NVIDIA Drivers for deepstream with 3060TI
Hi @oriaj3, can you please check this post
and share the nvidia-bug-report.log.gz file here?
Some other comments:
  • Is the “purple screen” you mention the login screen? If you get into a gdm/X11 login loop your driver installation is broken and you should do a clean re-install
  • Do you have secure boot enabled? Then you MUST make sure you followed the signing/authentication process of Ubuntu in all details. Authentication after the fact is rather complex.
  • You list “Data Center 525.85.12” as your driver. That is definitely incorrect for a 3060Ti.
