Fresh user of the Jetson TX1 and I’ve been learning and working through examples, but I am obviously missing something basic that I haven’t found. How could my TX1 with the Jetpack installation not have the Nvidia drivers and the smi command?
‘nvidia@tegra-ubuntu:~$ nvidia-smi
nvidia-smi: command not found’
You don’t need to install driver separately. Flash image also install the driver.
Nvidia-smi doesn’t support Tegra.
If you want to check GPU utilization, please use tegrastats
sudo ./tegrastats
If you want to check GPU memory, please use cudaMemGetInfo() function
https://devtalk.nvidia.com/default/topic/974063/jetson-tx1/caffe-failed-with-py-faster-rcnn-demo-py-on-tx1/post/5013784/#5013784
I see. thank you.
