Jetson Orin Developer Kit Won't Turn On
After not using my Jetson developer kit for about 1 month (it was stored in a case indoors with a reasonable temperature and humidity), I tried plugging in several official Nvidia barrel jack power supplies and the Jetson does not turn on. No fan, no light, nothing. I’ve tried everything and it still does not work. I bought mine just a few months ago from Amazon and it’s quite frustrating as it was working for the first few months. Any thoughts?
I’m sorry to hear that your Jetson Orin Nano Developer Kit is not turning on after a month of storage. Given that you’ve tried multiple official Nvidia barrel jack power supplies and the kit still doesn’t work, here are some potential causes and troubleshooting steps to consider:
  1. Power Supply Issues: Although you’ve tried multiple power supplies, it’s possible that the issue lies with the power supply itself or the connection to the kit. Ensure that the power supply is functioning correctly and that the barrel jack is securely connected to the kit.
  2. Storage Conditions: Although you mentioned that the kit was stored indoors with reasonable temperature and humidity, it’s possible that the storage conditions may have affected the kit’s components. Extreme temperatures, humidity, or exposure to moisture can cause damage to the kit’s internal components.
  3. Static Electricity: Static electricity can damage the kit’s internal components. If you’ve handled the kit or its components without proper grounding, it’s possible that static electricity may have caused damage.
  4. Hardware Failure: It’s possible that a hardware component within the kit has failed, preventing it from turning on. This could be due to a manufacturing defect, wear and tear, or damage caused by external factors.
  5. Corrosion or Oxidation: If the kit was exposed to moisture or humidity during storage, it’s possible that corrosion or oxidation may have occurred on the kit’s internal components, preventing it from functioning.
To troubleshoot the issue, you can try the following steps:
  1. Check the Power Button: Ensure that the power button is functioning correctly. Try pressing the power button for an extended period to see if the kit turns on.
  2. Check the LEDs: If the kit has LEDs, check if they are lit when you press the power button. If the LEDs are not lit, it may indicate a power supply issue.
  3. Try a Different Power Supply: If you have access to a different power supply, try using it to see if the kit turns on.
  4. Inspect the Kit’s Components: Carefully inspect the kit’s components for any signs of damage, corrosion, or oxidation.
  5. Contact Nvidia Support: If none of the above steps resolve the issue, it’s recommended that you contact Nvidia support for further assistance. They may be able to provide additional troubleshooting steps or repair/replace the kit if it’s still under warranty.
In comparison to other Jetson kits, the Orin Nano Developer Kit is a relatively new release, and it’s possible that there may be some teething issues. However, Nvidia’s support team should be able to provide guidance on resolving the issue.
It’s also worth noting that the Jetson Orin Nano Developer Kit is not intended for production use, and it’s possible that the kit may have been designed with a limited lifespan. However, given that you’ve only had the kit for a few months, it’s reasonable to expect that it should still be functioning correctly.
In summary, the issue with your Jetson Orin Nano Developer Kit not turning on could be due to a variety of factors, including power supply issues, storage conditions, static electricity, hardware failure, or corrosion/oxidation. By trying the troubleshooting steps outlined above, you may be able to resolve the issue. If not, it’s recommended that you contact Nvidia support for further assistance.
Please put the device into recovery mode, then use SDK Manager to perform a full flash of the device.
Also capture and save the serial console log for the entire duration of the flashing process.
