I’ve made a CAD file for a case for the Jetson Orin Nano Super Dev kit and, since it worked out well, I made a github repo for it and stored it there to share with others. It is 3d printable as well as cnc machinable.
The Jetson Orin Nano Super Dev kit is a developer kit that includes a non-production-specification Jetson Orin Nano module attached to a reference carrier board. The Jetson Orin Nano module is suitable for deployment in a production environment throughout its operating lifetime, but the developer kit itself is not intended for production use.
The Jetson Orin Nano carrier board supports all the Jetson Orin Nano Series and Jetson Orin NX Series modules. The Jetson Orin Nano Developer Kit carrier board design files are provided as a reference design, and both Jetson Orin Nano and Jetson Orin NX modules are compatible with this carrier board.
In your case, you have created a CAD file for a case for the Jetson Orin Nano Super Dev kit, which is a great contribution to the community. By making it 3D printable and CNC machinable, you have provided a versatile design that can be used by others.
Comparing your design to the reference carrier board design provided by NVIDIA, your design is likely to be more compact and optimized for a desktop case, whereas the reference design is more focused on providing a functional platform for development and testing.
The Jetson Orin Nano Super Dev kit is a powerful platform that can be used for a variety of applications, including AI, computer vision, and robotics. With your open-source case design, users can now create a custom enclosure that meets their specific needs and requirements.
In terms of compatibility, your design should be compatible with the Jetson Orin Nano module, as well as other modules in the Jetson Orin Nano Series and Jetson Orin NX Series. However, it’s always a good idea to double-check the specifications and dimensions of the module and carrier board to ensure a proper fit.
Overall, your contribution to the community is a great example of how open-source designs can be shared and used to benefit others. By providing a 3D printable and CNC machinable design, you have made it easy for others to create a custom case for their Jetson Orin Nano Super Dev kit.
Here are some key points to consider when using your design:
- Ensure that the design is compatible with the Jetson Orin Nano module and carrier board.
- Check the specifications and dimensions of the module and carrier board to ensure a proper fit.
- Use a suitable material for 3D printing or CNC machining, such as ABS or aluminum.
- Follow the instructions provided in the GitHub repository for assembling and using the case.
- Consider sharing your experience and feedback with the community to help improve the design.
By following these guidelines, users can create a custom case for their Jetson Orin Nano Super Dev kit using your open-source design.
Thank you so much @crussella0129 for graciously sharing your thoughtful design with the community! The variety of options for cooling and GPIO header access are great. We appreciate you posting it here for others to use.
