Jetso Orin Nano super stopped working
Hi , I have a Jetson Orin Nano Super developer kit. It was working exactly fine a while ago but then it suddenly stopped working. It made an update while closing then never turned on again. Now when I plug it in LED doesn’t turn on. I am sure the power supplier is working fine.
Based on the provided context, I’ll try to help you troubleshoot the issue with your Jetson Orin Nano Super developer kit.
Firstly, it’s essential to note that the Jetson Orin Nano Developer Kit consists of a P3767 System on Module (SOM) connected to a P3768 carrier board. The SOM and carrier board each have an EEPROM where the board ID is saved.
Since your Jetson Orin Nano Super developer kit was working fine earlier and stopped working after an update, it’s possible that the issue is related to the software or firmware. However, since the LED doesn’t turn on when you plug it in, it’s also possible that there’s a hardware issue.
Here are a few potential causes and troubleshooting steps:
  1. Power supply issue: Although you mentioned that the power supplier is working fine, it’s still worth double-checking. Ensure that the power supply is providing the correct voltage and current to the Jetson Orin Nano.
  2. Firmware or software issue: The update might have caused a firmware or software issue. Try to recover the device by flashing the firmware or software again. You can refer to the NVIDIA documentation for instructions on how to flash the firmware or software.
  3. EEPROM issue: The EEPROM on the SOM or carrier board might be corrupted. Try to reprogram the EEPROM with the correct board ID.
  4. Hardware issue: There might be a hardware issue with the SOM, carrier board, or other components. Inspect the device for any signs of physical damage or wear.
To troubleshoot further, you can try the following:
  • Check the power supply and ensure it’s providing the correct voltage and current.
  • Try to recover the device by flashing the firmware or software again.
  • Check the EEPROM on the SOM and carrier board for any corruption or issues.
  • Inspect the device for any signs of physical damage or wear.
If none of these troubleshooting steps resolve the issue, it’s possible that there’s a more serious hardware problem, and you may need to contact NVIDIA support or a professional repair service.
In comparison to the other issues mentioned in the context, your issue seems to be more related to a hardware or firmware issue rather than a software configuration issue. The other issues mentioned in the context, such as the Jetson Orin Nano restarts while running building text-generation-webui or the Nvidia JetSon Nano Developer Kit not able to install or run EfficientViT, seem to be more related to software configuration or compatibility issues.
I hope this helps you troubleshoot the issue with your Jetson Orin Nano Super developer kit. If you have any further questions or need more assistance, feel free to ask.
