Nvprof issue when profiling docker + pytorch / tensorRT on AGX Xavier
On AGX Xavier, I want to profile my pytorch1.7 / tensorRT code in docker, to check GPU, DLA, TensorCore usage with nvprof. However, I got the error message:
======== Warning: No CUDA application was profiled, exiting
Both pytorch and tensorRT application show the same error message.
Experiment environment:
The pytorch 1.7 docker image is l4t-pytorch:r32.5.0-pth1.7-py3:
Also I try python 1.9 in docker, but not works
Jetpack version is 4.5
CUDA version is 10.2
Command to reproduce the issue:
use nvprof to profile the whole docker+python:
sudo nvprof (run docker to execute python application)
or
run nvprof inside docker:
run docker, and use sudo nvprof execute_python_application inside
both gives the same error.
The python code is as follows:
import torchvision.models as models
import torch
print(torch.cuda.is_available() ) ## return True
import torch.cuda.profiler as profiler
import pyprof
pyprof.init()
with torch.autograd.profiler.emit_nvtx():
profiler.start()
a = torch.ones(5,5).cuda()
b = torch.ones(5,5).bool().cuda()
c = a + b
d = a+ a
print(c)
print(d)
model = models.resnet18().cuda()
inputs = torch.randn(5, 3, 224, 224).cuda()
profiler.stop()
Just check nvprof within l4t-pytorch:r32.5.0-pth1.7-py3.
It works well in our environment.
Could you check it again?
$ sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-pytorch:r32.5.0-pth1.7-py3
root@nvidia-desktop:/# nvprof /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/mnist/mnist.onnx
&&&& RUNNING TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/mnist/mnist.onnx
[07/08/2021-07:27:11] [I] === Model Options ===
[07/08/2021-07:27:11] [I] Format: ONNX
[07/08/2021-07:27:11] [I] Model: /usr/src/tensorrt/data/mnist/mnist.onnx
[07/08/2021-07:27:11] [I] Output:
[07/08/2021-07:27:11] [I] === Build Options ===
[07/08/2021-07:27:11] [I] Max batch: 1
[07/08/2021-07:27:11] [I] Workspace: 16 MB
[07/08/2021-07:27:11] [I] minTiming: 1
[07/08/2021-07:27:11] [I] avgTiming: 8
[07/08/2021-07:27:11] [I] Precision: FP32
[07/08/2021-07:27:11] [I] Calibration:
[07/08/2021-07:27:11] [I] Safe mode: Disabled
[07/08/2021-07:27:11] [I] Save engine:
[07/08/2021-07:27:11] [I] Load engine:
[07/08/2021-07:27:11] [I] Builder Cache: Enabled
[07/08/2021-07:27:11] [I] NVTX verbosity: 0
[07/08/2021-07:27:11] [I] Inputs format: fp32:CHW
[07/08/2021-07:27:11] [I] Outputs format: fp32:CHW
[07/08/2021-07:27:11] [I] Input build shapes: model
[07/08/2021-07:27:11] [I] Input calibration shapes: model
[07/08/2021-07:27:11] [I] === System Options ===
[07/08/2021-07:27:11] [I] Device: 0
[07/08/2021-07:27:11] [I] DLACore:
[07/08/2021-07:27:11] [I] Plugins:
[07/08/2021-07:27:11] [I] === Inference Options ===
[07/08/2021-07:27:11] [I] Batch: 1
[07/08/2021-07:27:11] [I] Input inference shapes: model
[07/08/2021-07:27:11] [I] Iterations: 10
[07/08/2021-07:27:11] [I] Duration: 3s (+ 200ms warm up)
[07/08/2021-07:27:11] [I] Sleep time: 0ms
[07/08/2021-07:27:11] [I] Streams: 1
[07/08/2021-07:27:11] [I] ExposeDMA: Disabled
[07/08/2021-07:27:11] [I] Spin-wait: Disabled
[07/08/2021-07:27:11] [I] Multithreading: Disabled
[07/08/2021-07:27:11] [I] CUDA Graph: Disabled
[07/08/2021-07:27:11] [I] Skip inference: Disabled
[07/08/2021-07:27:11] [I] Inputs:
[07/08/2021-07:27:11] [I] === Reporting Options ===
[07/08/2021-07:27:11] [I] Verbose: Disabled
[07/08/2021-07:27:11] [I] Averages: 10 inferences
[07/08/2021-07:27:11] [I] Percentile: 99
[07/08/2021-07:27:11] [I] Dump output: Disabled
[07/08/2021-07:27:11] [I] Profile: Disabled
[07/08/2021-07:27:11] [I] Export timing to JSON file:
[07/08/2021-07:27:11] [I] Export output to JSON file:
[07/08/2021-07:27:11] [I] Export profile to JSON file:
==13== NVPROF is profiling process 13, command: /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/mnist/mnist.onnx
==13== Warning: Unified Memory Profiling is not supported on the underlying platform. System requirements for unified memory can be found at: http://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#um-requirements
