DMESG:
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06aa000 lut_mem=0x2008@0xa06a4000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix=_b boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.848738] usbcore: registered new interface driver usbfs
[ 0.848790] usbcore: registered new interface driver hub
[ 0.848832] usbcore: registered new device driver usb
[ 0.915555] vdd-usb-3v3: at 3300 mV
[ 1.896752] usbcore: registered new interface driver r8152
[ 1.896815] usbcore: registered new interface driver asix
[ 1.896868] usbcore: registered new interface driver ax88179_178a
[ 1.896900] usbcore: registered new interface driver cdc_ether
[ 1.896956] usbcore: registered new interface driver net1080
[ 1.896987] usbcore: registered new interface driver cdc_subset
[ 1.897019] usbcore: registered new interface driver zaurus
[ 1.897061] usbcore: registered new interface driver cdc_ncm
[ 1.904113] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.906044] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f5480c00 id
[ 1.906474] usbcore: registered new interface driver uas
[ 1.906527] usbcore: registered new interface driver usb-storage
[ 1.906615] usbcore: registered new interface driver usbserial
[ 1.908705] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 1.908733] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.908755] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.909464] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.909508] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[ 1.910292] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.910298] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.910302] usb usb1: Product: xHCI Host Controller
[ 1.910307] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.910310] usb usb1: SerialNumber: 3610000.xhci
[ 1.911916] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.911932] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.911937] usbcore: registered new interface driver xpad
[ 1.911942] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.912231] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.912237] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.912241] usb usb2: Product: xHCI Host Controller
[ 1.912246] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.912270] usb usb2: SerialNumber: 3610000.xhci
[ 1.913818] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 1.913824] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 2.014607] usb usb2: usb_suspend_both: status 0
[ 2.122067] usbcore: registered new interface driver usbhid
[ 2.122071] usbhid: USB HID core driver
[ 2.140974] usbcore: registered new interface driver snd-usb-audio
[ 2.237999] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.278417] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[ 2.278447] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.278451] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 2.278455] usb 1-2: Manufacturer: Generic
[ 2.390931] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[ 2.427549] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[ 2.427572] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.427576] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 2.427580] usb 2-3: Manufacturer: Generic
[ 2.658030] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 2.679245] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549
[ 2.679251] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.679255] usb 1-3: Product: Bluetooth Radio
[ 2.679259] usb 1-3: Manufacturer: Realtek
[ 2.679263] usb 1-3: SerialNumber: 00e04c000001
[ 2.845999] usb 1-2: usb_suspend_both: status 0
[ 3.025992] usb 2-3: usb_suspend_both: status 0
[ 3.026163] usb usb2: usb_suspend_both: status 0
[ 7.202789] usbcore: registered new interface driver btusb
[ 7.210364] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 7.216674] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 7.216678] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 7.216680] rtk_btusb: patch_add
[ 7.216682] rtk_btusb: auto suspend is disabled
[ 7.216686] rtk_btusb: pid = 0x3549
[ 7.216688] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 7.216699] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 7.218653] rtk_btusb: btusb_probe: done
[ 7.218664] rtk_btusb: btusb_open start
[ 7.218668] rtk_btusb: btusb_open hdev->promisc ==0
[ 7.218669] rtk_btusb: download_patch start
[ 7.218673] rtk_btusb: chip type value: 0x73
[ 7.218677] rtk_btusb: HCI reset.
[ 7.218730] usbcore: registered new interface driver rtk_btusb
[ 7.230105] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 7.230108] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 7.230110] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 7.230112] rtk_btusb: load_firmware start
[ 7.230114] rtk_btusb: lmp_version = 0x8822
[ 7.230117] rtk_btusb: config filename rtl8822cu_config
[ 7.237790] rtk_btusb: no bdaddr file /opt/bdaddr
[ 7.237795] rtk_btusb: 55 ab 23 87 00 00
[ 7.237805] rtk_btusb: Config file length 6, new length 6
[ 7.237807] rtk_btusb: fw name is rtl8822cu_fw
[ 7.240554] rtk_btusb: This is not 8723a, use new patch style!
[ 7.240559] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 7.241110] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 7.241114] rtk_btusb: load_firmware: New gEVersion 3
[ 7.241118] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 7.241121] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 7.241123] rtk_btusb: fw_version = 0x98a42f7
[ 7.241125] rtk_btusb: number_of_total_patch = 3
[ 7.241126] rtk_btusb: chipID 4
[ 7.241128] rtk_btusb: patch_length 0x55f0
[ 7.241130] rtk_btusb: start_offset 0x00005d00
[ 7.241132] rtk_btusb: Svn version: 21761
[ 7.241134] rtk_btusb: Coexistence: BTCOEX_20190509-0d0d
[ 7.241136] rtk_btusb: buf_len = 0x55f6
[ 7.241147] rtk_btusb: fw: exists, config file: exists
[ 7.241148] rtk_btusb: load_firmware done
[ 7.241165] rtk_btusb: download_data start
[ 7.354096] rtk_btusb: download_data done
[ 7.354100] rtk_btusb: HCI reset.
