Nvidia drivers for GTX1060ti doesn't install
So, I bought new notebook and I try second day install ubuntu drivers. If I do it with help “additional drivers” I can’t load ubuntu after this. Then I tried install it with help file, which I downloaded from offical site. Version of drivers is 430. When I run sh I get error about kernel module. But I found log file.
In file included from /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nvlink_linux.c:30:
/tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/common/inc/nv-linux.h:1593:6: error: “NV_BUILD_MODULE_INSTANCES” is not defined, evaluates to 0 [-Werror=undef]
1593 | #if (NV_BUILD_MODULE_INSTANCES != 0)
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:275: /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv.o] Error 1
make[2]: *** [scripts/Makefile.build:275: /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/os-interface.o] Error 1
In file included from /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-rsync.c:24:
In file included from /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv_uvm_interface.c:21:
make[2]: *** [scripts/Makefile.build:275: /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-msi.o] Error 1
make[2]: *** [scripts/Makefile.build:275: /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-rsync.o] Error 1
In file included from /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/linux_nvswitch.c:28:
make[2]: *** [scripts/Makefile.build:275: /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nvlink_linux.o] Error 1
make[2]: *** [scripts/Makefile.build:275: /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv_uvm_interface.o] Error 1
make[2]: *** [scripts/Makefile.build:275: /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/linux_nvswitch.o] Error 1
make[2]: Target ‘__build’ not remade because of errors.
make[1]: *** [Makefile:1719: /tmp/selfgz7275/NVIDIA-Linux-x86_64-430.09/kernel] Error 2
make[1]: Target ‘modules’ not remade because of errors.
make[1]: Leaving directory ‘/usr/src/linux-headers-5.4.0-39-generic’
make: *** [Makefile:79: modules] Error 2
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