Input filename:   /usr/src/tensorrt/data/mnist/mnist.onnx
ONNX IR version:  0.0.3
Opset version:    8
Producer name:    CNTK
Producer version: 2.5.1
Domain:           ai.cntk
Model version:    1
Doc string:
[07/08/2021-07:27:13] [W] [TRT] onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[07/08/2021-07:27:13] [I] [TRT]
[07/08/2021-07:27:13] [I] [TRT] --------------- Layers running on DLA:
[07/08/2021-07:27:13] [I] [TRT] --------------- Layers running on GPU:
[07/08/2021-07:27:13] [I] [TRT] Convolution28 + ReLU32, Pooling66, Convolution110 + ReLU114, Pooling160, Times212_reshape0, (Unnamed Layer* 0) [Constant] + Times212_reshape1, Times212, (Unnamed Layer* 16) [Constant], Plus214,
[07/08/2021-07:27:19] [I] [TRT] Detected 1 inputs and 1 output network tensors.
[07/08/2021-07:27:19] [I] Starting inference threads
[07/08/2021-07:27:22] [I] Warmup completed 704 queries over 200 ms
[07/08/2021-07:27:22] [I] Timing trace has 14249 queries over 3.00022 s
[07/08/2021-07:27:22] [I] Trace averages of 10 runs:
[07/08/2021-07:27:22] [I] Average on 10 runs - GPU latency: 0.173114 ms - Host latency: 0.214737 ms (end to end 0.231467 ms, enqueue 0.167886 ms)
[07/08/2021-07:27:22] [I] Average on 10 runs - GPU latency: 0.135132 ms - Host latency: 0.166333 ms (end to end 0.184473 ms, enqueue 0.130078 ms)
[07/08/2021-07:27:22] [I] Host Latency
[07/08/2021-07:27:22] [I] min: 0.147217 ms (end to end 0.160156 ms)
[07/08/2021-07:27:22] [I] max: 1.11505 ms (end to end 1.14252 ms)
[07/08/2021-07:27:22] [I] mean: 0.175534 ms (end to end 0.189888 ms)
[07/08/2021-07:27:22] [I] median: 0.169189 ms (end to end 0.18335 ms)
[07/08/2021-07:27:22] [I] percentile: 0.237671 ms at 99% (end to end 0.255768 ms at 99%)
[07/08/2021-07:27:22] [I] throughput: 4749.33 qps
[07/08/2021-07:27:22] [I] walltime: 3.00022 s
[07/08/2021-07:27:22] [I] Enqueue Time
[07/08/2021-07:27:22] [I] min: 0.115234 ms
[07/08/2021-07:27:22] [I] max: 1.05127 ms
[07/08/2021-07:27:22] [I] median: 0.132568 ms
[07/08/2021-07:27:22] [I] GPU Compute
[07/08/2021-07:27:22] [I] min: 0.119873 ms
[07/08/2021-07:27:22] [I] max: 1.05804 ms
[07/08/2021-07:27:22] [I] mean: 0.142931 ms
[07/08/2021-07:27:22] [I] median: 0.137512 ms
[07/08/2021-07:27:22] [I] percentile: 0.195297 ms at 99%
[07/08/2021-07:27:22] [I] total compute time: 2.03662 s
&&&& PASSED TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/mnist/mnist.onnx
==13== Profiling application: /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/mnist/mnist.onnx
==13== Profiling result:
            Type  Time(%)      Time     Calls       Avg       Min       Max  Name
 GPU activities:   25.68%  95.707ms     15113  6.3320us  5.9200us  19.009us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=4, int=4, int=1, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                   24.22%  90.243ms     15033  6.0020us  5.8250us  10.784us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=3, int=5, int=4, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                   10.43%  38.874ms     14953  2.5990us  2.5600us  6.0810us  void gemv2N_kernel<int, int, float, float, float, int=128, int=32, int=4, int=4, int=1, cublasGemvParams<cublasGemvTensorStridedBatched<float const >, cublasGemvTensorStridedBatched<float>, float>>(float const )
                    9.62%  35.856ms     15337  2.3370us  1.8240us  4.9920us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=3, int=3, int=1, int=1, int=1, int=1, int=192, int=1, int=1, bool=0, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    8.92%  33.248ms     14985  2.2180us  2.1440us  4.3200us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=32, int=256, int=6, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    6.16%  22.967ms     14953  1.5350us  1.5040us  3.4880us  void cuEltwise::eltwise<cuEltwise::SimpleAlgo<float, float>, cuEltwise::Compute<nvinfer1::ElementWiseOperation>>(cuEltwise::LaunchParams)
                    2.39%  8.9193ms     15131     589ns     288ns  1.5360us  [CUDA memcpy HtoD]
                    1.81%  6.7616ms     14953     452ns     352ns     833ns  [CUDA memcpy DtoH]
