Nvidia with qt
I want to know how to access GPIO using qt creator. I have written the code in c++
Hi @walihullah,
We have done with using system commands. You should know the gpio pin number for configuring.
system(“echo 508 > /sys/class/gpio/export”);
system(“echo out > /sys/class/gpio/gpio508/direction”);
system(“echo 509 > /sys/class/gpio/export”);
system(“echo out > /sys/class/gpio/gpio509/direction”);
system(“echo 510 > /sys/class/gpio/export”);
system(“echo out > /sys/class/gpio/gpio510/direction”);
For setting the pin as high,
system(“echo 1 > /sys/class/gpio/gpio508/value”);
For setting the pin as low,
system(“echo 0 > /sys/class/gpio/gpio508/value”);
Hope it works.
