Nvrtc compiler summary
one simple question regarding the output of the nvrtc compiler. With cuda version 9 or 10 (not sure) the nvrtc compiler prints some useful information to the compiler output window (Windows/VS2022). It shows information like global/shared/const memory usage, registers per kernel and much more. Is there any way to get this information back with the latest nvrtc?
Thanks a lot.
I think for those things you would want to specify the ptxas option -v . (edited for future readers, I had mistakenly used capital V)
Thanks for your reply. I’m not able to get this working. Here are the options I use - which works without the --ptxas-options option set. The last lines are the output from the compiler:
nvrtc ver: 12.3
-arch=sm_86
-D_CUDA
-D_HAVE128
-restrict
-std=c++20
-extra-device-vectorization
-device-int128
-D=_DEBUG
-lineinfo
--ptxas-options=-V
ptxas fatal : Internal error: exit status 0
Using ‘V’ as option gives a different error:
-arch=sm_61
-D_CUDA
-D_HAVE128
-restrict
-std=c++20
-device-int128
-D=_DEBUG
-lineinfo
--ptxas-options=V
ptxas fatal : Input file ‘V’ could not be opened
ptxas fatal : Ptx assembly aborted due to errors
I think it needs to be a lower case “v”.
yes, that seems to be correct - below from NVIDIA CUDA Compiler Driver:
4.2.9.1.22. --verbose (-v)
Enable verbose mode which prints code generation statistics.
4.2.9.1.23. --version (-V)
Semantics same as nvcc option --version.
For all how run into the same problem - this is the option I use and I do get what I was hoping for.
--ptxas-options=-v
Thanks to all.