                    0.71%  2.6287ms       152  17.293us  5.5050us  32.130us  void cudnn::cnn::conv2d_grouped_direct_kernel<float, float, float, float, float, float, bool=1, bool=0, int=0, int=0, int=0>(cudnnTensorStruct, float const *, cudnnFilterStruct, float const *, cudnnConvolutionStruct, cudnn::cnn::conv2d_grouped_direct_kernel<float, float, float, float, float, float, bool=1, bool=0, int=0, int=0, int=0>, float*, float, float*, cudnn::reduced_divisor, float, float, float, float, int, cudnnConvolutionStruct const *, float const *, cudnnActivationStruct)
                    0.46%  1.6965ms        80  21.206us  9.0240us  41.667us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=4>, fused::KpqkPtrWriter<float, int=1, int=1, int=4>, float, float, int=5, int=3, int=1, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.45%  1.6695ms        56  29.812us  14.305us  54.115us  trt_volta_scudnn_128x128_relu_xregs_large_nn_v1
                    0.45%  1.6605ms        56  29.651us  14.337us  53.476us  trt_volta_scudnn_128x128_relu_medium_nn_v1
                    0.43%  1.5870ms        64  24.796us  11.841us  42.147us  trt_volta_scudnn_128x64_relu_medium_nn_v1
                    0.41%  1.5414ms        56  27.525us  13.537us  51.332us  trt_volta_scudnn_128x128_relu_small_nn_v1
                    0.41%  1.5291ms       160  9.5570us  6.4960us  17.025us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=2, int=5, int=1, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.41%  1.5287ms        64  23.886us  11.809us  41.315us  trt_volta_scudnn_128x64_relu_xregs_large_nn_v1
                    0.35%  1.3042ms        64  20.378us  10.144us  36.099us  trt_volta_scudnn_128x32_relu_small_nn_v1
                    0.35%  1.2978ms        51  25.448us     352ns  210.35us  [CUDA memset]
                    0.34%  1.2791ms        64  19.985us  10.785us  35.939us  trt_volta_scudnn_128x64_relu_small_nn_v1
                    0.27%  997.04us        80  12.462us  6.8480us  23.074us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=3, int=5, int=1, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.26%  966.28us        40  24.156us  22.049us  32.418us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=4>, fused::KpqkPtrWriter<float, int=1, int=1, int=4>, float, float, int=5, int=3, int=2, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.25%  941.51us        80  11.768us  7.9360us  21.858us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=5, int=5, int=1, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.21%  799.61us        32  24.987us  19.969us  30.210us  void gemv2N_kernel<int, int, float2, float2, float2, int=128, int=8, int=4, int=4, int=1, cublasGemvParams<cublasGemvTensorStridedBatched<float2 const >, cublasGemvTensorStridedBatched<float2>, float2>>(float2 const )
                    0.21%  797.11us        80  9.9630us  9.5690us  13.761us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=2, int=5, int=2, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.21%  773.18us        80  9.6640us  6.9760us  17.057us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=5, int=2, int=1, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.20%  752.66us        80  9.4080us  6.7840us  15.105us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=2, int=4, int=1, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.20%  729.40us        48  15.195us  8.0000us  31.554us  trt_volta_scudnn_128x32_relu_medium_nn_v1
                    0.19%  714.89us        40  17.872us  16.481us  24.066us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=4, int=5, int=2, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.19%  698.74us        80  8.7340us  8.3520us  11.425us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=3, int=5, int=8, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.18%  666.35us        80  8.3290us  6.6880us  13.409us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=3, int=4, int=1, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.17%  649.46us       184  3.5290us  3.1040us  4.8640us  void op_generic_tensor_kernel<int=3, float, float, float, int=256, cudnnGenericOp_t=0, cudnnNanPropagation_t=0, int=0>(cudnnTensorStruct, float*, cudnnTensorStruct, float const *, cudnnTensorStruct, float const *, float, float, float, float, reducedDivisorArray, int)
