_of_node_to_nid 0
#define NV_IS_EXPORT_SYMBOL_GPL_sme_active 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_swiotlb_map_sg_attrs 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_swiotlb_dma_ops 0
#define NV_IS_EXPORT_SYMBOL_PRESENT___close_fd 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_close_fd 1
#define NV_IS_EXPORT_SYMBOL_PRESENT_get_unused_fd 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_get_unused_fd_flags 1
#define NV_IS_EXPORT_SYMBOL_PRESENT_nvhost_get_default_device 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_nvhost_syncpt_unit_interface_get_byte_offset 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_nvhost_syncpt_unit_interface_get_aperture 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_tegra_dce_register_ipc_client 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_tegra_dce_unregister_ipc_client 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_tegra_dce_client_ipc_send_recv 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_dram_clk_to_mc_clk 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_get_dram_num_channels 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_tegra_dram_types 0
#define NV_IS_EXPORT_SYMBOL_PRESENT_kthread_create_on_node 1
 CONFTEST types.h:
#define NV_ACPI_DEVICE_OPS_REMOVE_ARGUMENT_COUNT 1
#undef NV_FILE_OPERATIONS_HAS_IOCTL
#define NV_FILE_HAS_INODE
#define NV_KUID_T_PRESENT
#undef NV_DMA_OPS_PRESENT
#undef NV_SWIOTLB_DMA_OPS_PRESENT
#undef NV_NONCOHERENT_SWIOTLB_DMA_OPS_PRESENT
#define NV_VM_FAULT_HAS_ADDRESS
#define NV_BACKLIGHT_PROPERTIES_TYPE_PRESENT
#undef NV_VM_INSERT_PFN_PROT_PRESENT
#define NV_VMF_INSERT_PFN_PROT_PRESENT
#define NV_VM_OPS_FAULT_REMOVED_VMA_ARG
#define NV_VMBUS_CHANNEL_HAS_RING_BUFFER_PAGE
#define NV_DEVICE_DRIVER_OF_MATCH_TABLE_PRESENT
#define NV_DEVICE_OF_NODE_PRESENT
#define NV_NODE_STATES_N_MEMORY_PRESENT
#undef NV_KMEM_CACHE_HAS_KOBJ_REMOVE_WORK
#undef NV_SYSFS_SLAB_UNLINK_PRESENT
#define NV_PROC_OPS_PRESENT
#define NV_TIMESPEC64_PRESENT
#undef NV_VMALLOC_HAS_PGPROT_T_ARG
#define NV_ACPI_FADT_LOW_POWER_S0_FLAG_PRESENT
#define NV_MM_HAS_MMAP_LOCK
#undef NV_PCI_CHANNEL_STATE_PRESENT
#undef NV_ADDRESS_SPACE_HAS_RWLOCK_TREE_LOCK
#undef NV_ADDRESS_SPACE_HAS_BACKING_DEV_INFO
#undef NV_MM_CONTEXT_T_HAS_ID
#define NV_VM_FAULT_T_IS_PRESENT
#define NV_MMU_NOTIFIER_OPS_HAS_INVALIDATE_RANGE
#undef NV_DRM_BUS_PRESENT
#undef NV_DRM_BUS_HAS_BUS_TYPE
#undef NV_DRM_BUS_HAS_GET_IRQ
#undef NV_DRM_BUS_HAS_GET_NAME
#undef NV_DRM_DRIVER_HAS_DEVICE_LIST
#undef NV_DRM_DRIVER_HAS_LEGACY_DEV_LIST
#undef NV_DRM_DRIVER_HAS_SET_BUSID
#define NV_DRM_CRTC_STATE_HAS_CONNECTORS_CHANGED
#define NV_DRM_CRTC_INIT_WITH_PLANES_HAS_NAME_ARG
#define NV_DRM_ENCODER_INIT_HAS_NAME_ARG
#define NV_DRM_UNIVERSAL_PLANE_INIT_HAS_FORMAT_MODIFIERS_ARG
#define NV_DRM_UNIVERSAL_PLANE_INIT_HAS_NAME_ARG
#define NV_DRM_HELPER_MODE_FILL_FB_STRUCT_HAS_DEV_ARG
#define NV_DRM_HELPER_MODE_FILL_FB_STRUCT_HAS_CONST_MODE_CMD_ARG
#undef NV_DRM_MASTER_DROP_HAS_FROM_RELEASE_ARG
#undef NV_DRM_DRIVER_UNLOAD_HAS_INT_RETURN_TYPE
#undef NV_DRM_ATOMIC_HELPER_CRTC_DESTROY_STATE_HAS_CRTC_ARG
#undef NV_DRM_ATOMIC_HELPER_PLANE_DESTROY_STATE_HAS_PLANE_ARG
#define NV_DRM_MODE_OBJECT_FIND_HAS_FILE_PRIV_ARG
#define NV_DMA_BUF_OWNER_PRESENT
#define NV_DRM_CONNECTOR_LIST_ITER_PRESENT
#define NV_DRM_CONNECTOR_LIST_ITER_BEGIN_PRESENT
#define NV_DRM_ATOMIC_HELPER_SWAP_STATE_HAS_STALL_ARG
#define NV_DRM_ATOMIC_HELPER_SWAP_STATE_RETURN_INT
#undef NV_DRM_DRIVER_PRIME_FLAG_PRESENT
#define NV_DRM_GEM_OBJECT_HAS_RESV
#define NV_DRM_CRTC_STATE_HAS_ASYNC_FLIP
#undef NV_DRM_CRTC_STATE_HAS_PAGEFLIP_FLAGS
#define NV_DRM_FORMAT_MODIFIERS_PRESENT
#define NV_DRM_VMA_NODE_IS_ALLOWED_HAS_TAG_ARG
#undef NV_DRM_VMA_OFFSET_NODE_HAS_READONLY
#undef NV_DRM_DISPLAY_MODE_HAS_VREFRESH
#undef NV_DRM_DRIVER_SET_MASTER_HAS_INT_RETURN_TYPE
#undef NV_DRM_DRIVER_HAS_GEM_FREE_OBJECT
#define NV_DRM_PRIME_PAGES_TO_SG_HAS_DRM_DEVICE_ARG
#undef NV_DRM_DRIVER_HAS_GEM_PRIME_CALLBACKS
#define NV_DRM_CRTC_ATOMIC_CHECK_HAS_ATOMIC_STATE_ARG
#define NV_DRM_GEM_OBJECT_VMAP_HAS_MAP_ARG
#define NV_DRM_PLANE_ATOMIC_CHECK_HAS_ATOMIC_STATE_ARG
 CONFTEST generic.h:
#undef NV_DOM0_KERNEL_PRESENT
#undef NV_VGPU_KVM_BUILD
#undef NV_GRID_BUILD
#undef NV_GRID_BUILD_CSP
#define NV_PM_RUNTIME_AVAILABLE
#define NV_PCI_CLASS_MULTIMEDIA_HD_AUDIO_PRESENT
#define NV_DRM_AVAILABLE
#define NV_DRM_ATOMIC_MODESET_AVAILABLE
