My nx cannot enter the desktop system?
Hello! Can you please help me to see how to solve the following situation? My nx directly enters the command line interface after booting, and cannot enter the desktop system? How can I solve this situation?
You’ll need to attach file “/var/log/Xorg.0.log” (whatever shows up right after the startx failure). Also, be sure to mention if your monitor is purely HDMI, versus if there is any kind of adapter.
[ 3250.711]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 3250.720] X Protocol Version 11, Revision 0
[ 3250.724] Build Operating System: Linux 4.15.0-140-generic aarch64 Ubuntu
[ 3250.727] Current Operating System: Linux nx 4.9.140-tegra #3 SMP PREEMPT Mon Aug 17 12:05:02 CST 2020 aarch64
[ 3250.727] Kernel command line: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069c000 lut_mem=0x2008@0xa0696000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 3250.740] Build Date: 08 April 2021 01:53:49PM
[ 3250.744] xorg-server 2:1.19.6-1ubuntu4.9 (For technical support please see Enterprise open source support | Ubuntu)
[ 3250.747] Current version of pixman: 0.34.0
[ 3250.753] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 3250.753] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 3250.766] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Jul 9 18:54:16 2021
[ 3250.769] (==) Using config file: “/etc/X11/xorg.conf”
[ 3250.772] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 3250.773] (==) No Layout section. Using the first Screen section.
[ 3250.773] (==) No screen section available. Using defaults.
[ 3250.773] (
) |–>Screen “Default Screen Section” (0)
[ 3250.773] () | |–>Monitor “”
[ 3250.775] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 3250.775] (
) | |–>Device “Tegra0”
[ 3250.775] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 3250.775] (==) Automatically adding devices
[ 3250.775] (==) Automatically enabling devices
[ 3250.775] (==) Automatically adding GPU devices
[ 3250.775] (==) Automatically binding GPU devices
[ 3250.775] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3250.775] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 3250.775] Entry deleted from font path.
[ 3250.775] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 3250.775] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 3250.775] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 3250.775] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 3250.775] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 3250.775] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 3250.775] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 3250.775] (II) Loader magic: 0x558a5de010
[ 3250.775] (II) Module ABI versions:
[ 3250.775] X.Org ANSI C Emulation: 0.4
[ 3250.775] X.Org Video Driver: 23.0
[ 3250.775] X.Org XInput driver : 24.1
[ 3250.775] X.Org Server Extension : 10.0
[ 3250.778] (++) using VT number 1
[ 3250.787] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 3250.793] (II) no primary bus or device found
[ 3250.793] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 3250.793] (II) “glx” will be loaded by default.
[ 3250.793] (II) LoadModule: “extmod”
[ 3250.793] (II) Module “extmod” already built-in
[ 3250.793] (II) LoadModule: “glx”
[ 3250.794] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3250.796] (II) Module glx: vendor=“X.Org Foundation”
[ 3250.796] compiled for 1.19.6, module version = 1.0.0
[ 3250.796] ABI class: X.Org Server Extension, version 10.0
[ 3250.796] (II) LoadModule: “nvidia”
[ 3250.796] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 3250.798] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 3250.798] compiled for 4.0.2, module version = 1.0.0
[ 3250.798] Module class: X.Org Video Driver
[ 3250.798] (II) NVIDIA dlloader X Driver 32.4.3 Release Build (integ_stage_rel) (buildbrain@mobile-u64-3357) Thu Jun 25 21:23:41 PDT 2020
[ 3250.798] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 3250.798] (WW) Falling back to old probe method for NVIDIA
[ 3250.798] (II) Loading sub module “fb”
[ 3250.798] (II) LoadModule: “fb”
[ 3250.798] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 3250.799] (II) Module fb: vendor=“X.Org Foundation”
[ 3250.799] compiled for 1.19.6, module version = 1.0.0
[ 3250.799] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3250.799] (II) Loading sub module “wfb”
[ 3250.799] (II) LoadModule: “wfb”
[ 3250.799] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 3250.799] (II) Module wfb: vendor=“X.Org Foundation”
[ 3250.799] (II) Loading sub module “ramdac”
[ 3250.799] (II) LoadModule: “ramdac”
[ 3250.799] (II) Module “ramdac” already built-in
[ 3250.801] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 3250.801] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 3250.801] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 3250.801] (==) NVIDIA(0): RGB weight 888
[ 3250.801] (==) NVIDIA(0): Default visual is TrueColor
[ 3250.801] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 3250.801] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 3250.801] () NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
[ 3250.801] (
) NVIDIA(0): Enabling 2D acceleration
[ 3250.802] (II) Loading sub module “glxserver_nvidia”
[ 3250.802] (II) LoadModule: “glxserver_nvidia”
[ 3250.802] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 3250.809] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 3250.809] compiled for 4.0.2, module version = 1.0.0
[ 3250.809] Module class: X.Org Server Extension
[ 3250.809] (II) NVIDIA GLX Module 32.4.3 Release Build (integ_stage_rel) (buildbrain@mobile-u64-3357) Thu Jun 25 21:22:13 PDT 2020
[ 3250.813] (–) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 3250.813] (–) NVIDIA(0): DFP-0
[ 3250.813] (–) NVIDIA(0): DFP-1
[ 3250.814] (II) NVIDIA(0): NVIDIA GPU Xavier (nvgpu) (GV11B) at SoC (GPU-0)
[ 3250.814] (–) NVIDIA(0): Memory: 7949628 kBytes
[ 3250.814] (–) NVIDIA(0): VideoBIOS:
[ 3250.814] (–) NVIDIA(GPU-0): HPN HP 24m (DFP-0): connected
[ 3250.814] (–) NVIDIA(GPU-0): HPN HP 24m (DFP-0): External TMDS
[ 3250.815] (==) NVIDIA(0):
[ 3250.815] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 3250.815] (==) NVIDIA(0): will be used as the requested mode.