                    0.17%  628.91us        80  7.8610us  6.2410us  11.584us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=2, int=4, int=1, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.17%  619.38us       184  3.3660us  3.0410us  4.0970us  void op_generic_tensor_kernel<int=1, float, float, float, int=256, cudnnGenericOp_t=8, cudnnNanPropagation_t=1, int=1>(cudnnTensorStruct, float*, cudnnTensorStruct, float const *, cudnnTensorStruct, float const *, float, float, float, float, reducedDivisorArray, int)
                    0.16%  603.50us        40  15.087us  14.529us  19.009us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=4>, fused::KpqkPtrWriter<float, int=1, int=1, int=4>, float, float, int=3, int=4, int=8, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.14%  519.94us        40  12.998us  12.609us  17.057us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=4>, fused::KpqkPtrWriter<float, int=1, int=1, int=4>, float, float, int=3, int=5, int=8, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.13%  470.46us        40  11.761us  10.720us  18.945us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=2, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=2, int=6, int=2, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=2, int=1Type>)
                    0.11%  405.50us        40  10.137us  9.7610us  15.938us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=5, int=5, int=2, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.11%  393.88us        40  9.8470us  9.5050us  11.841us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=2, int=3, int=2, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.10%  372.86us        40  9.3210us  9.0250us  11.745us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=4, int=4, int=8, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.10%  371.55us        40  9.2880us  8.9610us  14.529us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=6, int=4, int=2, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.10%  368.57us        40  9.2140us  8.7370us  11.904us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=4, int=4, int=2, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.10%  365.46us        40  9.1360us  8.8320us  10.657us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=4, int=3, int=8, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.10%  363.90us        40  9.0970us  8.7370us  11.969us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=6, int=5, int=8, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.10%  356.05us        40  8.9010us  8.6090us  11.712us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=5, int=6, int=8, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.09%  353.14us        40  8.8280us  8.4490us  11.392us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=5, int=3, int=8, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.09%  352.41us        40  8.8100us  7.9690us  13.281us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=3, int=5, int=4, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.09%  344.98us        40  8.6240us  8.2880us  10.337us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=2, int=4, int=4, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.09%  342.55us        40  8.5630us  8.2570us  12.417us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=3, int=5, int=2, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.09%  341.69us        40  8.5420us  8.2250us  13.761us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=2, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=2, int=5, int=4, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=2, int=1Type>)