#define NV_IS_EXPORT_SYMBOL_GPL_refcount_inc 0
#define NV_IS_EXPORT_SYMBOL_GPL_refcount_dec_and_test 0
#define NV_DRM_ALPHA_BLENDING_AVAILABLE
#undef NV_MLNX_IB_PEER_MEM_SYMBOLS_PRESENT
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-pci.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_pci"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-pci.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-pci.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-acpi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_acpi"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-acpi.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-acpi.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-cray.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_cray"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-cray.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-cray.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-dma.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_dma"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-dma.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-dma.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-i2c.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_i2c"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-i2c.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-i2c.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-mmap.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_mmap"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-mmap.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-mmap.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-p2p.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_p2p"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-p2p.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-p2p.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-pat.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_pat"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-pat.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-pat.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-procfs.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_procfs"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-procfs.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-procfs.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-procfs-utils.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_procfs_utils"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-procfs-utils.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-procfs-utils.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-usermap.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_usermap"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-usermap.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-usermap.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-vm.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_vm"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-vm.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-vm.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-vtophys.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_vtophys"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-vtophys.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-vtophys.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.os-interface.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"os_interface"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-interface.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-interface.c
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.os-mlock.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"os_mlock"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-mlock.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-mlock.c
   ./tools/objtool/objtool orc generate  --module  --no-fp   --retpoline  --uaccess  /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-procfs-utils.o
In file included from /var/lib/dkms/nvidia-current/470.57.02/build/common/inc/nv-linux.h:25,
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv.c:13:
/var/lib/dkms/nvidia-current/470.57.02/build/common/inc/nv-time.h: In function ‘nv_sleep_ms’:
/var/lib/dkms/nvidia-current/470.57.02/build/common/inc/nv-time.h:217:18: error: ‘struct task_struct’ has no member named ‘state’; did you mean ‘__state’?
