NvRmMemInitNvmap failed with Permission denied when pyds launched in docker without sudo
Setup info
• Hardware Platform (Jetson / GPU) Jetson AGX Orin
• DeepStream Version 6.2 (inside of docker)
• JetPack Version (valid for Jetson only) 5.1.1 (L4T 35.3.1)
• Issue Type( questions, new requirements, bugs) BUG
Problem
When I try to launch deepstream apps or try to import pyds in python I get NvRmMemInitNvmap failed with Permission denied
Reproduction
Build docker:
FROM nvcr.io/nvidia/deepstream-l4t:6.2-base
# Usefull tools, apps and libraries
RUN apt-get update && apt install -y \
    g++ gcc git automake \
    ffmpeg wget sudo htop x11-apps nano xonsh \
    libopenmpt-dev python3-pip python3-gi
RUN useradd -ms /bin/bash -G sudo myuser && echo "myuser ALL=(ALL) NOPASSWD: ALL" > /etc/sudoers.d/ubuntu
ENV TERM=xterm-256color
USER myuser
WORKDIR /home/myuser
RUN sudo apt install -y libcairo2-dev
RUN wget https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/releases/download/v1.1.6/pyds-1.1.6-py3-none-linux_aarch64.whl && \
    pip3 install ./pyds-1.1.6-py3-none-linux_aarch64.whl
# TAG v1.1.6 is meant for deepstream 6.2
docker build --tag pyds-jetson .
Run docker:
docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.3 -v /tmp/.X11-unix/:/tmp/.X11-unix pyds-jetson:latest
Open python and try to import pyds
myuser@ubuntu:~$ python3
Python 3.8.10 (default, Nov 22 2023, 10:22:35)
[GCC 9.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import pyds
549: Memory Manager Not supported
****NvRmMemInit failed**** error type: 196626
*** NvRmMemInit failed NvRmMemConstructor
The only way to avoid this problem is to install pyds and launch it with sudo.
I tried to run it wich changed -u flag like in NvRmMemInitNvmap failed with Permission denied - #7
But it did not help
Since my AGX Orin has been upgraded, I tried to reproduce the problem on the DS-6.3 and DS-6.4 versions.
If I use the DS-6.4 version and modify the dockerfile to have the following. It work fine.
FROM nvcr.io/nvidia/deepstream-l4t:6.4-triton-multiarch
# pyds to the 1.1.10 verion
pyds-1.1.10-py3-none-linux_aarch64.whl
If I use nvcr.io/nvidia/deepstream:6.3-triton-multiarch with pyds-1.1.8, I will be able to reproduce the problem.
So there are two ways to solve this problem
1.Upgrade to Jetpack 6.0 and DS-6.4
2.Change your dockerfile like below, I have tried this and it works perfectly
RUN useradd -ms /bin/bash -G sudo,audio,video,render myuser && echo "myuser ALL=(ALL) NOPASSWD: ALL" > /etc/sudoers.d/ubuntu
By the way
You can use groups “your host user” to get the groups to which the host user belongs and add myuser to them
Thank you, this solves my issue.
That’s great you provided 2 solutions both of them will be useful for my team.
