I just updated my centos 7
system and tried to install the nvidia driver and it failed. Has worked fine prior to the update.
Linux wdcentos72 3.10.0-862.3.3.el7.x86_64 #1 SMP Fri Jun 15 04:15:27 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Here is the nvidia-install.log file showing the problem.
Does anyone else have this issue?
cat nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Mon Jun 25 18:16:54 2018
installer version: 304.137
PATH: /root/perl5/bin:/usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Tagging shared libraries with chcon -t textrel_shlib_t.
→ License accepted.
→ Installing NVIDIA driver version 304.137.
→ There appears to already be a driver installed on your system (version: 304.137). As part of installing this driver (version: 304.137), the existing driver will be uninstalled. Are you sure you want to continue? (‘no’ will abort installation) (Answer: Yes)
→ Performing CC sanity check with CC=“cc”.
→ Performing CC version check with CC=“cc”.
→ Kernel source path: ‘/lib/modules/3.10.0-862.3.3.el7.x86_64/source’
→ Kernel output path: ‘/lib/modules/3.10.0-862.3.3.el7.x86_64/build’
→ Performing rivafb check.
→ Performing nvidiafb check.
→ Performing Xen check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; make clean’…
→ Building kernel module:
executing: ‘cd ./kernel; make module SYSSRC=/lib/modules/3.10.0-862.3.3.el7.x86_64/source SYSOUT=/lib/modules/3.10.0-862.3.3.el7.x86_64/build’…
NVIDIA: calling KBUILD…
make -C /lib/modules/3.10.0-862.3.3.el7.x86_64/build
KBUILD_SRC=/usr/src/kernels/3.10.0-862.3.3.el7.x86_64
KBUILD_EXTMOD=“/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel” -f /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/Makefile
modules
test -e include/generated/autoconf.h -a -e include/config/auto.conf || (
echo >&2;
echo >&2 " ERROR: Kernel configuration is invalid.“;
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.”;
echo >&2 " Run ‘make oldconfig && make prepare’ on kernel src to fix it.“;
echo >&2 ;
/bin/false)
mkdir -p /tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/.tmp_versions ; rm -f /tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/.tmp_versions/*
make -f /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/scripts/Makefile.build obj=/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel
cc -Wp,-MD,/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/.nv.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/kconfig.h -I/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DC
ONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="304.137" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -D"KBUILD_STR(s)=#s” -D"KBUILD_BASENAME=KBUILD_STR(nv)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/.tmp_nv.o /tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv.c
In file included from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/arch/x86/include/asm/cpumask.h:4:0,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/arch/x86/include/asm/msr.h:10,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/arch/x86/include/asm/processor.h:20,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/arch/x86/include/asm/cpufeature.h:7,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/arch/x86/include/asm/thread_info.h:22,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/thread_info.h:54,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/preempt.h:9,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/spinlock.h:50,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/seqlock.h:35,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/time.h:5,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/uapi/linux/timex.h:56,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/timex.h:56,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/sched.h:17,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/utsname.h:5,
from /tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h:40,
from /tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv.c:13:
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/cpumask.h: In function ‘cpumask_parse’:
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/cpumask.h:634:26: warning: signed and unsigned type in conditional expression [-Wsign-compare]
int len = nl ? nl - buf : strlen(buf);
In file included from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/rh_kabi.h:13:0,
from /usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/sched.h:5,
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/asm-generic/qrwlock.h: In function ‘queued_write_trylock’:
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/asm-generic/qrwlock.h:93:35: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
cnts, cnts | _QW_LOCKED) == cnts);
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’
# define likely(x) __builtin_expect(!!(x), 1)
In file included from /tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h:105:0,
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/cpufreq.h: In function ‘cpufreq_next_valid’:
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/cpufreq.h:534:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
while ((*pos)->frequency != CPUFREQ_TABLE_END)
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/cpufreq.h:535:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if ((*pos)->frequency != CPUFREQ_ENTRY_INVALID)
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_from_user’:
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/arch/x86/include/asm/uaccess_64.h:62:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (likely(sz == -1 || sz >= n))
In file included from /tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv.c:13:0:
/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h: In function ‘NV_GET_USER_PAGES’:
/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h:1892:13: warning: passing argument 1 of ‘get_user_pages’ makes pointer from integer without a cast [enabled by default]
return get_user_pages(start, nr_pages, flags, pages, vmas);
In file included from /tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h:82:0,
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/mm.h:1381:6: note: expected ‘struct task_struct *’ but argument is of type ‘long unsigned int’
long get_user_pages(struct task_struct *tsk, struct mm_struct *mm,
/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h:1892:13: warning: passing argument 2 of ‘get_user_pages’ makes pointer from integer without a cast [enabled by default]
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/mm.h:1381:6: note: expected ‘struct mm_struct *’ but argument is of type ‘long unsigned int’
/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h:1892:13: warning: passing argument 4 of ‘get_user_pages’ makes integer from pointer without a cast [enabled by default]
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/mm.h:1381:6: note: expected ‘long unsigned int’ but argument is of type ‘struct page **’
/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h:1892:13: warning: passing argument 5 of ‘get_user_pages’ makes integer from pointer without a cast [enabled by default]
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/mm.h:1381:6: note: expected ‘int’ but argument is of type ‘struct vm_area_struct **’
/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h:1892:13: error: too few arguments to function ‘get_user_pages’
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/mm.h:1381:6: note: declared here
/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h: In function ‘NV_GET_USER_PAGES_REMOTE’:
/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h:1919:45: warning: passing argument 6 of ‘get_user_pages_remote’ makes integer from pointer without a cast [enabled by default]
pages, vmas);
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/mm.h:1377:6: note: expected ‘int’ but argument is of type ‘struct page **’
long get_user_pages_remote(struct task_struct *tsk, struct mm_struct *mm,
/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h:1919:45: warning: passing argument 7 of ‘get_user_pages_remote’ from incompatible pointer type [enabled by default]
pages, vmas);
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/mm.h:1377:6: note: expected ‘struct page **’ but argument is of type ‘struct vm_area_struct **’
/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv-linux.h:1919:45: error: too few arguments to function ‘get_user_pages_remote’
pages, vmas);
/usr/src/kernels/3.10.0-862.3.3.el7.x86_64/include/linux/mm.h:1377:6: note: declared here
make[4]: *** [/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel/nv.o] Error 1
make[3]: *** [module/tmp/selfgz18105/NVIDIA-Linux-x86_64-304.137/kernel] Error 2
make[2]: *** [sub-make] Error 2
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make[1]: *** [module] Error 1
make: *** [module] Error 2
→ Error.
ERROR: Unable to build the NVIDIA kernel module.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
root@I7:/mnt/y#
