Nvlink seems not to link for cuda libraries if cross compiling and --cpu-arch=AARCH64 is specified
Cuda separable compilation seems not to work if cross compiling. The test code I am using available here:
https://github.com/siposcsaba89/cuda_separable_compilation_test.git
I get linker errors:
nvlink error : Undefined reference to ‘cudaGetParameterBufferV2’ in ‘CMakeFiles/cuda_separable_compilation_test.dir/main.cu.o’
nvlink error : Undefined reference to ‘cudaLaunchDeviceV2’ in ‘CMakeFiles/cuda_separable_compilation_test.dir/main.cu.o’
nvcc command:
/usr/local/cuda/bin/nvcc -ccbin=/usr/bin/aarch64-linux-gnu-g++ -arch=sm_50 -Xcompiler=-fPIC -Wno-deprecated-gpu-targets -shared -dlink CMakeFiles/cuda_separable_compilation_test.dir/main.cu.o -o CMakeFiles/cuda_separable_compilation_test.dir/cmake_device_link.o
Verbose output:
#$ SPACE=
#$ CUDART=cudart
#$ HERE=/usr/local/cuda/bin
#$ THERE=/usr/local/cuda/bin
#$ TARGET_SIZE=
#$ TARGET_DIR=
#$ TARGET_DIR=targets/aarch64-linux
#$ TOP=/usr/local/cuda/bin/…
#$ NVVMIR_LIBRARY_DIR=/usr/local/cuda/bin/…/nvvm/libdevice
#$ LD_LIBRARY_PATH=/usr/local/cuda/bin/…/lib:
#$ PATH=/usr/local/cuda/bin/…/nvvm/bin:/usr/local/cuda/bin:/home/csaba/bin:/home/csaba/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/cuda/bin/
#$ INCLUDES=“-I/usr/local/cuda/bin/…/targets/aarch64-linux/include”
#$ LIBRARIES= “-L/usr/local/cuda/bin/…/targets/aarch64-linux/lib/stubs” “-L/usr/local/cuda/bin/…/targets/aarch64-linux/lib”
#$ CUDAFE_FLAGS=
#$ PTXAS_FLAGS=
#$ nvlink --arch=sm_50 --register-link-binaries=“/tmp/tmpxft_0001adb7_00000000-2_cmake_device_link.reg.c” -m64 “-L/usr/local/cuda/bin/…/targets/aarch64-linux/lib/stubs” “-L/usr/local/cuda/bin/…/targets/aarch64-linux/lib” -cpu-arch=AARCH64 “CMakeFiles/cuda_separable_compilation_test.dir/main.cu.o” -lcudadevrt -o “/tmp/tmpxft_0001adb7_00000000-4_cmake_device_link.sm_50.cubin”
nvcc version: Cuda compilation tools, release 9.2, V9.2.88
If not cross compiling everything works fine.
I am on Ubuntu 16.04 with cuda 9.2 istalled from dripepx2 PDK5, which contains target files for x86_64 and aarch64 architecture.
In the repo there is a cmake toolchaim file I used for cmake configure, like:
cmake … -DCMAKE_TOOLCHAIN_FILE=$PWD/…/aarch64-linux-gnu.cmake
Could you please help me to resolve this issue? What do I miss?
Thanks in advance,
Csaba
Hi @csaba.sipos, did you ever solve this problem?
Dear @ericnathanmiller @csaba.sipos
Do you have any issues with CUDA cross compilation? If so, please include your code as a CUDA sample inside /usr/local/cuda/samples and make changes in Makefile. Please check cross compile using make TARGET_ARCH==aarch64 command (please see CUDA Samples :: CUDA Toolkit Documentation for more details)
Hi @SivaRamaKrishnaNV,
I tried to cross compile the samples, I am getting the same error as specified by @csaba.sipos .
Any updates on this, I am trying to cross compile some custom dynamic parallelism code to no avail.
#Cross compilation step to *.cu
/usr/local/cuda/bin/nvcc -m64 --compiler-bindir /usr/bin/aarch64-linux-gnu-g++-7 /usr/local/cuda/targets/aarch64-linux/lib/libcudadevrt.a -I/usr/local/include/ --gpu-architecture=sm_50 -rdc=true custom_code_dynamic_parallelism.cu -I/usr/local/cuda/include/ -Iinclude -Xlinker -L/usr/local/cuda/targets/aarch64-linux/lib/ -Xlinker -lcudadevrt
The above part properly generates the object files.
#Linking step for .o
/usr/local/cuda/bin/nvcc -m64 --compiler-bindir /usr/bin/aarch64-linux-gnu-g++-7 --gpu-architecture=sm_61 -dlink gpu_link.o custom_code_dynamic_parallelism.o -Xlinker -L/usr/local/cuda/targets/aarch64-linux/lib/ -lcudadevrt -lcudart
However, the nvlink step fails with this outputs:
@E@nvlink error   : Undefined reference to 'cudaGetParameterBufferV2' in 'cuda_quad_tree.o'
@E@nvlink error   : Undefined reference to 'cudaLaunchDeviceV2' in 'cuda_quad_tree.o'
I ran nm -A through all cuda libraries, I am not able to find which the library containing the cudaLaunchDeviceV2 nor cudaGetParameterBufferV2symbols.
Whenever I try compiling and linking without dynamic parallelism it works.
I am using cuda 10.2.
I am not sure what I am missing here.
Any help would be greatly appreciated.
Dear @lucasm70i1,
Please file a new topic with details about the issue. Also, please check if you are able to cross compile the shipped CUDA samples first.
I already tried building the samples, I will try again and open a new topic with my results.
Cheers.
@SivaRamaKrishnaNV
Follow up topic with my cross compilation results from your samples:
Let me know if I am doing something wrong for getting these linking errors.
Cheers.