                    0.09%  340.28us        40  8.5060us  8.2560us  13.537us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=5, int=4, int=2, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.09%  335.32us        40  8.3820us  7.9040us  11.393us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=2>, fused::KpqkPtrWriter<float, int=1, int=1, int=2>, float, float, int=2, int=5, int=4, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.09%  335.13us        40  8.3780us  7.9370us  12.833us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=5, int=5, int=4, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.09%  324.92us        40  8.1230us  7.7440us  11.873us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=4, int=6, int=4, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.08%  306.87us        40  7.6710us  7.3290us  10.369us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=4, int=6, int=8, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.08%  304.34us        32  9.5100us  4.8640us  15.553us  void fft2d_r2c_32x32<float, bool=0, unsigned int=5, bool=1>(float2*, float const *, int, int, int, int, int, int, int, int, int, cudnn::reduced_divisor, bool, int2, int, int)
                    0.08%  290.67us        40  7.2660us  6.6560us  10.656us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=4, int=5, int=4, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.07%  271.76us        40  6.7940us  6.4640us  8.2890us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=3, int=4, int=8, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.07%  267.54us        40  6.6880us  6.3690us  9.0560us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=4, int=4, int=4, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.07%  260.59us        16  16.287us  15.201us  18.049us  void fft2d_r2c_32x32<float, bool=0, unsigned int=1, bool=0>(float2*, float const *, int, int, int, int, int, int, int, int, int, cudnn::reduced_divisor, bool, int2, int, int)
                    0.07%  255.28us        40  6.3820us  6.0160us  8.7370us  void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1, int=1>, float, float, int=4, int=4, int=8, int=5, int=5, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
                    0.06%  206.80us        16  12.925us  12.481us  13.217us  void fft2d_c2r_32x32<float, bool=0, bool=0, unsigned int=1, bool=0, bool=0>(float*, float2 const *, int, int, int, int, int, int, int, int, int, float, float, cudnn::reduced_divisor, bool, float*, float*, int2, int, int)
                    0.05%  183.18us        64  2.8620us  2.4640us  8.3200us  void pooling_fw_4d_kernel<float, float, cudnn::maxpooling_func<float, cudnnNanPropagation_t=0>, int=0, bool=0>(cudnnTensorStruct, float const *, cudnnTensorStruct, float*, cudnnPoolingStruct, float, float, int, cudnn::reduced_divisor, cudnn::reduced_divisor)
                    0.04%  136.97us        64  2.1400us  1.9520us  4.3530us  void CUTENSOR_NAMESPACE::tensor_elementwise_kernel<CUTENSOR_NAMESPACE::pw_config_t<unsigned int=1, int=256, unsigned int=64, unsigned int=1, unsigned int=0, unsigned int=1, unsigned int=2, unsigned int=0, unsigned int=1, unsigned int=2>, float, float, float, float, bool=1, cutensorOperator_t=1, cutensorOperator_t, cutensorOperator_t, cutensorOperator_t, cutensorOperator_t>(CUTENSOR_NAMESPACE::pw_params_t, int, int, unsigned int=0, int=256 const *, CUTENSOR_NAMESPACE::pw_params_t, unsigned int=64 const *, CUTENSOR_NAMESPACE::pw_params_t, unsigned int=1 const *, unsigned int=64 const **, cutensorOperator_t, void const *, cutensorOperator_t, void const , cutensorOperator_t, void const , cutensorOperator_t, void const , cutensorOperator_t, void const )
                    0.03%  93.960us        16  5.8720us  5.4720us  11.169us  void fft2d_c2r_32x32<float, bool=0, bool=0, unsigned int=0, bool=0, bool=0>(float*, float2 const *, int, int, int, int, int, int, int, int, int, float, float, cudnn::reduced_divisor, bool, float*, float*, int2, int, int)
                    0.02%  87.590us        32  2.7370us  2.3360us  4.2570us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=32, int=256, int=7, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  83.044us        64  1.2970us  1.1200us  2.3370us  [CUDA memcpy DtoD]