  217 |         current->state = TASK_INTERRUPTIBLE;
      |                  __state
  if objdump -h /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-procfs-utils.o | grep -q __ksymtab; then  gcc-10 -E -D__GENKSYMS__ -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.nv-procfs-utils.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"nv_procfs_utils"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-procfs-utils.c | scripts/genksyms/genksyms    -r /dev/null > /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.tmp_nv-procfs-utils.ver; ld -m elf_x86_64 -r -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.tmp_nv-procfs-utils.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-procfs-utils.o -T /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.tmp_nv-procfs-utils.ver; mv -f /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.tmp_nv-procfs-utils.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-procfs-utils.o; rm -f /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.tmp_nv-procfs-utils.ver; fi
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-cray.c:14:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-acpi.c:14:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-mmap.c:14:
      |                  __state
   gcc-10 -Wp,-MMD,/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/.os-pci.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/10/include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include -I./arch/x86/include/generated -I/usr/src/linux-headers-5.14.0-1-common/include -I./include -I/usr/src/linux-headers-5.14.0-1-common/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/usr/src/linux-headers-5.14.0-1-common/include/uapi -I./include/generated/uapi -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler-version.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/kconfig.h -include /usr/src/linux-headers-5.14.0-1-common/include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=/usr/src/linux-headers-5.14.0-1-common/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -I/var/lib/dkms/nvidia-current/470.57.02/build/common/inc -I/var/lib/dkms/nvidia-current/470.57.02/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"470.57.02\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -DNV_KERNEL_INTERFACE_LAYER -I/var/lib/dkms/nvidia-current/470.57.02/build/nvidia -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -DKBUILD_BASENAME='"os_pci"' -DKBUILD_MODNAME='"nvidia"' -D__KBUILD_MODNAME=kmod_nvidia -c -o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-pci.o /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-pci.c
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-dma.c:14:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-pat.c:14:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-procfs.c:14:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-usermap.c:14:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/common/inc/nv-pci.h:15,
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-pci.c:13:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-p2p.c:14:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-vtophys.c:14:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-vm.c:13:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-mlock.c:14:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-interface.c:14:
      |                  __state
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-i2c.c:16:
      |                  __state
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-cray.o] Error 1
make[3]: *** Waiting for unfinished jobs....
/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-mmap.c: In function ‘nv_encode_caching’:
/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-mmap.c:321:16: warning: this statement may fall through [-Wimplicit-fallthrough=]
  321 |             if (NV_ALLOW_CACHING(memory_type))
/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-mmap.c:324:9: note: here
  324 |         default:
/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-dma.c: At top level:
/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-dma.c:963: warning: "IMPORT_SGT_STUBS_NEEDED" redefined
  963 | #define IMPORT_SGT_STUBS_NEEDED 0
/var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-dma.c:957: note: this is the location of the previous definition
  957 | #define IMPORT_SGT_STUBS_NEEDED 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-pci.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-i2c.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-acpi.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-mmap.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-pat.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-usermap.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-dma.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-vtophys.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-procfs.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-p2p.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv-vm.o] Error 1
                 from /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-pci.c:14:
      |                  __state
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/nv.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-mlock.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-interface.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.14.0-1-common/scripts/Makefile.build:276: /var/lib/dkms/nvidia-current/470.57.02/build/nvidia/os-pci.o] Error 1
make[2]: *** [/usr/src/linux-headers-5.14.0-1-common/Makefile:1882: /var/lib/dkms/nvidia-current/470.57.02/build] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-5.14.0-1-amd64'
make[1]: *** [Makefile:232: __sub-make] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.14.0-1-common'
make: *** [Makefile:80: modules] Error 2
Thanks, good to know, please be advised I could get the drivers built and the kernel 5.14 up and running by applying the following changes to the code. However, it’s more of a quick & dirty workaround than a real fix, and it’s not reviewed by Nvidia.
