NVPModel throws NVPM Error:
I encountered the following issue: A restart does not help.
root@agx-orin:~# /usr/sbin/nvpmodel -f /etc/nvpmodel.conf --verbose
NVPM VERB: Config file: /etc/nvpmodel.conf
NVPM VERB: parsing done for /etc/nvpmodel.conf
NVPM VERB: set power mode as MODE_30W(2) in /etc/nvpmodel.conf.
NVPM ERROR: Error writing 240 to /sys/devices/gpu.0/tpc_pg_mask: 16
NVPM WARN: Reboot required for changing to this power mode: 2
NVPM WARN: DO YOU WANT TO REBOOT NOW? enter YES/yes to confirm:
root@agx-orin:~# cat /var/lib/nvpmodel/status
pmode:0002
The filesystem is read-only .
Is this error critical?
How can I reduce this error
Hi brundli,
but it seems you have root permission with #
Please share your /etc/nvpmodel.conf for further check.
