WebRTC connection limit reached error in VST
I’m running JPS on an AGX Orin flashed with JetPack 6.0 (Rev. 2). In the VST web UI, I’m unable to add both input and output streams (overlay streams) at the same time. When I add both streams, it shows a “WebRTC connection limit reached” error. This problem occurs with the latest version of Metropolis (JPS). In the previous version, I did not encounter this kind of error.
Can you have a try to modify “max_webrtc_out_connections” in /opt/nvidia/jetson/services/vst/config/vst_config.json to 8?
