I’ve been using an NVS810 video card for over a year to drive 7 projectors. Everything worked fine until today when suddenly only 6 projectors are supported. If I plug in a 7th projector, doesn’t matter which of the Mini-DP ports I use, then suddenly ALL the projectors display a no HDMI signal message and stop working. If I unplug the 7th display, within a few seconds all the projectors are showing the desktop background color again and all is well. There have been no windows updates or hardware changes. I tried re-installing the NVS810 suitable driver, doing a cold restart etc. Nothing works. Any ideas?
Related topics
| NVS810 Display Issues on 2nd GPU | 0 | 527 | September 30, 2019 | |
| NVS 810 on 16 Displays | 0 | 777 | November 13, 2018 | |
| 367.35 - NVS 810 - Can't handle 6 Monitors | 0 | 764 | July 22, 2016 | |
| DPMS Standby not working with NVS 810 using driver 375.26 via mini-DP to DVI | 21 | 3842 | June 20, 2017 | |
| NVS 810 is not display the screens connected to 2 GPU | 4 | 1985 | January 13, 2020 | |
| Slowdown problem on multiple screens (NVS-810) | 2 | 918 | September 16, 2022 | |
| NVS 810 Setup with 8 Monitors (Displays) on UBUNTU 16.04.1 | 4 | 4500 | October 9, 2018 | |
| 2 NVS 810 Cards for 16 Displays | 0 | 1295 | November 13, 2018 | |
| "No signal" with HDMI or DP-0 ports on MacBookPro10,1 (GT 650M) -- only DP-1 works | 7 | 3525 | June 9, 2022 | |
| NVS 810 only shows 1 GPU in Windows 11 | 3 | 663 | February 4, 2026 |