--- nvidia-drm/nvidia-drm-drv.c	2021-07-13 18:05:33.000000000 +0200
+++ nvidia-drm/nvidia-drm-drv.fixed.c	2021-09-28 18:38:38.637969968 +0200
@@ -61,6 +61,7 @@
 #endif
 #include <linux/pci.h>
+#include <linux/version.h>
  * Commit fcd70cd36b9b ("drm: Split out drm_probe_helper.h")
@@ -922,7 +923,9 @@
     dev->dev_private = nv_dev;
     nv_dev->dev = dev;
     if (device->bus == &pci_bus_type) {
+#if LINUX_VERSION_CODE < KERNEL_VERSION(5,14,0)
         dev->pdev = to_pci_dev(device);
+#endif
     /* Register DRM device to DRM sub-system */
And also
--- common/inc/nv-time.h	2021-07-13 18:36:47.000000000 +0200
+++ common/inc/nv-time.fixed.h	2021-09-28 18:39:01.342124467 +0200
@@ -28,6 +28,7 @@
 #include <linux/delay.h>
 #include <linux/interrupt.h>
 #include <linux/ktime.h>
 #include <nvstatus.h>
@@ -214,7 +215,11 @@
         // the requested timeout has expired, loop until less
         // than a jiffie of the desired delay remains.
+#else
+        current->__state = TASK_INTERRUPTIBLE;
+#endif
         do
             schedule_timeout(jiffies);
The change of state to __state is also a change of type, that can be observed in struct task_struct definition in files /usr/src/linux-headers-5.10.0-8-common/include/linux/sched.h and /usr/src/linux-headers-5.14.0-1-common/include/linux/sched.h so there possibly might be other implications.
Cheers for the straight diff. The second patch seems not reasonable, with your noted caveats. I’m not overly keen on messing in the DRM code, particularly ifdef device stuff out but yeah totally get why you’ve done it just to get the thing built heh.
Exactly, so far, so good, no kernel crash, nvidia_drm driver is loaded, no weird log messages and videos run properly:
$ uname -msr
Linux 5.14.0-1-amd64 x86_64
$ lsmod |grep nvidia
nvidia_drm             69632  8
nvidia_modeset       1200128  5 nvidia_drm
nvidia              35315712  282 nvidia_modeset
drm_kms_helper        307200  2 nvidia_drm,i915
drm                   634880  19 drm_kms_helper,nvidia,nvidia_drm,i915,ttm
$ nvidia-smi
Tue Sep 28 23:35:22 2021
| NVIDIA-SMI 470.57.02    Driver Version: 470.57.02    CUDA Version: 11.4     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   45C    P8     7W /  N/A |     89MiB /  5944MiB |      9%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A       982      G   /usr/lib/xorg/Xorg                 83MiB |
|    0   N/A  N/A     61717      G   vlc                                 4MiB |
But I’m on a laptop and Nvidia is my second GPU, so I’m not sure how much of DRM-related code is effective.
fwiw, seems the ‘fix’ is in debian sid for now.
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=994860
Nice, but they mention the fix being included in nvidia-graphics-drivers-tesla-470 and nvidia-graphics-drivers which are not installed on my PC (and that I cannot even find them in repositories whereas I use unstable for source packages). There is an nvidia-tesla-470-driver though, but not used by me. On my side, it’s only in nvidia-kernel-dkms package:
$ dpkg -S /usr/src/nvidia-current-470.57.02/nvidia-drm/nvidia-drm-drv.c
nvidia-kernel-dkms: /usr/src/nvidia-current-470.57.02/nvidia-drm/nvidia-drm-drv.c