[ 3250.815] (II) NVIDIA(0): Validated MetaModes:
[ 3250.815] (II) NVIDIA(0): “DFP-0:nvidia-auto-select”
[ 3250.815] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 3250.818] (–) NVIDIA(0): DPI set to (92, 91); computed from “UseEdidDpi” X config
[ 3250.818] (–) NVIDIA(0): option
[ 3250.818] (–) Depth 24 pixmap format is 32 bpp
[ 3250.818] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 3250.818] (II) NVIDIA: access.
[ 3250.821] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 3250.821] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 3250.821] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 3250.821] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 3250.821] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 3250.821] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 3250.821] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 3250.821] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 3250.821] (II) NVIDIA(0): Config Options in the README.
[ 3250.877] (II) NVIDIA(0): Setting mode “DFP-0:nvidia-auto-select”
[ 3251.021] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 3251.021] (==) NVIDIA(0): Backing store enabled
[ 3251.021] (==) NVIDIA(0): Silken mouse enabled
[ 3251.022] (==) NVIDIA(0): DPMS enabled
[ 3251.022] (II) Loading sub module “dri2”
[ 3251.022] (II) LoadModule: “dri2”
[ 3251.022] (II) Module “dri2” already built-in
[ 3251.022] (II) NVIDIA(0): [DRI2] Setup complete
[ 3251.022] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 3251.026] (–) RandR disabled
[ 3251.037] (II) SELinux: Disabled on system
[ 3251.038] (II) Initializing extension GLX
[ 3251.038] (II) Indirect GLX disabled.
[ 3251.159] (II) config/udev: Adding input device tegra-hda-xnx HDMI/DP,pcm=3 (/dev/input/event0)
[ 3251.160] (II) No input driver specified, ignoring this device.
[ 3251.160] (II) This device may have been added with another device file.
[ 3251.161] (II) config/udev: Adding input device tegra-hda-xnx HDMI/DP,pcm=7 (/dev/input/event1)
[ 3251.161] (II) No input driver specified, ignoring this device.
[ 3251.161] (II) This device may have been added with another device file.
[ 3251.162] (II) config/udev: Adding input device tegra-hda-xnx HDMI/DP,pcm=8 (/dev/input/event2)
[ 3251.162] (II) No input driver specified, ignoring this device.
[ 3251.162] (II) This device may have been added with another device file.
[ 3251.162] (II) config/udev: Adding input device tegra-hda-xnx HDMI/DP,pcm=9 (/dev/input/event3)
[ 3251.163] (II) No input driver specified, ignoring this device.
[ 3251.163] (II) This device may have been added with another device file.
[ 3251.164] (II) config/udev: Adding input device SINO WEALTH USB KEYBOARD (/dev/input/event5)
[ 3251.164] () SINO WEALTH USB KEYBOARD: Applying InputClass “libinput keyboard catchall”
[ 3251.164] (II) LoadModule: “libinput”
[ 3251.165] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 3251.170] (II) Module libinput: vendor=“X.Org Foundation”
[ 3251.170] compiled for 1.19.6, module version = 0.27.1
[ 3251.170] Module class: X.Org XInput Driver
[ 3251.170] ABI class: X.Org XInput driver, version 24.1
[ 3251.170] (II) Using input driver ‘libinput’ for ‘SINO WEALTH USB KEYBOARD’
[ 3251.174] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 32 paused 0
[ 3251.174] (
) SINO WEALTH USB KEYBOARD: always reports core events
[ 3251.174] () Option “Device” “/dev/input/event5”
[ 3251.174] (
) Option “_source” “server/udev”
[ 3251.177] (II) event5 - SINO WEALTH USB KEYBOARD: is tagged by udev as: Keyboard
[ 3251.177] (II) event5 - SINO WEALTH USB KEYBOARD: device is a keyboard
[ 3251.177] (II) event5 - SINO WEALTH USB KEYBOARD: device removed
[ 3251.178] () Option “config_info” “udev:/sys/devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:5C0A:8502.0001/input/input5/event5”
[ 3251.178] (II) XINPUT: Adding extended input device “SINO WEALTH USB KEYBOARD” (type: KEYBOARD, id 6)
[ 3251.178] (
) Option “xkb_model” “pc105”
[ 3251.178] () Option “xkb_layout” “us”
[ 3251.180] (II) event5 - SINO WEALTH USB KEYBOARD: is tagged by udev as: Keyboard
[ 3251.180] (II) event5 - SINO WEALTH USB KEYBOARD: device is a keyboard
[ 3251.182] (II) config/udev: Adding input device SINO WEALTH USB KEYBOARD (/dev/input/event6)
[ 3251.182] (
) SINO WEALTH USB KEYBOARD: Applying InputClass “libinput pointer catchall”
[ 3251.182] () SINO WEALTH USB KEYBOARD: Applying InputClass “libinput keyboard catchall”
[ 3251.182] (II) Using input driver ‘libinput’ for ‘SINO WEALTH USB KEYBOARD’
[ 3251.184] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 35 paused 0
[ 3251.184] (
[ 3251.184] () Option “Device” “/dev/input/event6”
[ 3251.185] (
[ 3251.186] (II) event6 - SINO WEALTH USB KEYBOARD: is tagged by udev as: Keyboard Mouse
[ 3251.186] (II) event6 - SINO WEALTH USB KEYBOARD: device is a pointer
[ 3251.186] (II) event6 - SINO WEALTH USB KEYBOARD: device is a keyboard
[ 3251.186] (II) event6 - SINO WEALTH USB KEYBOARD: device removed
[ 3251.186] (II) libinput: SINO WEALTH USB KEYBOARD: needs a virtual subdevice
[ 3251.186] () Option “config_info” “udev:/sys/devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:5C0A:8502.0002/input/input6/event6”
[ 3251.186] (II) XINPUT: Adding extended input device “SINO WEALTH USB KEYBOARD” (type: MOUSE, id 7)
[ 3251.187] (
) Option “AccelerationScheme” “none”
[ 3251.187] () SINO WEALTH USB KEYBOARD: (accel) selected scheme none/0
[ 3251.187] (
) SINO WEALTH USB KEYBOARD: (accel) acceleration factor: 2.000
[ 3251.187] () SINO WEALTH USB KEYBOARD: (accel) acceleration threshold: 4
[ 3251.188] (II) event6 - SINO WEALTH USB KEYBOARD: is tagged by udev as: Keyboard Mouse
[ 3251.189] (II) event6 - SINO WEALTH USB KEYBOARD: device is a pointer
[ 3251.189] (II) event6 - SINO WEALTH USB KEYBOARD: device is a keyboard
[ 3251.190] (II) config/udev: Adding input device SINO WEALTH USB KEYBOARD (/dev/input/mouse0)
[ 3251.190] (II) No input driver specified, ignoring this device.
