Is this a modification to the device tree?
● nvpmodel.service - nvpmodel service
Loaded: loaded (/etc/systemd/system/nvpmodel.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2023-08-07 03:35:12 EDT; 10min ago
Process: 4929 ExecStart=/usr/sbin/nvpmodel -f /etc/nvpmodel.conf (code=exited, status=255)
Main PID: 4929 (code=exited, status=255)
Aug 07 03:35:12 nano nvpmodel[4929]: NVPM ERROR: failed to write PARAM GPU_POWER_CONTROL_ENABLE: ARG GPU_PWR_CNTL_EN: PATH: /sys/devices/gpu.0/power/control VAL: on
Aug 07 03:35:12 nano nvpmodel[4929]: NVPM ERROR: Error opening /sys/devices/gpu.0/devfreq/57000000.gpu/available_frequencies: 2
Aug 07 03:35:12 nano nvpmodel[4929]: NVPM ERROR: failed to read PARAM GPU: ARG FREQ_TABLE: PATH /sys/devices/gpu.0/devfreq/57000000.gpu/available_frequencies
Aug 07 03:35:12 nano nvpmodel[4929]: NVPM ERROR: Error opening /sys/devices/gpu.0/power/control: 2
Aug 07 03:35:12 nano nvpmodel[4929]: NVPM ERROR: failed to write PARAM GPU_POWER_CONTROL_DISABLE: ARG GPU_PWR_CNTL_DIS: PATH: /sys/devices/gpu.0/power/control VAL: auto
Aug 07 03:35:12 nano nvpmodel[4929]: NVPM ERROR: failed to set power mode!
Aug 07 03:35:12 nano nvpmodel[4929]: NVPM ERROR: optMask is 2, no request for power mode
Aug 07 03:35:12 nano systemd[1]: nvpmodel.service: Main process exited, code=exited, status=255/n/a
Aug 07 03:35:12 nano systemd[1]: nvpmodel.service: Failed with result ‘exit-code’.
Aug 07 03:35:12 nano systemd[1]: Failed to start nvpmodel service.