[ 7.365108] rtk_btusb: read_ver_rsp->lmp_subver = 0x42f7
[ 7.365111] rtk_btusb: read_ver_rsp->hci_rev = 0x98a
[ 7.365113] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 7.365120] rtk_btusb: Rtk patch end 0
[ 7.365123] rtk_btusb: btusb_open set HCI_RUNNING
[ 7.365150] rtk_btusb: btusb_open end
[ 7.387117] rtk_btusb: btusb_notify: hci0 evt 3
[ 7.419168] rtk_btusb: btusb_flush add delay
[ 7.439197] rtk_btusb: btusb_close
[ 8.858333] usb 2-3.3: new SuperSpeed USB device number 3 using tegra-xusb
[ 8.880204] usb 2-3.3: New USB device found, idVendor=2109, idProduct=0817
[ 8.880211] usb 2-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.880215] usb 2-3.3: Product: USB3.0 Hub
[ 8.880219] usb 2-3.3: Manufacturer: VIA Labs, Inc.
[ 8.958014] usb 1-2.3: new high-speed USB device number 4 using tegra-xusb
[ 8.980008] usb 1-2.3: New USB device found, idVendor=2109, idProduct=2817
[ 8.980015] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.980020] usb 1-2.3: Product: USB2.0 Hub
[ 8.980024] usb 1-2.3: Manufacturer: VIA Labs, Inc.
[ 9.297997] usb 2-3.3: usb_suspend_both: status 0
[ 9.354013] usb 2-3: usb_suspend_both: status 0
[ 9.354203] usb usb2: usb_suspend_both: status 0
[ 9.693994] usb 1-2.3.1: new full-speed USB device number 5 using tegra-xusb
[ 9.716140] usb 1-2.3.1: New USB device found, idVendor=062a, idProduct=4182
[ 9.716146] usb 1-2.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.716151] usb 1-2.3.1: Product: 2.4G Keyboard Mouse
[ 9.716155] usb 1-2.3.1: Manufacturer: MOSART Semi.
[ 9.718440] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3.1/1-2.3.1:1.0/0003:062A:4182.0001/input/input5
[ 9.778497] hid-generic 0003:062A:4182.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-3610000.xhci-2.3.1/input0
[ 9.780773] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3.1/1-2.3.1:1.1/0003:062A:4182.0002/input/input6
[ 9.838375] hid-generic 0003:062A:4182.0002: input,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-3610000.xhci-2.3.1/input1
[ 9.966018] usb 1-2.3.2: new low-speed USB device number 6 using tegra-xusb
[ 9.991145] usb 1-2.3.2: New USB device found, idVendor=1d57, idProduct=0001
[ 9.991153] usb 1-2.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.991158] usb 1-2.3.2: Product: 2.4G Mouse
[ 9.991182] usb 1-2.3.2: Manufacturer: 2.4G KB
[ 9.995577] input: 2.4G KB 2.4G Mouse as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3.2/1-2.3.2:1.0/0003:1D57:0001.0003/input/input7
[ 10.055175] hid-generic 0003:1D57:0001.0003: input,hidraw2: USB HID v1.10 Keyboard [2.4G KB 2.4G Mouse] on usb-3610000.xhci-2.3.2/input0
[ 10.059791] input: 2.4G KB 2.4G Mouse as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3.2/1-2.3.2:1.1/0003:1D57:0001.0004/input/input8
[ 10.118425] hid-generic 0003:1D57:0001.0004: input,hidraw3: USB HID v1.10 Mouse [2.4G KB 2.4G Mouse] on usb-3610000.xhci-2.3.2/input1
[ 37.011733] usb0: HOST MAC 8a:7c:72:4c:df:76
[ 37.011783] usb0: MAC 8a:7c:72:4c:df:77
[ 37.316985] l4tbr0: port 2(usb0) entered blocking state
[ 37.316993] l4tbr0: port 2(usb0) entered disabled state
[ 37.317170] device usb0 entered promiscuous mode
[ 37.323845] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 41.689187] Modules linked in: zram overlay bnep rtk_btusb btusb btrtl btbcm btintel rtl8822ce userspace_alert cfg80211 nvgpu ip_tables x_tables
LSHW
roadmapper2-desktop
description: Computer
product: NVIDIA Jetson Xavier NX Developer Kit
serial: 1421021003512
width: 64 bits
capabilities: smp cp15_barrier setend swp
*-core
description: Motherboard
physical id: 0
*-cpu:0
description: CPU
product: cpu
physical id: 1
bus info: cpu@0
capacity: 1907MHz
capabilities: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpufreq
*-cache
description: L1 Cache
physical id: 0
*-cpu:1
description: CPU
product: cpu
physical id: 2
bus info: cpu@1
capacity: 1907MHz
*-cache
physical id: 0
*-cpu:2
description: CPU
product: cpu
physical id: 3
bus info: cpu@2
capacity: 1907MHz
*-cache
physical id: 0
*-cpu:3
description: CPU
product: cpu
physical id: 4
bus info: cpu@3
capacity: 1907MHz
*-cache