[ 3251.190] (II) This device may have been added with another device file.
[ 3251.191] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event7)
[ 3251.191] (
) USB OPTICAL MOUSE: Applying InputClass “libinput pointer catchall”
[ 3251.191] (II) Using input driver ‘libinput’ for ’ USB OPTICAL MOUSE’
[ 3251.253] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 36 paused 0
[ 3251.253] () USB OPTICAL MOUSE: always reports core events
[ 3251.253] (
) Option “Device” “/dev/input/event7”
[ 3251.253] () Option “_source” “server/udev”
[ 3251.254] (II) event7 - USB OPTICAL MOUSE: is tagged by udev as: Mouse
[ 3251.254] (II) event7 - USB OPTICAL MOUSE: device is a pointer
[ 3251.254] (II) event7 - USB OPTICAL MOUSE: device removed
[ 3251.254] (
) Option “config_info” “udev:/sys/devices/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:0000:3825.0003/input/input7/event7”
[ 3251.254] (II) XINPUT: Adding extended input device " USB OPTICAL MOUSE" (type: MOUSE, id 8)
[ 3251.255] () Option “AccelerationScheme” “none”
[ 3251.255] (
) USB OPTICAL MOUSE: (accel) selected scheme none/0
[ 3251.255] () USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[ 3251.255] (
) USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[ 3251.256] (II) event7 - USB OPTICAL MOUSE: is tagged by udev as: Mouse
[ 3251.256] (II) event7 - USB OPTICAL MOUSE: device is a pointer
[ 3251.257] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/mouse1)
[ 3251.257] (II) No input driver specified, ignoring this device.
[ 3251.257] (II) This device may have been added with another device file.
[ 3251.259] (II) config/udev: Adding input device gpio-keys (/dev/input/event4)
[ 3251.259] () gpio-keys: Applying InputClass “libinput keyboard catchall”
[ 3251.259] (II) Using input driver ‘libinput’ for ‘gpio-keys’
[ 3251.262] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 37 paused 0
[ 3251.262] (
) gpio-keys: always reports core events
[ 3251.262] () Option “Device” “/dev/input/event4”
[ 3251.262] (
[ 3251.263] (II) event4 - gpio-keys: is tagged by udev as: Keyboard
[ 3251.263] (II) event4 - gpio-keys: device is a keyboard
[ 3251.263] (II) event4 - gpio-keys: device removed
[ 3251.263] () Option “config_info” “udev:/sys/devices/gpio-keys/input/input4/event4”
[ 3251.263] (II) XINPUT: Adding extended input device “gpio-keys” (type: KEYBOARD, id 9)
[ 3251.263] (
[ 3251.263] () Option “xkb_layout” “us”
[ 3251.264] (II) event4 - gpio-keys: is tagged by udev as: Keyboard
[ 3251.265] (II) event4 - gpio-keys: device is a keyboard
[ 3251.281] (
[ 3251.281] () SINO WEALTH USB KEYBOARD: Applying InputClass “libinput keyboard catchall”
[ 3251.281] (II) Using input driver ‘libinput’ for ‘SINO WEALTH USB KEYBOARD’
[ 3251.281] (II) systemd-logind: returning pre-existing fd for /dev/input/event6 13:70
[ 3251.281] (
[ 3251.281] () Option “Device” “/dev/input/event6”
[ 3251.281] (
) Option “_source” “_driver/libinput”
[ 3251.281] (II) libinput: SINO WEALTH USB KEYBOARD: is a virtual subdevice
[ 3251.281] () Option “config_info” “udev:/sys/devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:5C0A:8502.0002/input/input6/event6”
[ 3251.281] (II) XINPUT: Adding extended input device “SINO WEALTH USB KEYBOARD” (type: KEYBOARD, id 10)
[ 3251.281] (
[ 3251.281] () Option “xkb_layout” “us”
[ 3252.063] (
) Option “fd” “32”
[ 3252.063] (II) event5 - SINO WEALTH USB KEYBOARD: device removed
[ 3252.064] () Option “fd” “35”
[ 3252.064] (
) Option “fd” “36”
[ 3252.064] (II) event7 - USB OPTICAL MOUSE: device removed
[ 3252.064] () Option “fd” “37”
[ 3252.064] (II) event4 - gpio-keys: device removed
[ 3252.064] (
) Option “fd” “35”
[ 3252.064] (II) event6 - SINO WEALTH USB KEYBOARD: device removed
[ 3252.067] (II) UnloadModule: “libinput”
[ 3252.067] (II) systemd-logind: not releasing fd for 13:70, still in use
[ 3252.067] (II) systemd-logind: releasing fd for 13:68
[ 3252.088] (II) UnloadModule: “libinput”
[ 3252.088] (II) systemd-logind: releasing fd for 13:71
[ 3252.144] (II) UnloadModule: “libinput”
[ 3252.144] (II) systemd-logind: releasing fd for 13:70
[ 3252.192] (II) UnloadModule: “libinput”
[ 3252.192] (II) systemd-logind: releasing fd for 13:69
[ 3252.336] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 3255.414] (II) Server terminated successfully (0). Closing log file.
This is the log from your last successful boot up. Not this time.
Please reboot your device again and see if your syslog has some gdm3-x-session log.
Please do not directly copy the whole log up here. Do the check on your side first.
Note that you can attach the Xorg log file directly to the forum. You could use scp to copy the file from Jetson to host PC if you want to, or even “cat” the file while logging from your host, and then attach that file. In cases where you do paste content from a log you’d want to mark it as “code” via the “</>” icon to avoid formatting changes.
