NVIDIA Jetson Thor Developer Kit同时使用两条SSD的可能性
Hi:
英伟达团队,Thor开发者套件的J1 SSD这个看原理图时钟并没有实际走线,除了自定义硬件之外是否还有其他的硬件可以测试PCIe C3来做启动盘的可能性
J1 in the Dev Kit carrier board reference design is intended for UFS, so the UFS0_REF_CLK is on pin 56. The Dev Kit can only support NVMe on the J103 M.2 Key M connector.
Using PCIe C3 with up to 2 lanes for NVMe can only be supported on a customized carrier board.
好的,感谢回复,另外请教一下PCIe C3 X2 lanes作为NVME用途时,IIC的管脚选择有无要求
Hi taylor_quan,
The Jetson Thor Dev Kit does not support NVMe on PCIe C3. On the dev kit, J1 is intended for UFS, and NVMe is only supported on the J103 M.2 Key M connector. If you want to use PCIe C3 x2 for NVMe, that is only supported on a custom carrier board.
For the I2C question, there is no specific I2C pin requirement for using PCIe C3 x2 as NVMe. Please focus on the correct UPHY configuration, PCIe C3 enablement, and the PEX_C3_RST_N / PEX_C3_CLKREQ_N pinmux settings.
感谢回复,再请教一下是否有最新L4T R38.4配置PCIe C3用作NVME用途的文档指南吗,r38.4/DeveloperGuide中没有提及,以下是论坛其他开发者的案例,是R38.2.1版本,是否可以直接参考
https://forums.developer.nvidia.com/t/jetson-t5000-pcie-c3-rp/347577/6
Yes, the R38.2.1 case is useful as a reference, but not for direct copy.
For R38.4, please follow the current Jetson Thor Adaptation and Bring-Up guide and make sure UPHY_CONFIG is removed when using uphy0-config-6, otherwise C3 enablement may fail during flash/boot.
十分感谢解惑!
