nvprof fails with TensorRT inference task
I am using nvprof to analyse the compute and data transfer performance of P4 on
GoogleNet pre-trained network .
If I run TensorRT without nvprof the inference engine is generated and I can see the smi and giexec log.
For some reason when i run the same giexec with nvporf options it gets stuck and eventually crashes.
Here are the nvprof options i used :
nvprof --events all --print-gpu-trace --system-profiling on -u ms --log-file my_file_%p.log (followed by giexec command)
Is this an nvprof bug, or a certain configuration flag/plug (to nvprof) that I am missing?
Thanks for your help.
Hi, g.amardeep
This looks like the well-known slowdown caused due to kernel serialization.
Suggest you run the application using nvprof for a couple of minutes and then kill it. You should get usable results.
Please also refer answer in https://devtalk.nvidia.com/default/topic/1015752/b/t/post/5184891/?offset=7#5186940