Also note that when you run an X server it will always have a “DISPLAY” environment variable. If the system tries to run an X server automatically, then it might be “:0”, and a manually run instance might be “:1”
it just depends on the order of running. That number is tied to the Xorg log file, so if DISPLAY is “:1”, then the log would be “/var/log/Xorg.1.log” instead of the “Xorg.0.log”. If you’ve just tried startx, and assuming the log was updated, then you’ll know the most recent log is found via:
ls -ltr /var/log/Xorg.*.log | tail -n 1
Be certain that the log is not only for the current boot, but also that the log corresponds to your startx and is not a log from the system trying to automatically start an instance upon boot.
[  3250.711]
[  3250.744] xorg-server 2:1.19.6-1ubuntu4.9 (For technical support please see http://www.ubuntu.com/support)
[  3250.753] Markers: (--) probed, (**) from config file, (==) default setting,
[  3250.766] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jul  9 18:54:16 2021
[  3250.769] (==) Using config file: "/etc/X11/xorg.conf"
[  3250.772] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  3250.773] (**) |-->Screen "Default Screen Section" (0)
[  3250.773] (**) |   |-->Monitor "<default monitor>"
[  3250.775] (==) No device specified for screen "Default Screen Section".
[  3250.775] (**) |   |-->Device "Tegra0"
[  3250.775] (==) No monitor specified for screen "Default Screen Section".
[  3250.775] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[  3250.775] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[  3250.775] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[  3250.775] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[  3250.775] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
	built-ins
[  3250.775] (==) ModulePath set to "/usr/lib/xorg/modules"
[  3250.793] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[  3250.793] (II) "glx" will be loaded by default.
[  3250.793] (II) LoadModule: "extmod"
[  3250.793] (II) Module "extmod" already built-in
[  3250.793] (II) LoadModule: "glx"
[  3250.796] (II) Module glx: vendor="X.Org Foundation"
[  3250.796] (II) LoadModule: "nvidia"
[  3250.798] (II) Module nvidia: vendor="NVIDIA Corporation"
[  3250.798] (II) Loading sub module "fb"
[  3250.798] (II) LoadModule: "fb"
[  3250.799] (II) Module fb: vendor="X.Org Foundation"
[  3250.799] (II) Loading sub module "wfb"
[  3250.799] (II) LoadModule: "wfb"
[  3250.799] (II) Module wfb: vendor="X.Org Foundation"
[  3250.799] (II) Loading sub module "ramdac"
[  3250.799] (II) LoadModule: "ramdac"
[  3250.799] (II) Module "ramdac" already built-in
	"Default Screen Section" for depth/fbbpp 24/32
[  3250.801] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[  3250.801] (**) NVIDIA(0): Enabling 2D acceleration
[  3250.802] (II) Loading sub module "glxserver_nvidia"
[  3250.802] (II) LoadModule: "glxserver_nvidia"
[  3250.809] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[  3250.813] (--) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[  3250.813] (--) NVIDIA(0):     DFP-0
[  3250.813] (--) NVIDIA(0):     DFP-1
[  3250.814] (--) NVIDIA(0): Memory: 7949628 kBytes
[  3250.814] (--) NVIDIA(0): VideoBIOS:
[  3250.814] (--) NVIDIA(GPU-0): HPN HP 24m (DFP-0): connected
[  3250.814] (--) NVIDIA(GPU-0): HPN HP 24m (DFP-0): External TMDS
[  3250.815] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[  3250.815] (II) NVIDIA(0):     "DFP-0:nvidia-auto-select"
[  3250.818] (--) NVIDIA(0): DPI set to (92, 91); computed from "UseEdidDpi" X config
[  3250.818] (--) NVIDIA(0):     option
[  3250.818] (--) Depth 24 pixmap format is 32 bpp
[  3250.821] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  3250.821] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  3250.821] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  3250.877] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[  3251.022] (II) Loading sub module "dri2"
[  3251.022] (II) LoadModule: "dri2"
[  3251.022] (II) Module "dri2" already built-in
[  3251.026] (--) RandR disabled
[  3251.164] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "libinput keyboard catchall"
[  3251.164] (II) LoadModule: "libinput"
[  3251.170] (II) Module libinput: vendor="X.Org Foundation"
[  3251.170] (II) Using input driver 'libinput' for 'SINO WEALTH USB KEYBOARD'
[  3251.174] (**) SINO WEALTH USB KEYBOARD: always reports core events
[  3251.174] (**) Option "Device" "/dev/input/event5"
[  3251.174] (**) Option "_source" "server/udev"
[  3251.178] (**) Option "config_info" "udev:/sys/devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:5C0A:8502.0001/input/input5/event5"
[  3251.178] (II) XINPUT: Adding extended input device "SINO WEALTH USB KEYBOARD" (type: KEYBOARD, id 6)
[  3251.178] (**) Option "xkb_model" "pc105"
[  3251.178] (**) Option "xkb_layout" "us"
[  3251.182] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "libinput pointer catchall"
[  3251.182] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "libinput keyboard catchall"
[  3251.182] (II) Using input driver 'libinput' for 'SINO WEALTH USB KEYBOARD'
[  3251.184] (**) SINO WEALTH USB KEYBOARD: always reports core events
[  3251.184] (**) Option "Device" "/dev/input/event6"
[  3251.185] (**) Option "_source" "server/udev"
[  3251.186] (**) Option "config_info" "udev:/sys/devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:5C0A:8502.0002/input/input6/event6"
[  3251.186] (II) XINPUT: Adding extended input device "SINO WEALTH USB KEYBOARD" (type: MOUSE, id 7)
[  3251.187] (**) Option "AccelerationScheme" "none"
[  3251.187] (**) SINO WEALTH USB KEYBOARD: (accel) selected scheme none/0
[  3251.187] (**) SINO WEALTH USB KEYBOARD: (accel) acceleration factor: 2.000
[  3251.187] (**) SINO WEALTH USB KEYBOARD: (accel) acceleration threshold: 4
[  3251.191] (**)  USB OPTICAL MOUSE: Applying InputClass "libinput pointer catchall"
[  3251.191] (II) Using input driver 'libinput' for ' USB OPTICAL MOUSE'
[  3251.253] (**)  USB OPTICAL MOUSE: always reports core events
[  3251.253] (**) Option "Device" "/dev/input/event7"
[  3251.253] (**) Option "_source" "server/udev"
[  3251.254] (**) Option "config_info" "udev:/sys/devices/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:0000:3825.0003/input/input7/event7"
[  3251.255] (**) Option "AccelerationScheme" "none"
[  3251.255] (**)  USB OPTICAL MOUSE: (accel) selected scheme none/0
[  3251.255] (**)  USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[  3251.255] (**)  USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[  3251.259] (**) gpio-keys: Applying InputClass "libinput keyboard catchall"
