Ubuntu 20.04 blocked after upgrading nvidia drivers
I was normally using an Nvidia GPU GTX 1650 on my computer with Ubuntu Desktop 20.04 LTS. After some updates (nvidia driver 510 and I think also ubuntu 20.04.3), the GPU stopped working and the pc couldn’t start.
I tried several times removing the nvidia drivers and installing them again (510, 470, 460), but the command $nvidia-smi never started working again.
Here some info:
~$ uname -r
5.13.0-30-generic
~$ cat /etc/os-release
NAME=“Ubuntu”
VERSION=“20.04.3 LTS (Focal Fossa)”
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME=“Ubuntu 20.04.3 LTS”
VERSION_ID=“20.04”
HOME_URL=“https://www.ubuntu.com/
SUPPORT_URL=“https://help.ubuntu.com/
BUG_REPORT_URL=“https://bugs.launchpad.net/ubuntu/
PRIVACY_POLICY_URL=“Data privacy | Ubuntu
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
Here you can find the nvidia bug report:
nvidia-bug-report.log.gz (300.7 KB)
Thank you.
NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1253)
Might be broken.
The GPU fails to initialize, please check for properly connected power connectors, reseat card in its slot, check in another system for a general hardware failure.
I tested the GPU on a Windows computer and it works.
Moreover, I’m facing the same issue (RmInitAdapter failed) with another computer and another GPU. Everything works on Windows, but fails with Ubuntu. Any idea?
Thank you
There’s a similar issue
https://forums.developer.nvidia.com/t/rtx3060ti-with-intel-10th-cpu-on-ubuntu-20-04-3-not-work/204196/4
so I’m suspecting a runtime pm issue with recent nvidia driver versions. Please also post the output of
grep 10de /lib/udev/rules.d/* /etc/udev/rules.d/*
Seems this has been an issue before
https://forums.developer.nvidia.com/t/bug-470-42-01-1-dgpu-can-not-be-initialized/183627/9?u=generix
that specific issue was then fixed in 470.86 but likely re-introduced now.
The output of
$ grep 10de /lib/udev/rules.d/* /etc/udev/rules.d/*
is:
/lib/udev/rules.d/71-nvidia.rules:SUBSYSTEM=="pci", ATTRS{vendor}=="0x10de", DRIVERS=="nvidia", TAG+="seat", TAG+="master-of-seat"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x03[0-9]*", TEST=="power/control", ATTR{power/control}="auto"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x040300", TEST=="power/control", ATTR{power/control}="auto"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c0330", TEST=="power/control", ATTR{power/control}="auto"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c8000", TEST=="power/control", ATTR{power/control}="auto"
Please try to remove that file and run
sudo update-initramfs -u
afterwards. Then reboot and check if the gpu works.
This didn’t solve the issue. However I solved the issue by installing an old driver, by following this: *Bug* 470.42.01-1 dGPU can not be initialized - #13 by Kanguru007
These are the commands I entered:
#remove the current NVIDIA driver
sudo apt remove nvidia*
sudo reboot now
#disable the noveau driver
sudo echo "blacklist nouveau" >  /etc/modprobe.d/blacklist-nvidia-nouveau.conf
sudo echo "options nouveau modeset=0" >> /etc/modprobe.d/blacklist-nvidia-nouveau.conf
sudo reboot now
#install NVIDIA 460.84 driver
#downloaded from https://www.nvidia.com/Download/Find.aspx?lang=en-us
chmod +x NVIDIA-Linux-x86_64-460.84.run
sudo ./NVIDIA-Linux-x86_64-460.84.run
sudo reboot now
In the end, my configuration was:
Ubuntu: 20.04.2 LTS
Kernel: 5.13.0-30-generic
Nvidia driver: 460.84