                    0.02%  82.275us        32  2.5710us  2.2720us  4.3200us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=16, int=128, int=7, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  79.400us        32  2.4810us  2.2720us  4.7370us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=32, int=256, int=8, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  78.151us        32  2.4420us  2.2410us  4.4170us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=16, int=128, int=8, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  77.703us        32  2.4280us  2.2400us  3.3280us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=32, int=256, int=1, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  77.158us        16  4.8220us  4.1600us  11.201us  void fft2d_r2c_32x32<float, bool=0, unsigned int=0, bool=0>(float2*, float const *, int, int, int, int, int, int, int, int, int, cudnn::reduced_divisor, bool, int2, int, int)
                    0.02%  76.741us        32  2.3980us  2.2400us  4.2880us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=16, int=128, int=5, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  76.355us        32  2.3860us  2.2400us  3.8400us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=32, int=256, int=5, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  75.720us        32  2.3660us  1.9840us  3.8080us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=32, int=256, int=4, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  75.717us        32  2.3660us  2.1120us  3.8400us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=16, int=128, int=1, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  75.461us        32  2.3580us  1.9840us  3.4880us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=32, int=256, int=3, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  75.426us        32  2.3570us  2.1760us  3.5520us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=16, int=128, int=6, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  75.367us        32  2.3550us  2.0480us  3.3600us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=16, int=128, int=4, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  74.565us        32  2.3300us  1.9840us  3.5840us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=32, int=256, int=2, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  73.764us        32  2.3050us  1.9200us  3.3920us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=16, int=128, int=3, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.02%  71.654us        32  2.2390us  1.8250us  3.4560us  void nvinfer1::tiled_pooling::poolCHW_PQT<int=2, int=2, int=2, int=2, int=2, int=16, int=128, int=2, int=1, bool=1, nvinfer1::ITiledPooling::PoolingMode, bool=0>(nvinfer1::TiledPoolingParams, int)
                    0.01%  42.308us        16  2.6440us  2.0480us  5.7600us  cask_trt::computeOffsetsKernel(cask_trt::ComputeOffsetsParams)
      API calls:   26.28%  2.64881s       239  11.083ms  1.4400us  1.62312s  cudaFree
                   24.83%  2.50279s     94078  26.603us  12.512us  1.05240s  cudaLaunchKernel
                   15.86%  1.59868s     18833  84.887us  1.5040us  1.2079ms  cudaEventSynchronize
                   12.42%  1.25163s        24  52.151ms  2.3040us  1.25152s  cudaStreamCreateWithFlags
                    7.91%  796.93ms       176  4.5280ms  10.113us  62.489ms  cuModuleUnload
                    4.37%  440.12ms    112755  3.9030us  1.2800us  726.21us  cudaEventRecord
                    3.62%  364.81ms     30110  12.116us  9.0880us  88.420us  cudaMemcpyAsync
                    1.76%  177.53ms    108551  1.6350us  1.0880us  962.42us  cudaEventElapsedTime
                    1.16%  116.85ms      3880  30.116us  14.017us  349.11us  cudaStreamAddCallback
                    0.70%  70.322ms     30451  2.3090us  1.5360us  51.011us  cudaStreamWaitEvent
                    0.54%  53.944ms    112959     477ns     224ns  775.43us  cudaGetLastError