[  3251.259] (II) Using input driver 'libinput' for 'gpio-keys'
[  3251.262] (**) gpio-keys: always reports core events
[  3251.262] (**) Option "Device" "/dev/input/event4"
[  3251.262] (**) Option "_source" "server/udev"
[  3251.263] (**) Option "config_info" "udev:/sys/devices/gpio-keys/input/input4/event4"
[  3251.263] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 9)
[  3251.263] (**) Option "xkb_model" "pc105"
[  3251.263] (**) Option "xkb_layout" "us"
[  3251.281] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "libinput pointer catchall"
[  3251.281] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "libinput keyboard catchall"
[  3251.281] (II) Using input driver 'libinput' for 'SINO WEALTH USB KEYBOARD'
[  3251.281] (**) SINO WEALTH USB KEYBOARD: always reports core events
[  3251.281] (**) Option "Device" "/dev/input/event6"
[  3251.281] (**) Option "_source" "_driver/libinput"
[  3251.281] (**) Option "config_info" "udev:/sys/devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:5C0A:8502.0002/input/input6/event6"
[  3251.281] (II) XINPUT: Adding extended input device "SINO WEALTH USB KEYBOARD" (type: KEYBOARD, id 10)
[  3251.281] (**) Option "xkb_model" "pc105"
[  3251.281] (**) Option "xkb_layout" "us"
[  3252.063] (**) Option "fd" "32"
[  3252.064] (**) Option "fd" "35"
[  3252.064] (**) Option "fd" "36"
[  3252.064] (**) Option "fd" "37"
[  3252.067] (II) UnloadModule: "libinput"
[  3252.088] (II) UnloadModule: "libinput"
[  3252.144] (II) UnloadModule: "libinput"
[  3252.192] (II) UnloadModule: "libinput"
I don’t know where to copy the log? So I provided the entire log file? In my case? What kind of log file should I provide you? I am not sure about this, or if you are targeting my situation, there are Is there no better solution or suggestion?
Reboot your device. Go to your /var/log/syslog.
Check the log with your local time, because the syslog is very very long, you have to use the timestamp to make sure which one is for current boot.
Search keyword “gdm3-x-session” and see if you can see it.
Also, is your NX disk space still enough?
Disk space is enough. I think it can be solved by installing a graphical interface on the Internet. I don’t know if this nx can be solved by installing a graphical interface? The following code is the way to reinstall the graphical interface provided on the Internet.
sudo apt-get update
sudo apt-get install ubuntu-desktop
sudo apt-get install unity
sudo apt-get install lightdm
sudo service gdm3 start
sudo systemctl set-default graphical.target
Just try this command and dump the log
sudo service gdm3 restart
We use gdm3 but not lightdm. You don’t need to install lightdm
Failed to restart gdm3.service: Unit gdm3.service not found.
The above error message appears after input
I found that the 18.04 ubuntu system often has the problem of not being able to enter the desktop after restarting. How should we avoid this problem? Or where should we start to find the problem when this problem occurs, and then smoothly solve this problem?
That is what we are doing now. There lots of possibilities to hit such issue and what we are doing now is debug.
Our current problem is why even your gdm3 is gone. Did you remove it? If you removed it, then it makes sense the desktop is gone.
Are these commands returning any result?
systemctl status gdm.service
systemctl status gdm3.service
nvidia@nx:/home1/workspace/sukai$ systemctl status gdm.service
Unit gdm.service could not be found.
Unit gdm3.service could not be found.
In this case, do I need to reinstall gdm3?
My problem is still not solved? Do you have any better suggestions or solutions?
You can just reflash the board. It looks like you’ve removed lots of things from original setting.
Another Xavier agx also failed to enter the desktop, the following is the error log information
Jul 13 11:55:46 xavier zeitgeist-datah[9285]: Attempting to read the recently used resources file at '/home/nvidia/.local/share/recently-used.xbel', but the parser failed: Failed to open file “/home/nvidia/.local/share/recently-used.xbel”: Permission denied.
Jul 13 11:55:53 xavier zeitgeist-datah[9285]: Attempting to read the recently used resources file at '/home/nvidia/.local/share/recently-used.xbel', but the parser failed: Failed to open file “/home/nvidia/.local/share/recently-used.xbel”: Permission denied.
Jul 13 11:56:00 xavier zeitgeist-datah[9285]: Attempting to read the recently used resources file at '/home/nvidia/.local/share/recently-used.xbel', but the parser failed: Failed to open file “/home/nvidia/.local/share/recently-used.xbel”: Permission denied.
Jul 13 11:56:02 xavier update-notifier.desktop[9373]: Unable to init server: Could not connect: Connection refused
Jul 13 11:56:02 xavier update-notifier.desktop[9373]: Failed to init the UI: Cannot open display:
Jul 13 11:56:02 xavier gnome-software-service.desktop[9375]: Unable to init server: Could not connect: Connection refused
Jul 13 11:56:02 xavier gnome-software[9375]: cannot open display: :0
The log has nothing to do with the desktop.
ul 13 11:55:12 xavier kernel: [   23.866498] tegradc 15200000.nvdisplay: unblank
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (==) NVIDIA(0): Disabling shared memory pixmaps
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (==) NVIDIA(0): Backing store enabled
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (==) NVIDIA(0): Silken mouse enabled
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (==) NVIDIA(0): DPMS enabled
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) Loading sub module "dri2"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) LoadModule: "dri2"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) Module "dri2" already built-in
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) NVIDIA(0): [DRI2] Setup complete
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (--) RandR disabled
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) SELinux: Disabled on system
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) AIGLX: Screen 0 is not DRI2 capable
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (EE) AIGLX: reverting to software rendering
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) IGLX: enabled GLX_MESA_copy_sub_buffer
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) IGLX: Loaded and initialized swrast
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) GLX: Initialized DRISWRAST GL provider for screen 0
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) config/udev: Adding input device tegra-hda-galen-t194 HDMI/DP,pcm=3 (/dev/input/event0)
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) No input driver specified, ignoring this device.
