I am running ubuntu 22.10
I have disabled security boot
boot in my BIOS settings.
I’ve installed from ubuntu GUI Additional Drivers NVIDIA-515 driver metapackage
My system does not recognize the driver, hence don’t use it, please help
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I am using Wayland
Gnore Version 43.1
Laptop Is Dell XPS 15 9510
Kinda odd, you first had a working 525.78.01 driver, then you went to the incompatible “-open” version and now the nvidia gpu is turned off and inaccesible so no driver can load. pci 0000:01:00.0: Unable to change power state from D3cold to D0, device inaccessible
Does it still work with Windows? Please also check for a bios update.
I don’t really know, might be a kernel bug or even defective hardware since it worked previously.
Maybe add the liquorix ppa to upgrade to latest kernel and check if the nvidia gpu comes alive.
