NVPOWER ERROR (write_int:170): Failed to open empty file! (Bad address)
xavier nx syslog show message:
Nov 7 06:03:12 tegra-ubuntu nvfancontrol[522]: NVPOWER ERROR (write_int:170): Failed to open empty file! (Bad address)
Nov 7 06:03:12 tegra-ubuntu nvfancontrol[522]: NVFAN WARN: Unable to set Fan PWM for FAN1
My nx application does not require an external fan, how can I disable this log output.
Hi 924908681,
Are you using the devkit or custom board for Xavier NX?
Could you try the following command to disable nvfanctrol service?
$ systemctl stop nvfancontrol