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) This device may have been added with another device file.
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) config/udev: Adding input device tegra-hda-galen-t194 HDMI/DP,pcm=7 (/dev/input/event1)
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) config/udev: Adding input device tegra-hda-galen-t194 HDMI/DP,pcm=8 (/dev/input/event2)
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) config/udev: Adding input device tegra-hda-galen-t194 HDMI/DP,pcm=9 (/dev/input/event3)
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) config/udev: Adding input device Dell Dell Universal Receiver (/dev/input/event4)
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Dell Dell Universal Receiver: Applying InputClass "libinput keyboard catchall"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) LoadModule: "libinput"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) Module libinput: vendor="X.Org Foundation"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: #011compiled for 1.19.6, module version = 0.27.1
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: #011Module class: X.Org XInput Driver
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: #011ABI class: X.Org XInput driver, version 24.1
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) Using input driver 'libinput' for 'Dell Dell Universal Receiver'
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 31 paused 0
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Dell Dell Universal Receiver: always reports core events
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "Device" "/dev/input/event4"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "_source" "server/udev"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) event4  - Dell Dell Universal Receiver: is tagged by udev as: Keyboard
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) event4  - Dell Dell Universal Receiver: device is a keyboard
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) event4  - Dell Dell Universal Receiver: device removed
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "config_info" "udev:/sys/devices/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:301D.0001/input/input4/event4"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) XINPUT: Adding extended input device "Dell Dell Universal Receiver" (type: KEYBOARD, id 6)
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "xkb_model" "pc105"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "xkb_layout" "us"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) config/udev: Adding input device Dell Dell Universal Receiver (/dev/input/event5)
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Dell Dell Universal Receiver: Applying InputClass "libinput pointer catchall"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 34 paused 0
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "Device" "/dev/input/event5"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) event5  - Dell Dell Universal Receiver: is tagged by udev as: Keyboard Mouse
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) event5  - Dell Dell Universal Receiver: device is a pointer
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) event5  - Dell Dell Universal Receiver: device is a keyboard
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) event5  - Dell Dell Universal Receiver: device removed
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) libinput: Dell Dell Universal Receiver: needs a virtual subdevice
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "config_info" "udev:/sys/devices/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.1/0003:413C:301D.0002/input/input5/event5"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) XINPUT: Adding extended input device "Dell Dell Universal Receiver" (type: MOUSE, id 7)
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "AccelerationScheme" "none"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Dell Dell Universal Receiver: (accel) selected scheme none/0
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Dell Dell Universal Receiver: (accel) acceleration factor: 2.000
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Dell Dell Universal Receiver: (accel) acceleration threshold: 4
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) config/udev: Adding input device Dell Dell Universal Receiver (/dev/input/mouse0)
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) config/udev: Adding input device gpio-keys (/dev/input/event6)
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) gpio-keys: Applying InputClass "libinput keyboard catchall"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) Using input driver 'libinput' for 'gpio-keys'
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 35 paused 0
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) gpio-keys: always reports core events
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "Device" "/dev/input/event6"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) event6  - gpio-keys: is tagged by udev as: Keyboard
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) event6  - gpio-keys: device is a keyboard
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) event6  - gpio-keys: device removed
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "config_info" "udev:/sys/devices/gpio-keys/input/input6/event6"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 8)
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) systemd-logind: returning pre-existing fd for /dev/input/event5 13:69
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "_source" "_driver/libinput"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) libinput: Dell Dell Universal Receiver: is a virtual subdevice
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) XINPUT: Adding extended input device "Dell Dell Universal Receiver" (type: KEYBOARD, id 9)
Jul 13 11:55:12 xavier systemd[9198]: Started D-Bus User Message Bus.
Jul 13 11:55:12 xavier gnome-session[9235]: libGL error: MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
Jul 13 11:55:12 xavier gnome-session[9235]: libGL error: failed to load driver: swrast
Jul 13 11:55:12 xavier dbus-daemon[9232]: [session uid=120 pid=9232] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.2' (uid=120 pid=9236 comm="/usr/lib/gnome-session/gnome-session-check-acceler")
Jul 13 11:55:12 xavier systemd[9198]: Starting Accessibility services bus...
Jul 13 11:55:12 xavier dbus-daemon[9232]: [session uid=120 pid=9232] Successfully activated service 'org.a11y.Bus'
Jul 13 11:55:12 xavier systemd[9198]: Started Accessibility services bus.
