I have implemented a pipeline that outputs an rtsp stream, however I would ultimately like to be able to stream through WebRTC. I visited this link: Welcome — Jetson Linux<br/>Developer Guide 34.1 documentation
and tried out the code in WebRTC_r32.2.0_aarch64.tbz2 following the instructions in the README, however I am confused as to which IP address to use in this command:
./peerconnection_client --autoconnect --server <Server.IP>
I would have assumed it was localhost as I am running the server on the same device. But I get this error:
Unable to init server: Could not connect: Connection refused
I have also tried centricular’s web rtc demo code found here: GitHub - centricular/gstwebrtc-demos: Superseded by https://gitlab.freedesktop.org/gstreamer/gst-examples/-/tree/master/webrtc - Demo apps for using gstreamer's webrtc implementation with no luck.
**• Jeston Xavier
**• DeepStream 5.1
