NvJPEGEncoder-encodeFromBuffer-tegra_multimedia_api
Dear Nvidia,
    1. I refer to the 05_jpeg_encode example to encode raw data into jpeg.
      Errors occur after running hundreds of times each time.
terminate called after throwing an instance of ‘std::logic_error’
what(): basic_string::_M_construct null not valid
Aborted
or
NVMAP_IOC_GET_FD failed: Bad address
PosixMemMap:74 FD from Handle failed : Bad address
NvJpeg_Tvmr_Error: tvmrNvjpgJPEGEncoderCreate: 590: ring buffers allocation failed
Segmentation fault
The dmesg log as below.
[ 9258.250626] nvmap: __nvmap_dmabuf_fd() NvMap: FD limit is crossed for uid 0
    1. My source code is as follows.
static int save_image(cv::Mat outMat, char * video_node, uint64_t timestamp)
    char image_name[70];
    sprintf(image_name, PATH, *video_node, timestamp);
    uint32_t width = outMat.cols;
    uint32_t height = outMat.rows;
    unsigned long out_buf_size = width * height;
    unsigned char *out_buf;
	NvBuffer buffer(V4L2_PIX_FMT_YUV420M, width, 2 * height / 3, 0);
	int ret = buffer.allocateMemory();
	if(ret < 0)
			printf("allocate memory failed\n");
	memcpy(buffer.planes[0].data, outMat.data, 2 * width * height / 3);
	buffer.planes[0].bytesused = width * height * 2 / 3;
	memcpy(buffer.planes[1].data, outMat.data + width * height * 2 / 3, width * height/6);
	buffer.planes[1].bytesused = width * height / 6;
	memcpy(buffer.planes[2].data, outMat.data + (5*width * height)/6, width * height/6);
	buffer.planes[2].bytesused = width * height / 6;
	NvJPEGEncoder *jpegenc = NvJPEGEncoder::createJPEGEncoder("jpenenc");
	out_buf = new unsigned char[out_buf_size];
	ret = jpegenc->encodeFromBuffer(buffer, JCS_YCbCr, &out_buf, out_buf_size, 85);
	out_file->write((char *) out_buf, out_buf_size);
    delete[] out_buf;
    delete out_file;
     * Destructors do all the cleanup, unmapping and deallocating buffers
     * and calling v4l2_close on fd
    delete jpegenc;
    return 0;
    1. I located the problem with this line of code.
    1. Current issue HW and SW infomation:
      Jetson AGX Orin - Jetpack 5.0.2 GA [L4T 35.1.0]
Please help to check this issue, thanks.
It looks like YUV420 frame data is not copied directly. It should be Y plane with (width*height) bytes and UY plane with (width*height)*0.5 bytes. And please allocate Nvbuffer and out_buf to (width*height)*1.5 bytes.
Dear Sir,
I changed the code to look like this.
When the code is executed to the 257th time, a segment fault will be reported.
I have confirmed that there was no error reported in memory allocation, and the error was reported when executing the following line of code.
memcpy(buffer.planes[0].data, outMat.data, width * height);
        unsigned long out_buf_size = width * height * 3 / 2;
        std::ofstream * out_file = new ofstream(image_name);
        NvBuffer buffer(V4L2_PIX_FMT_YUV420M, width, height, 0);
        if(ret < 0)
        buffer.planes[0].bytesused = width * height;
        memcpy(buffer.planes[1].data, outMat.data + width * height, width * height / 4);
        buffer.planes[1].bytesused = width * height / 4;
        memcpy(buffer.planes[2].data, outMat.data + 5 * width * height / 4, width * height / 4);
        buffer.planes[2].bytesused = width * height / 4;
        usleep(500);
        out_file->close();
        buffer.deallocateMemory();
        delete[] out_buf;
        delete out_file;
        delete jpegenc;
    return 0;
You can set this option to 05_jpeg_encode to make sure it does not happen to the default sample:
-s Stress test [Default = 1]
If default sample works, you may compare your code with the default code.