Jul 13 11:55:12 xavier at-spi-bus-launcher[9237]: dbus-daemon[9242]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=9236 comm="/usr/lib/gnome-session/gnome-session-check-acceler")
Jul 13 11:55:12 xavier at-spi-bus-launcher[9237]: dbus-daemon[9242]: Successfully activated service 'org.a11y.atspi.Registry'
Jul 13 11:55:12 xavier at-spi-bus-launcher[9237]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jul 13 11:55:12 xavier gnome-session[9235]: X Error of failed request:  GLXBadContext
Jul 13 11:55:12 xavier gnome-session[9235]:   Major opcode of failed request:  154 (GLX)
Jul 13 11:55:12 xavier gnome-session[9235]:   Minor opcode of failed request:  6 (X_GLXIsDirect)
Jul 13 11:55:12 xavier gnome-session[9235]:   Serial number of failed request:  35
Jul 13 11:55:12 xavier gnome-session[9235]:   Current serial number in output stream:  34
Jul 13 11:55:12 xavier gnome-session[9235]: gnome-session-check-accelerated: GL Helper exited with code 256
Jul 13 11:55:12 xavier dbus-daemon[9232]: [session uid=120 pid=9232] Activating service name='org.gnome.ScreenSaver' requested by ':1.15' (uid=120 pid=9235 comm="/usr/lib/gnome-session/gnome-session-binary --auto")
Jul 13 11:55:12 xavier gnome-screensav[9254]: Couldn't get presence status: The name org.gnome.SessionManager was not provided by any .service files
Jul 13 11:55:12 xavier dbus-daemon[9232]: [session uid=120 pid=9232] Successfully activated service 'org.gnome.ScreenSaver'
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (--) NVIDIA(GPU-0): IPS XY190 (DFP-0): connected
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (--) NVIDIA(GPU-0): IPS XY190 (DFP-0): External TMDS
Jul 13 11:55:12 xavier org.gnome.Shell.desktop[9259]: libGL error: MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
Jul 13 11:55:12 xavier org.gnome.Shell.desktop[9259]: libGL error: failed to load driver: swrast
Jul 13 11:55:12 xavier gnome-shell[9259]: Unable to initialize Clutter: Unable to initialize the Clutter backend: no available drivers found.
Jul 13 11:55:12 xavier gnome-shell[9259]: Unable to initialize Clutter.
Jul 13 11:55:12 xavier gnome-session[9235]: gnome-session-binary[9235]: WARNING: App 'org.gnome.Shell.desktop' exited with code 1
Jul 13 11:55:12 xavier gnome-session-binary[9235]: WARNING: App 'org.gnome.Shell.desktop' exited with code 1
Jul 13 11:55:12 xavier org.gnome.Shell.desktop[9266]: libGL error: MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
Jul 13 11:55:12 xavier org.gnome.Shell.desktop[9266]: libGL error: failed to load driver: swrast
Jul 13 11:55:12 xavier gnome-shell[9266]: Unable to initialize Clutter: Unable to initialize the Clutter backend: no available drivers found.
Jul 13 11:55:12 xavier gnome-shell[9266]: Unable to initialize Clutter.
Jul 13 11:55:12 xavier gnome-session[9235]: gnome-session-binary[9235]: WARNING: App 'org.gnome.Shell.desktop' respawning too quickly
Jul 13 11:55:12 xavier gnome-session-binary[9235]: WARNING: App 'org.gnome.Shell.desktop' respawning too quickly
Jul 13 11:55:12 xavier gnome-session-binary[9235]: Unrecoverable failure in required component org.gnome.Shell.desktop
Jul 13 11:55:12 xavier gnome-session[9235]: gnome-session-binary[9235]: CRITICAL: We failed, but the fail whale is dead. Sorry....
Jul 13 11:55:12 xavier gnome-session-binary[9235]: CRITICAL: We failed, but the fail whale is dead. Sorry....
Jul 13 11:55:12 xavier gnome-screensav[9254]: gnome-screensaver: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Jul 13 11:55:12 xavier at-spi-bus-launcher[9237]: XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
Jul 13 11:55:12 xavier at-spi-bus-launcher[9237]:       after 21 requests (21 known processed) with 0 events remaining.
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "fd" "31"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "fd" "34"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (**) Option "fd" "35"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) UnloadModule: "libinput"
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) systemd-logind: not releasing fd for 13:69, still in use
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) systemd-logind: releasing fd for 13:70
Jul 13 11:55:12 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) systemd-logind: releasing fd for 13:69
Jul 13 11:55:13 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) UnloadModule: "libinput"
Jul 13 11:55:13 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) systemd-logind: releasing fd for 13:68
Jul 13 11:55:13 xavier kernel: [   24.858723] tegradc 15200000.nvdisplay: blank - powerdown
Jul 13 11:55:13 xavier kernel: [   24.924421] Extcon AUX2(HDMI) disable
Jul 13 11:55:13 xavier kernel: [   24.948186] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
Jul 13 11:55:13 xavier kernel: [   24.948841] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
Jul 13 11:55:13 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) NVIDIA(GPU-0): Deleting GPU-0
Jul 13 11:55:13 xavier kernel: [   24.958688] tegradc 15200000.nvdisplay: blank - powerdown
Jul 13 11:55:13 xavier kernel: [   24.958730] tegradc 15200000.nvdisplay: unblank
Jul 13 11:55:13 xavier kernel: [   24.973458] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
Jul 13 11:55:13 xavier kernel: [   24.973639] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
Jul 13 11:55:13 xavier kernel: [   24.984832] Parent Clock set for DC plld3
Jul 13 11:55:13 xavier kernel: [   24.989476] tegradc 15200000.nvdisplay: hdmi: tmds rate:106500K prod-setting:prod_c_hdmi_54m_111m
Jul 13 11:55:13 xavier kernel: [   24.990872] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
Jul 13 11:55:13 xavier kernel: [   25.025890] Extcon AUX2(HDMI) enable
Jul 13 11:55:13 xavier kernel: [   25.041142] tegradc 15200000.nvdisplay: sync windows ret = 246
Jul 13 11:55:13 xavier /usr/lib/gdm3/gdm-x-session[9210]: (II) Server terminated successfully (0). Closing log file.
Jul 13 11:55:13 xavier gdm3: GdmDisplay: display lasted 1.539906 seconds
Jul 13 11:55:13 xavier gdm3: GdmLocalDisplayFactory: maximum number of X display failures reached: check X server log for errors
Jul 13 11:55:13 xavier gdm3: Child process -9210 was already dead.
Jul 13 11:55:13 xavier systemd[1]: Stopping User Manager for UID 120...
Jul 13 11:55:13 xavier systemd[9198]: Stopped target Default.
Jul 13 11:55:13 xavier systemd[9198]: Stopping D-Bus User Message Bus...
Jul 13 11:55:13 xavier systemd[9198]: Stopping Accessibility services bus...
Jul 13 11:55:13 xavier systemd[9198]: Stopped D-Bus User Message Bus.
Jul 13 11:55:13 xavier systemd[9198]: Stopped Accessibility services bus.
Jul 13 11:55:13 xavier systemd[9198]: Stopped target Basic System.
