Nx设备无法正常启动
nx设备无法正常启动 jp4.6.2
发现桌面服务出问题了,现在没办法开机,能否确定是什么原因导致的,谢谢
Oct 27 16:03:08 lcfc-desktop nm-applet[8991]: gtk_widget_destroy: assertion 'GTK_IS_WIDGET (widget)' failed
Oct 27 16:03:08 lcfc-desktop nm-applet[8991]: Can't set a parent on widget which has a parent
Oct 27 16:03:09 lcfc-desktop NetworkManager[5708]: <info>  [1761552189.4462] device (eth1): state change: activated -> unavailable (reason 'carrier-changed', sys-iface-state: 'managed')
Oct 27 16:03:09 lcfc-desktop avahi-daemon[5335]: Withdrawing address record for 192.168.1.100 on eth1.
Oct 27 16:03:09 lcfc-desktop avahi-daemon[5335]: Leaving mDNS multicast group on interface eth1.IPv4 with address 192.168.1.100.
Oct 27 16:03:09 lcfc-desktop avahi-daemon[5335]: Interface eth1.IPv4 no longer relevant for mDNS.
Oct 27 16:03:09 lcfc-desktop avahi-daemon[5335]: Withdrawing address record for fe80::c3f4:4083:a23c:c49e on eth1.
Oct 27 16:03:09 lcfc-desktop avahi-daemon[5335]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::c3f4:4083:a23c:c49e.
Oct 27 16:03:09 lcfc-desktop avahi-daemon[5335]: Interface eth1.IPv6 no longer relevant for mDNS.
Oct 27 16:03:09 lcfc-desktop NetworkManager[5708]: <info>  [1761552189.4517] manager: NetworkManager state is now DISCONNECTED
Oct 27 16:03:09 lcfc-desktop nm-dispatcher: req:3 'down' [eth1]: new request (1 scripts)
Oct 27 16:03:09 lcfc-desktop nm-dispatcher: req:3 'down' [eth1]: start running ordered scripts...
Oct 27 16:03:09 lcfc-desktop nm-applet[8991]: gtk_widget_destroy: assertion 'GTK_IS_WIDGET (widget)' failed
Oct 27 16:03:09 lcfc-desktop nm-applet[8991]: Can't set a parent on widget which has a parent
log.zip (9.9 MB)
請問你的無法開機是真的無法開機還是沒有桌面?
你附件裡面的xorg log 一個是空的一個看起來是3個月前開機時候的log.
没办法进入系统,卡在开机的界面
麻煩請用UART 幫我確認目前的dmesg /xorg.0.log 還有df -h
在客户现场没办法接uart log,进入不了系统,没办法输入指令
ssh應該還是活的. 能用這個嗎?
ssh登录不上,也ping不通
Jetson鍵盤上按ctrl+alt + F1~F6有辦法切進console嗎?
现在系统在ssd里面
請問用戶端目前是能接上網路線來透過ssh傳出log的嗎?
如果不行的話幫我確認一下 restart gdm3會不會讓/var/log/Xorg.0.log更新
reset 之后没有更新,/var/log/Xorg.0.log还是空的
請先把gdm3 service停掉. 直接跑純粹的xinit看有沒有跑出白色視窗
如果沒有的話看一下xinit失敗的錯誤是什麼.
停掉gmd3服务之后还是无法进入系统
HI
你上面的紅字就是我要看的內容, 能請你把完整內容附上嗎?
另外說明一下, 感覺你好像沒有搞清楚… 現在的問題是gdm3起不來所以你才沒有Gnome桌面可以用.
前面提到的關掉gdm3並沒有要解決你什麼問題. 我只是想要確認跑更簡單的xinit會不會也沒辦法跑.
如何进入xinit模式
xinit目前不重要了 請你把上面我提到的紅字部份先貼出來 那邊就有系統到底發生了什麼問題的答案.
請問客戶端有什麼複製問題的手法嗎? 看起來整個系統變成read only filesystem了…
是客户端的问题,用一段时间之后导致开不了机的,不知道是什么原因。客户担心还有其他设备也会有相似的问题
