I would like to know if there is a box/case that allows me to install the Jetson Orin Nano.
The question about a box case for the Jetson Orin Nano is not directly addressed in the provided context. However, I can provide some general information and comparisons that might be helpful.
The Jetson Orin Nano is a system-on-module (SOM) designed for edge AI applications. It is a compact module that requires a carrier board to function. The Jetson Orin Nano Developer Kit, which includes the module and a reference carrier board, is available from NVIDIA.
If you’re looking for a box case or enclosure to house your Jetson Orin Nano, you’ll need to consider a few factors:
While there isn’t a specific box case mentioned in the provided context, you can explore third-party options that cater to the Jetson Orin Nano’s form factor and requirements. Some popular options include:
When selecting a box case for your Jetson Orin Nano, ensure that it meets your specific requirements and provides adequate cooling, ventilation, and connectivity. You may also want to consider factors like durability, aesthetics, and cost when making your decision.
In comparison to other Jetson modules, the Jetson Orin Nano has a similar form factor to the Jetson Xavier NX, but it’s slightly smaller. The Jetson AGX Orin, on the other hand, has a larger form factor due to its more powerful processing capabilities. When selecting a case, ensure that it’s compatible with the specific Jetson module you’re using.
In summary, while there isn’t a specific box case mentioned in the provided context, you can explore various options from NVIDIA and third-party manufacturers that cater to the Jetson Orin Nano’s form factor and requirements. Be sure to consider factors like cooling, ventilation, and connectivity when selecting a case for your application.
Hello @f.capitanio,
There are many cases you can get from vendors like Amazon for example:
But I guess it all will depend on your use-case.
Any specific requirements you might be looking for?
best regards,
Andrew
