Hi everyone,
I have errors using nvpm.
my command : sudo nvpmodel -m 0
--------error ouput ------
NVPM ERROR: Error opening /sys/devices/platform/tegra-fuse/opt_tpc_disable: 2
NVPM ERROR: Error writing quiet to /sys/bus/platform/devices/pwm-fan/fan_profile: 22
NVPM ERROR: Fan failed to set mode:quiet
thank you in advance
ryuhj0915,
May I know which release are you using? I don’t hit such error when using nvpmodel with mode 0.
Do you have below node?
Yes, fan_profile file exists.
the content of the ‘fan_profile’ is “N/A”
Same here.
Can turn on/off the fan, but can’t change the fan profile to cool.
@gschimmel,
Please provide the release and hardware you are using. Do you hit the exact same error message as #1?
Hi there, thanks for your answer.
I’m on Jetson Xavier 16GB, Jetpack 4.3.
Same error here.
root@localhost:~# nvpmodel -m 0
root@localhost:~#
Trying to write to /sys/devices didn’t work either.
Regards
Sorry for late reply. Do you only have one xavier? Just want to make sure whether this is a hardware problem or not.
Unfortunately, I have only one.
In the future I’ll have several to test.
If in the meantime is there anything I can try, please let me know.
thanks a lot
