Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Unable to setup Nvidia Drive AGX Orin Developer kit, unable to accept EULA terms and conditions to setup username and password for the dev kit. I have attached all the serial logs below.
Error String
Logs
teraterm-com24-log.txt (38.3 KB)
teraterm-Com23-log.txt (6.6 KB)
Please paste the complete application log here. If there are multiple logs, please use multiple text box
*************** NvShell Initialization Start******************
DRIVE-V6.0.4-P3710-AFW-Aurix-StepB-5.05.03
Compilation date: Jul 16 2022, 01:07:14
Enter ‘help’ to see the available commands.
*************** NvShell Initialized *************************
Press ‘Enter’ for NvShell prompt
MCU_FOH: E2E Initialized
MCU_FOH: Initialization done
INFO: MCU_PLTFPWRMGR: Power-on Triggered…
MCU_FOH: SOC error pin is asserted
INFO: NvMCU_OrinTMON: Toggle check of Alert and Therm pins for local sensor successfull
ERROR: NVMCU_ORINPWRCTRL: FUNC_NIRQ Toggle check has failed
INFO: NvMCU_OrinTMON: Toggle check of Alert and Therm pins for remote sensor successfull
INFO: NVMCU_ORINPWRCTRL: FUNC_NIRQ continuous monitoring Enabled…!
INFO: NvMCU_OrinTMON: Orin Temperature sensor initialized
ERROR: MCU_PLTFPWRMGR: Request VMON Power-up sequence verification failed …Continue sequence !
INFO: BtChn_Cfg: No valid next bootchain loaded
INFO: NVMCU_ORINPWRCTRL: Tegra x1 Boot Chain: A
INFO: SftyMon_tmon: Board Temperature sensor initialized
INFO: MCU_PLTFPWRMGR: Board TMON enabled …
INFO: MCU_PLTFPWRMGR: Orin TMON enabled …
INFO: Marvell Switch: p3710_oak_init
INFO: Marvell Switch: Device ID in the Spruce slave address 0x8 is not as expected
INFO: Marvell Switch: Expected 0xf130/0xf131/0xf132/0xf133, but reading back 0xa722
INFO: Marvell Switch: IfxEth_Marvell_Switch_write_reg: write the extend 16 bit data 0x3
INFO: Marvell Switch: IfxEth_Marvell_Switch_write_reg: write the extend 16 bit data 0x1
INFO: Marvell Switch: IfxEth_Marvell_Switch_write_reg: write the extend 16 bit data 0x0
INFO: Marvell Switch: Port restrictions for Aurix port(P8) enabled
INFO: Marvell Switch: p3710_spruce_init
INFO: Marvell Switch: Spruce device with chip revision B4 detected on SMI address 0x1.
INFO: MCU_PltfPwrMgr: Switch Init
INFO: MCU_PltfPwrMgr: Linkup status is not active
INFO: MCU_PltfPwrMgr: 88Q5072 OAK Link Active
INFO: Marvell Phy: Initial 88Q2112 config
INFO: Marvell Phy:
Start init 88Q222x slave address 1 at group 1
INFO: Marvell Phy: Apply Legacy mode
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 1 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 2 at group 1
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 2 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 3 at group 1
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 3 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 4 at group 1
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 4 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 5 at group 1
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 5 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 6 at group 1
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 6 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 7 at group 1
MCU_FOH: SOC error pin is de-asserted
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 7 at group 1, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 1 at group 0
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 1G, slave address 1 at group 0, API 1.10
INFO: Marvell Phy:
Start init 88Q222x slave address 2 at group 0
INFO: Marvell Phy: Initialed 88Q2112 A2 silicon 100M, slave address 2 at group 0, API 1.10
INFO: MCU_PltfPwrMgr: PHYs Init
INFO: MCU_PltfPwrMgr: StbM Init
INFO: MCU_PLTFPWRMGR: Power-up sequence is complete !
INFO: MCU_PLTFPWRMGR: DL Ready drive to HIGH !
ERROR: SftyMon_IoHwAbs: VRS11 PGOOD Failure notification…!
INFO: MCU_PLTFPWRMGR: VRS11 PG Monitoring enabled …
Power on the system
ERROR: MCU_ERRHANDLER: PGOOD failure notification…error detected by VRS11
MCU_FOH: MCU FOH : Power state notification for Orin Power On
INFO: MCU_SWC_FanControl: max_rpm fan1 : 0
INFO: MCU_SWC_FanControl: maxrpm of fan1 has more than 50 percent deviation against rated maxrpm
INFO: MCU_SWC_FanControl: max_rpm fan2 : 0
INFO: MCU_SWC_FanControl: maxrpm of fan2 has more than 50 percent deviation against rated maxrpm
MCU_FOH: Spi Transmit Started
MCU_FOH: ErrReport: ErrorCode-0x240008cb ReporterId-0x8001 Error_Attribute-0x0 Timestamp-0x5c648ea
MCU_FOH: ErrReport: ErrorCode-0x89abcdef ReporterId-0x8013 Error_Attribute-0x0 Timestamp-0x5c69152
MCU_FOH: ErrReport: ErrorCode-0x1012 ReporterId-0xe00e Error_Attribute-0x0 Timestamp-0x645298a
MCU_FOH: ErrReport: ErrorCode-0x20000007 ReporterId-0x8030 Error_Attribute-0x0 Timestamp-0x9b95ffa
MCU_FOH: ErrReport: ErrorCode-0x20000 ReporterId-0x8030 Error_Attribute-0x0 Timestamp-0x9b9f362
MCU_FOH: Periodic Report: KeyOfSeed-0xffff
MCU_FOH: Periodic Report[0]:SystemFailureId-0xabcd, MaturationState-0xef, Failure_Attribute-0x22
MCU_FOH: Periodic Report[9]:SystemFailureId-0x1234, MaturationState-0x56, Failure_Attribute-0xee
MCU_FOH: ErrReport: ErrorCode-0x100c ReporterId-0xe00e Error_Attribute-0x0 Timestamp-0x2278090a
MCU_FOH: ErrReport: ErrorCode-0x100c ReporterId-0x800e Error_Attribute-0x1002 Timestamp-0x22780dd2
