NVIDIA Jetson Orin™ Nano Super Developer Kit not powering up
Hi, we recently bought the Jetson Nano super dev kit from SparkFun. Everything worked fine initially, but it suddenly stopped working. The power LED is also not showing up. The power supply and SD card are fine. What could be the issue?
(we were using GPIO pins for actuator control)
Not possible to know what is the cause.
You could learn to dump log from serial console to do analysis. The log will be shown on another host PC…
