NVJPEGEncoder not compress frame
my setup JP4.6.1 AGX, imx264 2448x2048.
This code compress frame:
EGLStream::IImageJPEG * iJPEG{ Argus::interface_cast< EGLStream::IImageJPEG >( iFrame->getImage() ) };
                    if( iJPEG )
                        const auto file{ m_recordPath + "/" + std::to_string( cameraId ) + "/" + std::to_string( framesNum.at( cameraId ) ) + ".jpg" };
                        if( iJPEG->writeJPEG( file.c_str() ) != Argus::STATUS_OK )
                            std::cout << "Failed to write JPEG: " << file << std::endl;
This does not:
                    EGLStream::NV::IImageNativeBuffer * iNativeBuffer{ Argus::interface_cast< EGLStream::NV::IImageNativeBuffer >( iFrame->getImage()) };
                    if( not iNativeBuffer )
                        std::cout << "IImageNativeBuffer not supported by Image!" << std::endl;
                    else
                        if( m_dmaBuffers.at( cameraId ) == - 1 )
                            m_dmaBuffers.at( cameraId ) = iNativeBuffer->createNvBuffer( frameSize,
        NvBufferColorFormat_YUV420,
        NvBufferLayout_BlockLinear );
                        if( m_dmaBuffers.at( cameraId ) != - 1 )
                            if( iNativeBuffer->copyToNvBuffer( m_dmaBuffers.at( cameraId ) ) != Argus::STATUS_OK )
                                std::cout << "Failed to copy frame to NvBuffer!" << std::endl;
                            } else
                                const auto filename{ m_recordPath + "/" + std::to_string( cameraId ) + "/" + std::to_string( framesNum.at( cameraId ) ) + ".jpg" };
                                std::ofstream outputFile{ filename };
                                if( outputFile.is_open() )
                                    uint8_t * buffer = m_OutputBuffers.at( cameraId );
                                    unsigned long size{ bufferSize };
                                    m_JpegEncoders.at( cameraId )->encodeFromFd( m_dmaBuffers.at( cameraId ), JCS_YCbCr, & buffer, size );
                                    outputFile.write( ( char * ) buffer, bufferSize );
                        } else
                            std::cout << "Failed to create NvBuffer!" << std::endl;
First case file size about 200-400KB
Next one always 7.5MB as buffer size.
Please explain me that.
Best regards, Viktor.
Please check and confirm if the fd is valid. For further investigation, please compare the code to the reference sample:
/usr/src/jetson_multimedia_api/samples/05_jpeg_encode
Sorry, my mistake.
size should be rewritable.
outputFile.write( ( char * ) buffer, size );
