Nvidia smi driver version 570 on ubuntu 24.04 shows wrong power consumption when running for the first time
Nvidia smi on driver version 570 on ubuntu 24.04.2 shows wrong power consumption when running for the first time after boot
when booting the computer and checking nvidia-smi soon after logging into the computer, running nvidia-smi for the first time after boot will cause it to show a power consumption figure of 752w like this:
Fri Mar 7 21:08:26 2025
| NVIDIA-SMI 570.124.06 Driver Version: 570.124.06 CUDA Version: 12.8 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3060 … Off | 00000000:01:00.0 Off | N/A |
| N/A 40C P0 752W / 80W | 2MiB / 6144MiB | 5% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
if you try to run nvidia-smi afterwards the issue dissappears, unless you don’t check nvidia-smi afterwards for around 1 minute and then try again, in which case the same issue happens again. i have a lenovo 15ach6h laptop with an nvidia rtx 3060 mobile graphics card
nvidia-bug-report.log.gz (590.3 KB)