physical id: 0
*-cpu:4
description: CPU
product: cpu
physical id: 5
bus info: cpu@4
capacity: 1907MHz
*-cache
physical id: 0
*-cpu:5
description: CPU
product: cpu
physical id: 6
bus info: cpu@5
capacity: 1907MHz
*-cache
physical id: 0
*-cpu:6 DISABLED
description: CPU
product: cpu_cluster_power_states
physical id: 7
bus info: cpu@6
*-cpu:7 DISABLED
description: CPU
product: cpu_core_power_states
physical id: 8
bus info: cpu@7
*-cpu:8 DISABLED
description: CPU
product: cpu_crossover_thresholds
physical id: 9
bus info: cpu@8
*-cpu:9 DISABLED
description: CPU
product: cpu-map
physical id: a
bus info: cpu@9
*-memory
description: System memory
physical id: b
*-pci
description: PCI bridge
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0004:00:00.0
version: a1
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress msix normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:33 ioport:1000(size=4096) memory:1740000000-17400fffff
*-network
description: Wireless interface
product: RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0004:01:00.0
logical name: wlan0
version: 00
serial: 20:4e:f6:c6:17:a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtl88x2ce ip=192.168.1.11 latency=0 multicast=yes wireless=IEEE 802.11AC
resources: irq:555 ioport:1000(size=256) memory:1740000000-174000ffff
*-virtio0 UNCLAIMED
description: Virtual I/O device
physical id: c
bus info: virtio@0
configuration: driver=trusty_ipc
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 4.9.253-tegra xhci-hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 4.09
capabilities: usb-2.00
configuration: driver=hub slots=4 speed=480Mbit/s
*-usb:0
description: USB hub
product: 4-Port USB 2.0 Hub
vendor: Generic
physical id: 2
bus info: usb@1:2
version: 1.40
capabilities: usb-2.10
*-usb
product: USB2.0 Hub
vendor: VIA Labs, Inc.
physical id: 3
bus info: usb@1:2.3
version: 0.50
*-usb:0
description: Keyboard
product: 2.4G Keyboard Mouse
vendor: MOSART Semi.
physical id: 1
bus info: usb@1:2.3.1
version: 1.03
capabilities: usb-1.10
configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
*-usb:1
product: 2.4G Mouse
vendor: 2.4G KB
physical id: 2
bus info: usb@1:2.3.2
version: 11.10
configuration: driver=usbhid maxpower=100mA speed=1Mbit/s
*-usb:1
description: Bluetooth wireless interface
product: Bluetooth Radio
vendor: Realtek
physical id: 3
bus info: usb@1:3
version: 0.00
serial: 00e04c000001
capabilities: bluetooth usb-1.00
configuration: driver=rtk_btusb maxpower=500mA speed=12Mbit/s
*-usbhost:1
physical id: 2
bus info: usb@2
logical name: usb2
version: 4.09
capabilities: usb-3.10
configuration: driver=hub slots=4 speed=10000Mbit/s
*-usb
product: 4-Port USB 3.0 Hub
vendor: Generic
physical id: 3
bus info: usb@2:3
version: 1.40
capabilities: usb-3.20
*-usb
product: USB3.0 Hub
physical id: 3
bus info: usb@2:3.3
version: 0.50
configuration: driver=hub slots=4 speed=5000Mbit/s
*-network:0 DISABLED
description: Ethernet interface
physical id: 3
logical name: dummy0
serial: 0a:b0:b6:7c:10:98
capabilities: ethernet physical
configuration: broadcast=yes driver=dummy driverversion=1.0
*-network:1
physical id: 4
logical name: eth0
serial: 48:b0:2d:3d:76:71
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=eqos link=no multicast=yes port=MII
*-network:2
physical id: 5
logical name: usb0
serial: 8a:7c:72:4c:df:77
configuration: broadcast=yes driver=g_ether driverversion=29-May-2008 firmware=tegra-xudc link=no multicast=yes
*-network:3
physical id: 6
logical name: rndis0
serial: 8a:7c:72:4c:df:75
LUSB
Bus 002 Device 003: ID 2109:0817 VIA Labs, Inc. 4-Port USB 3.0 Hub
Bus 002 Device 002: ID 0bda:0489 Realtek Semiconductor Corp. 4-Port USB 3.0 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 13d3:3549 IMC Networks Bluetooth Radio
Bus 001 Device 006: ID 1d57:0001 Xenta 4-Port USB 2.0 Hub
Bus 001 Device 005: ID 062a:4182 MosArt Semiconductor Corp.
Bus 001 Device 004: ID 2109:2817 VIA Labs, Inc. Bluetooth Radio
Bus 001 Device 002: ID 0bda:5489 Realtek Semiconductor Corp. 4-Port USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
