Hi NV_Team,
When we enable MAXN for Xavier using JetPack4.5, get an error, can you help to check about it on JetPack4.5 ? If we change to other JetPack version doesn’t get this error.
nvidia@xavier:~$ sudo nvpmodel -m 0
NVPM ERROR: Error opening /sys/devices/14000000.tegra-cvnas/clk_cap: 2
NVPM ERROR: failed to write PARAM CVNAS: ARG MAX_FREQ: PATH: /sys/devices/14000000.tegra-cvnas/clk_cap VAL: 2147483647
NVPM ERROR: failed to set power mode!
NVPM ERROR: optMask is 1, no request for power mode
I compared the /etc/nvpmodel.conf file between JetPack4.5 and JetPack4.4, find the difference, and change ‘CVNAS’ setting to JetPack4.4 then ‘nvpmodel -m 0’ works fine.
JetPack4.5
< PARAM TYPE=CLOCK NAME=CVNAS >
MAX_FREQ /sys/devices/14000000.tegra-cvnas/clk_cap
JetPack4.4 and before
MAX_FREQ /sys/kernel/nvpmodel_emc_cap/nafll_cvnas
MAX_FREQ_KNEXT /sys/kernel/nvpmodel_emc_cap/nafll_cvnas
hello Luna2020,
may I know is this also happened when toggle with GUI selection?
thanks
Hi Jerry,
If toggle MAXN with GUI there is no error display.
Hi Luna2020,
We don’t see this issue with JP-4.5 on Xavier.
$ sudo nvpmodel -q
NV Fan Mode:quiet
NV Power Mode: MAXN
0
$ cat /etc/nv_tegra_release
# R32 (release), REVISION: 5.0, GCID: 25531747, BOARD: t186ref, EABI: aarch64, DATE: Fri Jan 15 23:21:05 UTC 2021
Hi Carolyuu,
On my Xavier there is an error, I check the dmesg error log “[ 11.892870] tegra-cvnas: probe of 14000000.tegra-cvnas failed with error -2”
nvidia@xavier:~$ sudo nvpmodel -q
NV Fan Mode:quiet
NV Power Mode: MAXN
0
NVPM ERROR: failed to read PARAM CVNAS: ARG MAX_FREQ: PATH /sys/devices/14000000.tegra-cvnas/clk_cap
nvidia@xavier:~$ cat /etc/nv_tegra_release
hello Luna2020,
would like to confirm how you flash the image,
are you using OTA process to move to JetPack-4.5, or you’re install that with SDKManager?
Hi Jerry,
I download the L4T and RootFS packages and unzip using command to flash the whole image “sudo ./flash.sh jetson-xavier mmcblk0p1”. Not using OTA and SDKManager.
hello Luna2020,
did you also perform the apply_binaries.sh script to copy the NVIDIA user space libraries into the target file system?
please check developer guide, Setting Up the Root File System for reference,
thanks
Hi Jerry,
I find the root cause, because I modified the tegra194-soc-base.dtsi file “cvnas” phase.
Thanks for you support information.
