nvidia-xconfig --enable-all-gpus
nvidia-xconfig --cool-bits=4
from forums.developer.nvidia.com worked with my dual titan rtx on Ubuntu 18. This allows me to manually set the fan speed using NVIDIA X Server Setting. Otherwise, the GPU runs real hot during training (86C). When I set fans to 100%, the temperature is at 66C during training.
Upgraded to ubuntu 20.04, everything very stable except after setting the coolbits=4. When I do, I get manual fan control, but after the screen times out and darkens, I log in, the mouse does not appear. reboot using the <CTRL><ALT>T to get a terminal(no mouse), sudo reboot, log in and all is fine until the screen darkens after a timeout.
Delete the /etc/X11/xorg.config, reboot, then all is good again, even after screen times out and darkens, but no GPU fan speed control.
Very repeatable.
Any other way to enable manual fan speed control on NVIDIA?
I tried sudo nvidia-smi --gpu-target-temp=70 but this had no effect on fan speed.
The /etc/X11/xorg.config created by nvidia-xconfig
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 460.32.03
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" RightOf "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "TITAN RTX"
BusID "PCI:33:0:0"
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:74:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Coolbits" "4"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
