Hi all, I am using Ubuntu 18.04 remotely on xrdp and try to use vulkan to do some work but I just found that I couldn’t use nvidia on vulkan nor even use it for display settings.
Here is the gpu info (1 aspeed and 8 nvidia 1080ti):
03:00.0 VGA compatible controller: ASPEED Technology, Inc. ASPEED Graphics Family (rev 41) Subsystem: ASPEED Technology, Inc. ASPEED Graphics Family Kernel driver in use: ast -- 1a:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) Subsystem: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] Kernel driver in use: nvidia -- 1b:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) Subsystem: ASUSTeK Computer Inc. GP102 [GeForce GTX 1080 Ti] Kernel driver in use: nvidia -- 1d:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) Subsystem: ASUSTeK Computer Inc. GP102 [GeForce GTX 1080 Ti] Kernel driver in use: nvidia -- 1e:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) Subsystem: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] Kernel driver in use: nvidia -- 3d:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) Subsystem: ASUSTeK Computer Inc. GP102 [GeForce GTX 1080 Ti] Kernel driver in use: nvidia -- 3f:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) Subsystem: Gigabyte Technology Co., Ltd GP102 [GeForce GTX 1080 Ti] Kernel driver in use: nvidia -- 40:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) Subsystem: Gigabyte Technology Co., Ltd GP102 [GeForce GTX 1080 Ti] Kernel driver in use: nvidia -- 41:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) Subsystem: ASUSTeK Computer Inc. GP102 [GeForce GTX 1080 Ti] Kernel driver in use: nvidia
When I run nvidia-settings, it got
ERROR: Unable to load info from any available system
run “nvidia-smi”, got
Sun Aug 16 16:55:38 2020 +-----------------------------------------------------------------------------+ | NVIDIA-SMI 450.57 Driver Version: 450.57 CUDA Version: 11.0 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 GeForce GTX 108... Off | 00000000:1A:00.0 Off | N/A | | 0% 21C P8 9W / 250W | 42MiB / 11178MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ | 1 GeForce GTX 108... Off | 00000000:1B:00.0 Off | N/A | | 21% 23C P8 9W / 250W | 7MiB / 11178MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ | 2 GeForce GTX 108... Off | 00000000:1D:00.0 Off | N/A | | 20% 29C P8 9W / 250W | 7MiB / 11178MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ | 3 GeForce GTX 108... Off | 00000000:1E:00.0 Off | N/A | | 0% 21C P8 8W / 250W | 7MiB / 11178MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ | 4 GeForce GTX 108... Off | 00000000:3D:00.0 Off | N/A | | 20% 22C P8 8W / 250W | 7MiB / 11178MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ | 5 GeForce GTX 108... Off | 00000000:3F:00.0 Off | N/A | | 21% 22C P8 9W / 250W | 7MiB / 11178MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ | 6 GeForce GTX 108... Off | 00000000:40:00.0 Off | N/A | | 21% 25C P8 9W / 250W | 7MiB / 11178MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ | 7 GeForce GTX 108... Off | 00000000:41:00.0 Off | N/A | | 29% 24C P8 8W / 250W | 7MiB / 11178MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 1990 G /usr/lib/xorg/Xorg 31MiB | | 0 N/A N/A 3170 G /usr/bin/gnome-shell 8MiB | | 1 N/A N/A 1990 G /usr/lib/xorg/Xorg 4MiB | | 2 N/A N/A 1990 G /usr/lib/xorg/Xorg 4MiB | | 3 N/A N/A 1990 G /usr/lib/xorg/Xorg 4MiB | | 4 N/A N/A 1990 G /usr/lib/xorg/Xorg 4MiB | | 5 N/A N/A 1990 G /usr/lib/xorg/Xorg 4MiB | | 6 N/A N/A 1990 G /usr/lib/xorg/Xorg 4MiB | | 7 N/A N/A 1990 G /usr/lib/xorg/Xorg 4MiB | +-----------------------------------------------------------------------------+
and glxinfo | grep render:
direct rendering: Yes
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer,
Extended renderer info (GLX_MESA_query_renderer):
OpenGL renderer string: llvmpipe (LLVM 10.0.0, 256 bits)
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_MESA_ycbcr_texture, GL_NV_conditional_render, GL_NV_depth_clamp,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
GL_EXT_polygon_offset_clamp, GL_EXT_read_format_bgra, GL_EXT_render_snorm,
GL_MESA_shader_integer_functions, GL_NV_conditional_render,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
and vulkaninfo:
ERROR at /build/vulkan-tools-1.2.148.0-1ubuntu18.04/vulkaninfo/vulkaninfo.h:240:vkEnumerateInstanceExtensionProperties failed with ERROR_INITIALIZATION_FAILED
and xrandr --listproviders:
Providers: number : 0
I searched a lot and trid many methods, including but not limited to disable secure boot (mokutil --sb-state), set the nvidia-drm.modeset=1 to GRUB_CMDLINE_LINUX_DEFAULT option in the grub config, add option “Option “PrimaryGPU” “Yes”” or “AllowNVIDIAGPUScreens” on /etc/X11/xorg.conf; but nothing seemed to really work.
Attatched is the bug report. Really hope someone could help cause I really need nvidia gpu running for my work.
nvidia-bug-report.log.gz (2.0 MB)
