Nvidia VLM Workflow Issues
We’re having an issue while running the VLM workflow
We’re able to add a camera and generate alerts on the mobile app, but while adding a second camera we are getting an error saying ‘Max WebRTC connections reached’
Also the ROI feature fails and says ‘Failed to set ROI’
Are there any settings we could try for this?
Can you update “max_webrtc_out_connections”: 1, in /opt/nvidia/jetson-1.1.0/services/vst/config/vst_config.json to the prefer number?
Here is the guide on JPS VLM. Why you need set ROI for VLM workflow?
Thanks, updating “max_webrtc_out_connections”: 1, in /opt/nvidia/jetson-1.1.0/services/vst/config/vst_config.json
But on the web page 0.0.0.0:30080/vst - we get Bad Gateway error
Any idea why ? The VST service on the jeston orin is running without issues
Please ignore above “Bad Gateway” error
We want to setup AI NVR with Trip Wire, can you point us to the steps for this please ?
We set the “analytic_server_address”: “http://21.6.45.236:30080/emdx"
which is the jetson IP and port… but the tripwire fails still
Here is the setup guide for AI NVR: AI NVR — Metropolis on Jetson documentation 0.1.0 documentation
Trip Wire and ROI works fine without any changes for JPS release in my side.
Thanks. We will have a look at this
One more issue we are facing - after adding 4 cameras on VST, on the mobile app we get an error saying - Invalid VLM stream ID whenever we use the chat option to interact with the VLM
And on the docker logs for VLM, we see that there is an error saying - max retries exceeded for URL - /api/v1/chat-completion
Any idea why this happens ?
Can you share the log? You can refer the source code of VLM here: jetson-platform-services/inference/vlm at main · NVIDIA-AI-IOT/jetson-platform-services · GitHub
This is the error we get when using the chat feature on the mobile app
Hi @kesong do you know why this could be happening ?
Can VLM work if only add one camera?
It fails with 1 stream as well
Error on jps_vlm container : HTTPConnectionPool(host=‘0.0.0.0’, port=5015): Max retries exceeded with url: /v1/chat/completions (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0xffff8a5c7700>: Failed to establish a new connection: [Errno 111] Connection refused’))
Can you chat with curl instead of the mobile app? Please refer here for chat with curl: Visual Language Models (VLM) with Jetson Platform Services — Metropolis on Jetson documentation 0.1.0 documentation
Yes I got the problem.
It is working when I stop AI-NVR containers using sudo docker compose -f compose_nano.yaml down --remove-orphans
But VLM gives error saying - HTTPConnectionPool(host=‘0.0.0.0’, port=5015): Max retries exceeded with url: /v1/chat/completions (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0xffff8a5c7700>: Failed to establish a new connection: [Errno 111] Connection refused’))
even with curl, when AI-NVR containers are running
Do you think there is some port forwarding / port blocking issue ?
Also the analytics button on Mobile app is not clickable, but on web UI it is working
Any idea why? Screenshots below
@kesong can you please help with the above screenshots?
It will be a great help to us. Thank you for all the support
Here is the guide for mobile app. Can you refer here for Analytics: AI-NVR Mobile Application User Guide — Metropolis on Jetson documentation 0.1.0 documentation?
Yes we saw this, but we are not able to click on the analytics button. We are able to see all cameras but the analytics button is greyed out.
Which workflows are you running? Analytics is for AI NVR as AI NVR will output Analytics such as trip wire/ROI counting. Seems you are running VLM, so only chat and alert button are green. You can refer the images in here: AI-NVR Mobile Application User Guide — Metropolis on Jetson documentation 0.1.0 documentation (nvidia.com)
Thank you @kesong
How do I enable AI NVR on the mobile app? On web UI it is working, I am able to add Tripwire
And AI NVR containers are running on the jetson device as well. Should I stop the VLM container?
