• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 5.1
**• JetPack Version (valid for Jetson only)**4.5.1
• Issue Type( questions, new requirements, bugs) question
I have a system where a frame is processed by nvinfer PGIE (detector), then 1st nvinfeserver SGIE is run on detections of one specific class from PGIE. I use a probe to get this sgie’s results. Then I have a nvvideoconvert to convert frame to RGBA as I need access to frame data and NV12 is not supperted by pyds.get_nvds_buf_surface. I get the frame in a probe before 2nd nvinfeserver sgie and use 1st sgie’s output to modify (rotate) the frame data. At this point, if I check ‘obj_user_meta_list’, it is always None, but e.g. ‘class_id’ is present. Then I run 2nd nvinfeserver sgie on the frame, and try to intercept its output in a probe pretty much like with 1st sgie, but at this point obj_user_meta_list is also always None. I tried removing the nvvideoconvert from the pipeline, it would break the access to frame data because it is not RGBA now, but just before this step I get all the obj_user_meta_list from 1st sgie. It seems that after running nvvideoconvert, obj_user_meta_list from 1st gie is removed and not added by 2nd sgie afterwards. At the same time other object info like rect_params or class_ids remain intact. How can I keep it there?
