I am looking for some benchmarks/guidance on the A2 and A10 GPUs for H.264 encoding.
I need to spec a GPU (or a pair of GPUs - not more than 2) that can handle inline encoding of fourteen1080P video streams. I receive either 10-bit1080i60 or 10-bit1080P30 over SDI, then H.264 encode it.
From this T4 benchmark: https://developer.nvidia.com/blog/turing-h264-video-encoding-speed-and-quality/
Two T4s should be adequate to provide some head room, but would prefer an ampere card to get the PCIe 4 bandwidth.
The A2 does not seem like a direct replacement of the T4 with much lower specs and am skeptical it has the same capacity as the T4.
The A10 roughly seems to be about double the performance of the T4. With no benchmarks I would think I could achieve at least the same numbers as two T4s based on the benchmark I linked above. I don’t know if this is a valid conclusion or not.
Doing an evaluation with Nvidia is not an option. This application requires many PCI slots and the line of servers that I use do not have a relevant Nvidia certification for any model with an adequate number of PCI slots for any relevant model of GPU, and very few certifications at all for anything smaller than an A30.
Does anyone have any comments on the performance of these two cards in this application?
