I cannot find the nvvp on my Nvidia Drive AGX !
I read that it should be a part of the CUDA toolkit.
I can find the nvprof under /usr/local/cuda/bin but I didn’t find the nvvp.
I tried to install it using this command line
sudo apt install nvidia-visual-profiler (and it is not working on the drive AGX)
I got an error “E: Unable to locate package nvidia-visual-profiler”
I used the same command line to install the nvvp on another Linux-ubuntu based machine (that doesn’t include any GPU) and that works fine.
My last question is about the nvvp/nvprof : Can I use the NVIDIA profilers to profile a pure CPU application (a c/c++ code without any cuda ) ?
If yes what kind of metrics I can profile?
Could you try with Nsight Eclipse Edition bundled in NVIDIA CUDA Toolkit? It is part of Drive Software. You can also consult “Development and Debugging Setup” in the page for reference.