Jul 13 11:55:13 xavier systemd[9198]: Stopped target Timers.
Jul 13 11:55:13 xavier systemd[9198]: Stopped target Paths.
Jul 13 11:55:13 xavier systemd[9198]: Stopped Pending report trigger for Ubuntu Report.
Jul 13 11:55:13 xavier systemd[9198]: Stopped target Sockets.
Jul 13 11:55:13 xavier systemd[9198]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jul 13 11:55:13 xavier systemd[9198]: Closed GnuPG cryptographic agent and passphrase cache.
Jul 13 11:55:13 xavier systemd[9198]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jul 13 11:55:13 xavier systemd[9198]: Closed D-Bus User Message Bus Socket.
Jul 13 11:55:13 xavier systemd[9198]: Closed REST API socket for snapd user session agent.
Jul 13 11:55:13 xavier systemd[9198]: Closed Sound System.
Jul 13 11:55:13 xavier systemd[9198]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jul 13 11:55:13 xavier systemd[9198]: Closed GnuPG network certificate management daemon.
Jul 13 11:55:13 xavier systemd[9198]: Reached target Shutdown.
Jul 13 11:55:13 xavier systemd[9198]: Starting Exit the Session...
Jul 13 11:55:13 xavier systemd[9198]: Received SIGRTMIN+24 from PID 9281 (kill).
Jul 13 11:55:13 xavier systemd[1]: Stopped User Manager for UID 120.
Jul 13 11:55:13 xavier systemd[1]: Removed slice User Slice of gdm.
Jul 13 11:55:23 xavier dbus-daemon[7454]: [session uid=1000 pid=7454] Activating via systemd: service name='org.gnome.zeitgeist.Engine' unit='zeitgeist.service' requested by ':1.115' (uid=1000 pid=9285 comm="zeitgeist-datahub ")
Jul 13 11:55:23 xavier systemd[7236]: Starting Zeitgeist activity log service...
Jul 13 11:55:23 xavier dbus-daemon[7454]: [session uid=1000 pid=7454] Activating via systemd: service name='org.gnome.zeitgeist.SimpleIndexer' unit='zeitgeist-fts.service' requested by ':1.116' (uid=1000 pid=9294 comm="/usr/bin/zeitgeist-daemon ")
Jul 13 11:55:23 xavier dbus-daemon[7454]: [session uid=1000 pid=7454] Successfully activated service 'org.gnome.zeitgeist.Engine'
Jul 13 11:55:23 xavier systemd[7236]: Started Zeitgeist activity log service.
Jul 13 11:55:23 xavier systemd[7236]: Starting Zeitgeist full-text search indexer...
Jul 13 11:55:23 xavier zeitgeist-daemon[9294]: #033[31m[03:55:23.622246 WARNING]#033[0m zeitgeist-daemon.vala:127: Unable to parse version info!
Jul 13 11:55:23 xavier zeitgeist-daemon[9294]: #033[31m[03:55:23.622712 WARNING]#033[0m zeitgeist-daemon.vala:127: Unable to parse version info!
Jul 13 11:55:23 xavier zeitgeist-daemon[9294]: #033[31m[03:55:23.645142 WARNING]#033[0m zeitgeist-daemon.vala:127: Unable to parse version info!
Jul 13 11:55:23 xavier zeitgeist-datah[9285]: Attempting to read the recently used resources file at '/home/nvidia/.local/share/recently-used.xbel', but the parser failed: Failed to open file “/home/nvidia/.local/share/recently-used.xbel”: Permission denied.
Jul 13 11:55:23 xavier zeitgeist-datah[9302]: zeitgeist-datahub.vala:227: Unable to get name "org.gnome.zeitgeist.datahub" on the bus!
Jul 13 11:55:23 xavier dbus-daemon[7454]: [session uid=1000 pid=7454] Successfully activated service 'org.gnome.zeitgeist.SimpleIndexer'
Jul 13 11:55:23 xavier systemd[7236]: Started Zeitgeist full-text search indexer.
Jul 13 11:55:24 xavier kernel: [   36.186392] vdd-epb-1v0: disabling
Jul 13 11:55:24 xavier kernel: [   36.186401] avdd-cam-2v8: disabling
Jul 13 11:55:24 xavier kernel: [   36.186406] vdd-sata-1v5: disabling
Jul 13 11:55:24 xavier kernel: [   36.186411] vdd-1v8-slt: disabling
Jul 13 11:55:24 xavier kernel: [   36.186415] vdd-3v3-slt: disabling
Jul 13 11:55:24 xavier kernel: [   36.186443] vdd-fan: disabling
Jul 13 11:55:24 xavier kernel: [   36.186448] vdd_sys_en: disabling
Jul 13 11:55:34 xavier systemd-timesyncd[3384]: Timed out waiting for reply from 193.182.111.14:123 (1.pool.ntp.org).
Jul 13 11:55:33 xavier systemd-timesyncd[3384]: Synchronized to time server 119.28.206.193:123 (1.pool.ntp.org).
Jul 13 11:55:43 xavier dbus-daemon[9353]: [session uid=0 pid=9351] Activating service name='org.a11y.Bus' requested by ':1.1' (uid=0 pid=9346 comm="gedit syslog ")
Jul 13 11:55:43 xavier dbus-daemon[9353]: [session uid=0 pid=9351] Successfully activated service 'org.a11y.Bus'
Jul 13 11:55:43 xavier org.a11y.Bus[9353]: dbus-daemon[9361]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=0 pid=9346 comm="gedit syslog ")
Jul 13 11:55:44 xavier dbus-daemon[9353]: [session uid=0 pid=9351] Activating service name='ca.desrt.dconf' requested by ':1.0' (uid=0 pid=9346 comm="gedit syslog ")
Jul 13 11:55:44 xavier dbus-daemon[9353]: [session uid=0 pid=9351] Successfully activated service 'ca.desrt.dconf'
Jul 13 11:55:44 xavier org.a11y.Bus[9353]: dbus-daemon[9361]: Successfully activated service 'org.a11y.atspi.Registry'
Jul 13 11:55:44 xavier org.a11y.Bus[9353]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
