I have been trying some basic image and video tasks e.g. taking images/videos.
nvgstcapture-1.0 --camsrc=0 --cap-dev-node= /dev/video0
I’m following the article: First Picture USB and CSI Camera. When I try to capture an image, I can do it without any issue. But when I try to capture a video using
nvgstcapture-1.0 --mode=2 --camsrc=0 --cap-dev-node= /dev/video0
the command I get a segmentation fault error. Following is the info I’m getting.
Encoder null, cannot set bitrate!
Encoder Profile = High
/dev/video/dev/video0 does not exist
Runtime USB Camera Commands:
//Help Commands
bitrate = 4000000
Encoder control-rate = 1
Encoder EnableTwopassCBR = 0
Opening in BLOCKING MODE
Troubleshooting steps tried:
1. v4l2-ctl --list-devices
USB 2.0 Camera (usb-70090000.xusb-2.1):
/dev/video0
2. v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘YUYV’
Size: Discrete 3264x2448
Interval: Discrete 0.500s (2.000 fps)
Size: Discrete 2592x1944
Size: Discrete 2048x1536
Size: Discrete 1920x1080
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1600x1200
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.050s (20.000 fps)Index : 1
Pixel Format: ‘MJPG’ (compressed)
Interval: Discrete 0.033s (30.000 fps)
3. I’m also facing the same Segmentation Fault (Core dumped) issue with the raspberry pi v2 CSI camera module while testing it with Jetson Hacks Nano CSI-Camera. The stream starts but freezes almost immediately. So, can it be an issue with my Jetson Board/OpenCV installation?
