I installed jetpack3.2 on my JetsonTX2. I run NVIDIA_System_Profiler/Host-x86_64/SystemProfiler. When I configure target device IP/user I am getting connection error:
AnalysisInternalError (4001) {
OriginalExceptionClass: N5boost16exception_detail10clone_implINS0_19error_info_injectorINS_6system12system_errorEEEEE
Please note that I can ssh to target fine via terminal.
Could someone please let me know what is this error?
Thanks for updating this issue with us.
We are trying to reproduce this internally.
Will let you know the result.
We have checked the System Profiler internally.
It works correctly without the error you met.
Could you try it again?
I have tried several times, with Jetpack3.2 (System Profiler 4.0) running on Host Ubuntu 14.04 LTS I am getting
From the error do you get any information that can help me troubleshoot this issue?
Any help on this is much appreciated.
Maybe this error is caused by some different environment setting.
Let us track with our internal team and update information to you later.
Could you share the tool log file? To create a log file, please do the following:
- Close any running instances of the System Profiler application on host machine
- Rename nvlog.config.template to nvlog.config in Host-x86_64/ directory
- Start the application and attempt to connect to the target board
- If the connection fails, close the host application
- The SystemProfiler.log file should be created in Host-x86_64/ directory. Please share this file with us
