Hi
I am running the following lab set up:
2 x HPDL380 G9 hosts each with 1 x K1 GRID card
Horizon 7.0.2 Enterprise
vCenter 6.5 4602587
VMware ESXi 6.5.0 4564106 on each host (Enterprise Plus licenses on both)
I’ve installed the latest 4.1 GRID driver set - including the ESXi VIB (nvidia-smi reporting all ok on both hosts). I have created a K120Q and K160Q VGPU template Win7 x64 VM as per the Horizon 6.1 deployment guide however when I try to select the template I get the following message:
‘NVIDIA GRID VGPU support does not match desktop setting’
I can’t then proceed with the VGPU pool. I can create non-GRID enabled pools and desktops via this Horizon installation. I can connect to the base image used for the template using a View client and can verify that the correct profile shows in the Nvidia Control Panel.
This appears to me as a licensing issue? I’ve checked over the release notes and can see that ESXi 6.5 nor vCenter is not a validated platform for K1 support (runs up to ESXi 6.0u2 and vCenter 6.0) but Horizon 7.0.2 is validated. Is this simply a case of no validation for the later versions of hypervisor?
I’ve seen this question a couple of times, once on this forum but no answers. Has anyone any insight into this error?
Product Type = GRID
Product Series = NVIDIA GRID vGPU
Product = GRID K1
Operating System = VMware vSphere ESXi 6.5
You’ll need to change out the ESXi host driver and Windows driver to ensure compatibility.
Kepler based GPUs (K1 / K2) don’t require any licensing. They also do not come with any NVIDIA support. Maxwell GPUs (M6 / M60 / M10) do require licensing and you can purchase SUMS on top for NVIDIA support.
K1/K2 support is detailed in the release documentation for the 4.1 driver releases - i’d assumed that the VIB and Windows guest would work on both M and K GRID hardware.
I can try both of these suggestions and report back
Ok - downloaded the K1/K2 GRID drivers from the NVidia website - uninstalled the 4.1 VIB and installed the K1 VIB onto both ESXi hosts. Also, on the template I uninstalled the 4.1 Windows guest driver and installed the K1 Windows guest driver (which is actually the same file).
Tried to create the vGPU pool as before - no dice. Same error and the template was unavailable for selection
Updated both Horizon View Connection servers to 7.0.3 and tried to create the vGPU pool - success!
It’s likely that the existing config may have worked with just the update to 7.0.3 but I can leave that for another day.
