Good evening. I have the following problem. After the recent Nvidia driver updates on Fedora 40, when I run anaconda-navigator, the system suddenly starts allocating an unhealthy amount of RAM, and at the same time, input lags occur with a bluetooth mouse (but at the same time, a wired mouse or touchpad works without these problems). Trying to get rid of these problems, restarting the computer by using the reboot command or through the button in the “Restart” menu, I get a black screen with repeated lines of error “nvidia-modeset: ERROR: GPU:0: Error while waiting for GPU process”. After a while, the system still restarts, but the problem repeats itself after starting anaconda-navigator (I also want to note that the same symptoms occurred when running JetBrains IDEs). I don’t know what the problem is as everything has been working fine for over a year.
I am also attaching the system characteristics of the device
OS: Fedora Linux 40 (Workstation Editi
Host: Nitro AN17-51 V1.05
Kernel: 6.10.10-200.fc40.x86_64
Uptime: 1 hour, 14 mins
Packages: 2506 (rpm), 56 (flatpak)
Shell: zsh 5.9
Resolution: 2560x1440
DE: GNOME 46.5
WM: Mutter
WM Theme: Adwaita
Theme: Orchis-Purple-Dark-Compact [GTK
Icons: WhiteSur-purple-dark [GTK2/3]
Terminal: gnome-terminal
CPU: 13th Gen Intel i7-13700H (20) @ 4
GPU: Intel Raptor Lake-P [Iris Xe Grap
GPU: NVIDIA GeForce RTX 4060 Max-Q / M
Memory: 4997MiB / 15685MiB
and nvidia-bug-report.log.gz
nvidia-bug-report.log.gz (484.6 KB)
