I writing a C++ program that will run on the NX using the Dev Kit board. I want to run headless and give the operator status information with LEDS driven by GPIO from the 40 pin header.
I have tried following the advice in the post How to config gpio07 as gpio and How to Enable GPIO7 and GPIO14 as PWM8 and PWM7 on Xavier-Nx module
with little luck.
The NX I am developing with shows no activity on the pins. I can export, set direction, and value through the command line without errors, but an oscope on the pins stays flat.
I tried a fresh install on a second NX and microSD, but I can only get pin32/gpio07 (424 as calculated and listed in a post) to toggle high and low NOT:
pin7/gpio09 (432 as calculated)
pin31/gpio11 (416 as calculated and listed in a post)
pin15/gpio12 (264 as calculated)
Is there something beyond the export, direction, and value writing that needs to be done to use the GPIO pins with the Dev kit?