                    0.37%  37.773ms     14953  2.5260us  1.7280us  45.026us  cudaOccupancyMaxActiveBlocksPerMultiprocessorWithFlags
                    0.06%  6.3658ms       214  29.746us  6.9120us  370.51us  cudaMalloc
                    0.02%  1.6867ms        51  33.072us  7.6480us  82.916us  cudaMemsetAsync
                    0.01%  1.1697ms       540  2.1660us  1.2160us  23.873us  cudaFuncSetAttribute
                    0.01%  1.1666ms        32  36.454us  29.665us  60.611us  cudaMemcpy2DAsync
                    0.01%  753.93us        57  13.226us  8.1280us  34.017us  cudaCreateTextureObject
                    0.01%  744.84us       241  3.0900us     704ns  67.043us  cudaDeviceGetAttribute
                    0.01%  697.48us       473  1.4740us     512ns  65.123us  cuDeviceGetAttribute
                    0.01%  666.72us       113  5.9000us  4.4170us  23.905us  cudaStreamSynchronize
                    0.01%  649.34us         3  216.45us  76.740us  366.48us  cudaHostAlloc
                    0.01%  580.73us       204  2.8460us  1.0880us  48.642us  cudaEventDestroy
                    0.01%  566.17us       172  3.2910us  1.1520us  32.994us  cudaEventCreateWithFlags
                    0.01%  520.22us         5  104.04us  27.617us  221.20us  cudaFreeHost
                    0.00%  472.25us        57  8.2850us  3.8400us  27.362us  cudaDestroyTextureObject
                    0.00%  469.49us        11  42.681us  19.777us  90.308us  cudaGetDeviceProperties
                    0.00%  429.43us         7  61.347us  1.1200us  96.741us  cudaMemcpy
                    0.00%  274.51us        12  22.875us  2.2720us  243.40us  cudaStreamCreateWithPriority
                    0.00%  235.72us        40  5.8930us  2.3680us  45.122us  cudaStreamDestroy
                    0.00%  154.95us        24  6.4560us  2.9760us  14.113us  cudaDeviceSynchronize
                    0.00%  148.20us        32  4.6310us  3.3920us  9.1840us  cudaEventCreate
                    0.00%  129.80us         3  43.265us  8.3840us  66.435us  cudaHostGetDevicePointer
                    0.00%  114.98us        23  4.9990us  1.0880us  18.209us  cudaGetDevice
                    0.00%  91.109us         1  91.109us  91.109us  91.109us  cudaLaunchHostFunc
                    0.00%  83.621us         5  16.724us  8.6410us  23.137us  cuDeviceTotalMem
                    0.00%  73.828us         4  18.457us  5.5050us  45.474us  cudaStreamCreate
                    0.00%  71.299us         2  35.649us  28.129us  43.170us  cudaSetDevice
                    0.00%  70.308us         2  35.154us  27.361us  42.947us  cudaMallocHost
                    0.00%  67.683us        57  1.1870us     384ns  22.562us  cudaCreateChannelDesc
                    0.00%  33.505us         4  8.3760us  7.2000us  10.016us  cuInit
                    0.00%  23.042us         4  5.7600us  2.7520us  11.233us  cuDriverGetVersion
                    0.00%  17.985us        10  1.7980us     480ns  9.1200us  cudaGetDeviceCount
                    0.00%  13.760us         7  1.9650us  1.2800us  3.2640us  cuDeviceGetCount
                    0.00%  8.8330us         5  1.7660us  1.2800us  2.4640us  cuDeviceGetName
                    0.00%  8.4480us         3  2.8160us  2.0800us  4.2560us  cudaDeviceGetStreamPriorityRange
                    0.00%  7.8080us         6  1.3010us     928ns  1.9840us  cuDeviceGet
                    0.00%  7.0720us         2  3.5360us  3.5200us  3.5520us  cuDevicePrimaryCtxRelease
                    0.00%  4.9920us         5     998ns     832ns  1.3120us  cuDeviceGetUuid
                    0.00%  4.9280us         7     704ns     512ns     960ns  cudaRuntimeGetVersion
Thanks a lot.
After trying trtrexec, the problem is finally solved.
There are some steps:
1.
use sudo before nvprof, or nvprof won’t give correct profiling result.
use sudo /usr/local/cuda/bin/nvprof instead of sudo nvprof.
The system can find nvprof command, but not sudo nvprof. However, sudo /usr/local/cuda/bin/nvprof works.
I think after resolving the permission issue, nvprof will work inside docker. Though I haven’t try yet.
